Question about Intel Desktop Board D845WN Motherboard
Desktop Board D485wn Bios setup
I turn on the comp, and the Intel Screen Bios appear but it remains there, I change the jumper to bios config, but nothing happend while the message in thescreen is "Entering SET UP"
any suggestion?
  • Freejol Apr 28, 2008
    I tryed, and I have the same message in the screen,
    Thanks
    Genius:
  • 2,785 Answers
Plz try by removing your hard drive
Posted on Apr 28, 2008
  • Rajkumar Bordoloi
    Rajkumar Bordoloi Apr 29, 2008
    try with another working ram
Need to reset pin
Dear,
Any board there 3 stander Jumper for BIOS Config 1-2-3 in normal condition jumper always will be short on 1-2 if you want to clear the BIOS Config switch the computer take out the Jumper from 1-2 and insert in 2-3 after that switch on for 5 second and turn off computer then again take back jumper in to old postion that is 1-2 then start computer go in to bios setup you can see bios will be clear all old setting,
Thanks with Regard,
Ankur Goyal
Sep 10, 2015 | Computers & Internet
Author image Clayton Molle wrote: Hello Looking at the specs for this unit, I think I have a solution for you. The hard drive is SATA but the optical drive is ATA (the older ribbon cable connection).
older systems have 2 ata channels, each channel has a master and a slave so yes there can be two masters. you should set your boot hard disk to the primary (channel 0) master and the cdroms to master and slave on the secondary (channel 1) channel. the bios config jumper will allow you to config the bios, norm is for normal ops and there should indeed be two pins that you short together to clear the bios passwd
Nov 07, 2013 | MPC Computers ClientPro 365 PC Desktop
D845GVAD2 no bios screen no beep no boot
Hello here is the intel homepage:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+845+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D845GVAD2
Try to renew the power supply, with one you know is working.
I think that`s the problem.
The problem could ofcourse also be the mainboard itselves failing.
There is not much to do about that, other than renew the mainboard or buy a new pc.
Good luck
Apr 08, 2013 | Intel D845GVSR Motherboard
Intel Desktop Board D845BG (KD845BGPAK10) Motherboard display not working
it can be a motherboard fault try resetting your bios. u can rreset bios by changing jumper settings near to the bios
Mar 08, 2011 | Intel Desktop Board D845BG (KD845BGPAK10)...
When I open bios setup, some of the selections are dimmed and I cannot access them. How to fix it?
open yout cabiner then reset your bios setup but interchanging the jumper setting available on motherboard once u restart comp. later switch off n then place the jumper to its original place n start ur comp n try accessing bios.
Feb 17, 2010 | Intel Desktop Board D845GLAD Motherboard
Recover BIOS d845gebv2 motherboard my motherboard does not boot.monitor displays intel desktop board in blue screen
Right after you power the computer on start tapping F2 rapidly on the keyboard until you are in the BIOS setup. When you are in the BIOS setup, check to see that the computer recognizes your boot device and that your boot order is correct. Also, if you have changed any jumpers on your mainboard; change the back.
Sep 19, 2009 | Intel D845GEBV2 Motherboard
I want to the bios intel motherboard d845PEBT2 place sent me
First be clear, do you want to update your BIOS & if so then go through this first: To identify your current BIOS version, check the BIOS version string:
  1. During boot, enter the BIOS setup by pressing F2.
  2. Check the Main menu.
  3. The 4-digit number after the '86A' or '86I' is the current BIOS version, as in this example: MQ96510H.86A.1663.2007.0319.1957
  4. Press Escape to exit BIOS Setup.
Important:
  • Update the BIOS on your computer only if the newer BIOS version specifically solves a problem you have. We do not recommend BIOS updates for computers that do not need it. You can view all new BIOS fixes in the Release Notes included on the BIOS download page in Download Center.
  • Before initiating a BIOS update, be sure to read and precisely follow the update instructions. You may wish to print the instructions for easy reference.
  • If a BIOS update process is interrupted, your computer may not function properly. We recommend the process be done in an environment with a steady power supply (preferably with UPS).
  • All images in the examples used in the instructions are specific to certain desktop boards and are for illustration purposes only. You need to select the correct BIOS files for your desktop board.
There are up to six methods of updating an Intel® Desktop Board BIOS to the latest version. The number of options made available for any particular board may vary, depending on drive support and BIOS update file size. You only need to use one.
All BIOS update files for Intel® Desktop Boards are available on Intel(link: http://mysearch.intel.com/corporate/default.aspx?culture=en_US&q=d845PEBT2&category=all&adv=0&value=0&searchsubmit.x=30&searchsubmit.y=12).
If simply want to clear the BIOS then either remove the small battery on the MB, wait for a couple of minutes and replace it. Else close to the BIOS chip look for a 3 pin setup on the mother boar with a jumper on two pins Remove the jumper, wait for 10-20 seconds & replace it. That will clear the BIOS.
A word of caution, do not update the BIOS if your PC is working properly. Do it when prompted to,during installing a new software or hardware this message will pop up on the screen.................sodeep
May 15, 2009 | Intel Desktop Board D845PEBT2 Motherboard
I have intel board d-815 with intel logo. this board hangs at the time of setup entering. i have used all of my techics like power supply change, battery cell change, processor change, ram change and also...
they best way is to flash ur bios that will really help u can visit the intel website and download latest bios for your motherboard and flash and install it using according to instructions.thanks
www.intel.com
Mar 31, 2009 | Intel Desktop Board D845WN Motherboard
Bios setup problem at booting.
Make sure the BIOS Configuration Jumper is in the 'Normal' position (pins 1 and 2) and not in the Config position (pins 2 and 3). It is located near the battery at the corner of the board. The Manual and Config information can be found here.
Mar 14, 2008 | Intel D845GVSR Motherboard
Update my Intel D845GVSR Bios Version to VA84510A.86A.0056.P20, then my USB driver is not working at all.
I followed the suggestion of changing the BIOS configuration to the recovery mode, however one thing was missing - it required a startup disk and I didn't have one. I then changed the BIOS configuration to the config (pins 2 & 3) mode, booted up and went to the BIOS/CMOS setup and a new menu tab appeared called "maintenance". I went to the advance tab and selected USB configuration and, instead of a blank screen, there appeared a selection for USB support and it showed disabled. I changed the setting to enabled and three more lines of information regarding USB came up, but required not further changes. I went to F10 and saved and exited and I now have me USB capability back.
Mar 10, 2008 | Intel D845GVSR Motherboard
Intel Desktop Board D845WN Motherboard Logo
388 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
