Question about Janome Memory Craft 4000 Sewing Machine
Replacing light bulb on mc4000 - Janome Memory Craft 4000 Sewing Machine
  • 323 Answers
Takes a special bulb which costs around $10 U.S. Easy to change Just pull out and reinsert in proper position.
Sewman7
Posted on May 13, 2008
Need the light bulb for the 6005 Elna. I've had this machine for many years and its been a real work horse, but now the light bulb has gone out in it.
Looking here, it looks like a capless bulb like in cars.
Lamp Socket Unit Elna 395723 43
In fact it is, a 12 volt 5 watt capless auto bulb
Changing the Light Bulb The sewing light is located behind the face plate. Unplug
the machine. Remove screw cap and screw. Pull away
face plate.
Pull out light socket. Pull out light bulb. Push in light bulb
with pins aligned to holes in light socket. Push in light
socket.
Replace face plate, screw and screw cap.
NOTE: Only use same type light bulb rated 12 Volts, 5
watts
6005 Elna light bulb Google Search
similar
ELNA 6200 Instruction Manual Changing The Light Bulb Feed Dog
Feb 05, 2018 | Sewing Machines
My new home mc4000 is only sewing in reverse
try turning the tension wheel in the center of the belt wheel. Have you changed belts recently. Also there should be 2 plugs for the machine motor, did these get switched?
Jul 29, 2017 | New Home Sewing Machines
I can't find a button to turn on the light on my Designer 1
There is no button to turn on the light. When the machine is turned on, the lights come on. If they are not working it means that one of the bulbs needs replacing. If one bulb blows, neither light works. The bulbs are readily available from auto spare parts shops. See page 110 of your manual for instructions on how to replace the bulb.
Nov 07, 2010 | Husqvarna Designer I
I need a replacement Foot F No 822804004 for my memory craft MC4000
try ebay as people often sell their spare feet when they upgrade
Sep 11, 2010 | Janome Memory Craft 4000 Sewing Machine
Bernina 1230. Works fine except the two bulbs
Did more research and found the answer on a FREE site.
Nov 21, 2009 | Bernina Sewing Machines
Can't figure out automatic buttonhole use on MC4000
2 things must do:
You have to use the buttonhole foot.
You have to pull down the lever to the lowest position (just left of needle bar/ presser bar up in machine.)
Set to buttonhole. After each buttonhole, be sure to change off the buttonhole then reset to buttonhole to reset the buttonhole to the beginning
Mar 15, 2009 | Janome Memory Craft 4000 Sewing Machine
Stops sewing
Sounds like the motor is stressing and a cut-off is operating to protect from overheating........ensure the bobbin area under the needle plate is clean and clear of lint, and that there is no thread jammed around in this area, also at the take-up arm and the cams at the far left of the upper shaftnear the needlearm.........if there is thread wrapped around anything, unwind it VERY CAREFULLY .....DO NOT pull and break it, be patient and move the handwheel gently in reverse while gripping the trapped thread, working it free slowly.
Of course it may be that the motor is old and needing a replacement, but as this machine is quite elderly and may have other complicating issues, you would be best to have someone take a look at it for the best decision of fix or replace, if it comes to that point.
May 13, 2008 | Janome Memory Craft 4000 Sewing Machine
How to put on presser foot "p" to embroider
Not shure you can embroider on an MC4000, i think this is only a sewingmachine.
But to change presser fot:
If it a "snap on" foot, when foot lifted, press the "button" on the back of the needle bar (on the bottom) this would release the presser foot.
If is a large foot, you have to unscrew the screw on the left side of the needlebar, and change the whole foot.
Jun 21, 2007 | Janome Memory Craft 4000 Sewing Machine
Sewing Machines Logo
319 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
