Question about Janome Memory Craft 4000 Sewing Machine
Need to replace the light bulb--how do I do that
  • Janome Master
  • 1,388 Answers
You will need to obtain a new lamp from a Janome dealer.......they will probably offer to install it for you for no additional charge.......just ring to agree a time.
It is a small low voltage, simple push in type lamp & I believe the part number to be: 000 009 906
Just make sure the machine is NOT plugged in when you change it !!
Posted on May 10, 2008
My light just burnt iut onmy kenmore sewing machine and now it wont work
You need to replace the lightbulb. You may need to remove the cover over the lightbulb off in order to remove the bulb. Take the bulb to the local sewing machine repair shop or order a replacement online.
FWIW, you may want to consider an LED bulb. They are much brighter and do not get hot like the standard bulbs.
Mar 15, 2017 | Kenmore Sewing Machines
How do I change the light bulb on my Bernina 1530?
You might check out some of the older Bernina manuals to get an idea of how it may work in your machine. The 1260 is the closest manual available. Looks like your machine takes the same push-in bulb. So, you would push up on the bulb and twist. Then you would install the replacement the same way. Sometimes, using tight fitting medical gloves helps grip the bulb in order to twist.
BERNINA Sewing Systems
BTW--I have older Berninas and upgraded their bulbs to LED.
Oct 03, 2016 | Bernina Sewing Machines
How to remove light bulb cover Viking #1+
look on the left side of the machine and see if you see a little round plastic circle, very very carefully use a screw driver to pry it out , there should be a screw to unscrew and the side should come off so you can replace the bulb. if you will send me a comment with the complete name and model number, I'll see if I can find you a manual.
Jun 12, 2015 | Husqvarna Viking 1
Where is the light bulb located on a Memory Craft 4000 sewing machine. Need to change light
Hi Rhonda I have a 9000 and a 500e and the light should be directly above the needle shaft.
Good luck
Jan 20, 2015 | Janome Sewing Machines
Bulb replacement
Take it into an authorized repair shop to have the bulb replaced.
Some are more difficult than others there can be special tools needed to remove outer case to get to the light socket. The bulbs are a very specialty items as well.
Feb 01, 2014 | Janome Memory Craft 9000 Computerized...
Replace light bulb
Make sure power is turned off. Get a pair of pointy nose pliers (may need to try a couple of sizes to get correct one). Use these to get hold of the metal light base and remove. Will probably need to turn base to release.
Jan 18, 2014 | Elna 945 Computerized Sewing Machine
Light bulb not working
You need to change the bulb.
Most light bulbs in almost all sewing machines are located inside the face plate on the left hand side of the machine.
The faceplate is usually hinged at the back and it opens a bit like a door. It should open fairly easily and close with a click.
Open the faceplate and unscrew the bulb, it should be in plain view.
Look to see if it a screw or bayonet type.
Replace it the same way you would an ordinary bulb.
You can get sewing machine bulbs on ebay but you'll need to know which type of fitting it has before you buy.
Hope this helps!
Nov 10, 2010 | Singer 7462 Mechanical Sewing Machine
I can't find a button to turn on the light on my Designer 1
There is no button to turn on the light. When the machine is turned on, the lights come on. If they are not working it means that one of the bulbs needs replacing. If one bulb blows, neither light works. The bulbs are readily available from auto spare parts shops. See page 110 of your manual for instructions on how to replace the bulb.
Nov 07, 2010 | Husqvarna Designer I
Bernina 1230. Works fine except the two bulbs
Did more research and found the answer on a FREE site.
Nov 21, 2009 | Bernina Sewing Machines
Replacement bulb for a Necchi 537FA
it's the same size as a night light bulb. That's how I replaced mine. You can pick one up at any hardware or dept store.
Oct 31, 2009 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
161 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
