Question about Acer AL2216W LCD Monitor
Monitor amber light is on and it will not come out of sleep mode.you can push the menu button nothing happens screen stays black.
  • Jim McD May 22, 2008
    screen britens up for ony seconds at start-up then goes black, or when mouse is moved during sleep mode
  • jwrhcraw03 Dec 27, 2008
    i have the same problem, will be surfing the internet, just goes to sleep mode, what should i do
  • 975 Answers
OPEN MONITOR , look inside the PC BOARD around the transformer area and look for a burnt solder or cold solder , re solder it , and try again , please rate solution , thanks AJ
Posted on May 06, 2008
Monitor switch always return to Sleeo Mode
You can open the VGA cable and connect it again, sometimes there are two or three vga ports behind your cpu, connect the right one. Try it, if not success, change the cable.
Mar 11, 2017 | LG W2252TQ Monitor
Why does my HP vs17 monitor screen keep going to blank black screen like it turned off but did'nt.....blue power button light is still on? Everything is running but no picture.....keeps happening everytime...
this old monitor has 2 issues.
1: it has CCFL tubes that love to burn out (backlamps)
most this old are long go, yell,dim.,blinking or DEAD.
2: push the menu button on front of mon. turn off power saver.
3: if the PC goes to sleep, or hibernete mode (parked)
then that is 100% normal
if you dont like feature then go to windows control panel
click power, ICON and turn off all monitor sleep /hibernate modes.
that assumes windows, no OS stated.
if the lamps are dead,
use flash light pointed to sceen, see data. ? bingo for bad CCFT tubes.
as seen here
http://www.pcdied.com/monitors.html#flashlighttest
Jan 12, 2018 | HP Vs17 17" LCD Flat Panel Monitor
Monitor will not awake from sleep mode. Pilot light is amber when asleep. If the monitor is turned off pilot light goes from amber to off or black or nothing. Turning the monitor back on the pilot light...
That means your monitor is not receiving a signal from your video card.
A couple things to check:
*Make sure your cable is ok - unplug and replug the cable to see if it is a loose connection. Or try a different cable.
*Make sure your computer is not in sleep mode - Move your mouse or otherwise ensure your computer is awake and sending a video signal
*If you have another computer, try the monitor on the other system and see if it works.
Sep 03, 2017 | LG L196WTQ-BF 19" Monitor
The monitor starts up and goes into sleep mode
After repairing the on/off button for $100.00 and then rehooking up the monitor to my pc, the monitor has power but stays asleep even when I push in the menu button, I can't get anything to happen. HP techs tell me that the problem is with my computer although it worked perfectly fine before I unhooked all to send out the monitor.
I hooked all back up again as before but now the monitor will only say "monitor going to sleep" and nothing happens.
Wishing I had a solution. Thanks
Sep 10, 2010 | HP f2105 21" LCD Monitor
Amber colored power light on eMachine W3503
The amber power light indicates that your computer has been "sleeping" or "hibernating" and usually all it takes to restart the computer is tapping a key on the keyboard. If this is not the case, try holding the Power switch down for 6-10 seconds to force the system off. Restart in Safe Mode and try to find the settings for Sleep/hibernate, open the control panel and open the Screen Saver. Select "Change Power Settings" and set it for "Never" on sleep and hybernate.
Nov 10, 2009 | E-Machines W3503 PC Desktop
Monitor in sleep mode
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
Monitor just black
I would guess the capacitors are bulging or leaking. It can be repaired if you are handy with a soldering iron. Good Luck.
Oct 01, 2008 | Liquid Video A170E101 Monitor
Hyundai LCD monitor L70N Stuck in sleep mode?
push and hold the power button... then hit the settings button on the monitor and goto power>sleep mode
Jun 17, 2008 | Hyundai ImageQuest L70N 17" LCD Monitor
Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Feb 24, 2008 | Gateway FPD2275W LCD Monitor
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
Acer AL2216W LCD Monitor Logo
237 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
