Question about Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS 400D
My canon EOS 400D just died on me. It won't turn on .Battery is ok, and so is all the other stuff.The camera is about 16 months old.
Wat can the problem be?
  • 3 more comments
  • jordanchambe Aug 09, 2008
    Camera will just not switch on. Battery is fully charged as is the spare battery that I've also tried.
  • Anonymous Jan 27, 2009
    Same problem here.. :(
    Same problem here!
  • janestree Feb 02, 2009
    OMG ME TOOOOOO. Like, the previous night, it was still very very alive and doing okay, then the next morning, it couldn't "wake up". Gahhhhhhhhh
  • nja82099 Feb 03, 2009
    I have the same problem with my Canon Rebel XTi 400D. Is thre a solution. I have been able to get it turned on by removing the battery as well as the back-up cell battery but as soon as I turn it off it does not turn on again.
The camera is working again. I took out the battery, with the the on/off switch, off. I then swtiched the On/Off switch On. I then put the battery in ,and the camera turned on.It then gave me an ERROR 99. I then switch it off and on again, and it is still working.
Posted on Apr 29, 2008
  • zgpt Apr 03, 2011
    THANKS YOU SO MUCH. My Xti had the same problem and didn't work for a year until I finally found this post. I just gave away my old lenses and spare batteries for it TODAY whoops. Still can't believe it was that easy.
When The battery on my Canon 400d goes flat it loses the date and I have to re set it. I didn't need to do that until recently.
There is a small backup battery in the main battery compartment. I believe the XTi uses a CR2016 battery. It provides backup power to maintain the camera's settings when the main battery is removed.
Bob Kilbourn www.camerarepairs.com
Apr 28, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
My Canon EOS 400D won't switch on. No power.
Have you tried cleaning the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol? Are the batteries also 3 years old?
Dec 07, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
My 400D won't turn on
Did you overtighten the tripod screw?
Aug 16, 2009 | Canon EOS 400D Digital Camera
Error 99 message keeps popping up
err 99 is moisture or dew inside the camera.
May 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I would like to download a copy of a canon eos 400d manual in eng
Here's how to do it:
Go to this page: Canon Digital Rebel XTi
Click Drivers & Downloads, scroll all the way to the bottom, and click on the PDF link as shown.
EOS DIGITAL REBEL XTi / EOS 400D
DIGITAL Instruction Manual
EOSDRXTi400DIM-EN.pdf
Apr 22, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS Rebel problem
This is usually caused by a defective shutter release switch - it'll have to go into a repair shop - independent shops will charge about $110 USD - Canon charges about $180
Nov 26, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Camera doesn't appear to be working
Hi
Take the cameras back to the dealers. Even more so if you are coming to the end of the warranty. This sounds like a hardware fault. The cameras should operate without this sort of hitch and when you get the little red (read/write/power) staying on after you have switched it of and you have not just taking a strings of shots i.e. it is not writing to the card this is normally hardware failure. I had the same sort of thing on a 30D i used to have it turned out to be something which Canon replaced the main circuit board to get it working again.
Regards
Jun 20, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Camera won't turn on
Try replacing the date/time battery located in the main battery compartment. Also, simultaneously remove the lens. This will be like a master reboot for the camera. Replace the date/time coin battery, the main battery (freshly charged) and lastly the lens.
If this doesn't work, send it in for service. If you are just slightly beyond your one year warranty, Canon may allow a grace period especially if you can provide a receipt. If you can't find a receipt, give them the approximate date of purchase when you send in the camera. You will need to call them or set up service online.
Hope this helps!
Apr 25, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon error code 99
Your camera performs a quick 'integrity' check before each shot and goes into error 99 mode if the lens in incompatible or has a diaphragm problem. ( it will also display e99 if the shutter or flash unit is not ok but this does not apply here ). This is how you can check whether the diaphragm mechanism is ok : attach lens to your old camera and set camera to AV and set F stop to 16 . open back and release shutter and look through the back to see if your lens is closing to F 16. If it is closing fine then the lens is ok but is not compatible with your D400.
Sep 10, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
337 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
