Question about Kitchen Ranges
GE Spectra XL 44 Gas Oven Bottom Heating
The Pilot (bottom) is not working of my oven, and I do not smell the gas either, I belive the gas auto-shuts down when the pilot is out of order.
Do you think i can fix myself or I need an expert help also where to get the pilot from.
my email is: fareedi@comcast.net
Wes Fareedi
I have the same problem; my GE XL44 Gas Range Oven does not work but the stove top does (I think its only 4-5 years old).
Can someone tell me why this happened? Please email me at r.mchale@comcast.net.
Should a service call be placed or is this an easy fix that I could take care of?
  • 4 more comments
  • Anonymous Apr 29, 2008
    Same exact problem for me
  • BDParker May 24, 2008
    Our GE XL44 oven stopped heating. the last few times it heated there was a very strong gas smell while heating up.
    Also, only 2 of our stove top elements will ignite.
    Can anyone offer help on these problems.
  • Brian In OC Aug 27, 2008
    My GE Gas Range problem: When the oven is COLD I have trouble getting it to turn up. According to the Owner's Manual, it states that the oven should ignite after 60 - 90 seconds. My oven takes several minutes...funny thing, though once it lights it will cycle on and off normally during the time I'm baking something. A couple of days later, when COLD, it has the same problem with the initial pre-heat. I can visually see the glow from the ignitor...could the problem be the safety valve (the electronic switch that directs the gas to either the broiler or the oven)? My next step, when the oven is COLD is to place a voltmeter across the leads: It appears to be a simple relay-type setup. If the est. 110 volts is there, I'll go ahead and order the safety valve.
    Brian
    a_surfbum@yahoo.com
  • Anonymous Nov 15, 2008
    The self cleaning portion slowly stopped working efficiently. Eventually, the oven stopped lighting at all. There is no smell of gas when I turn it on and it does not light, so I don't think I am getting any leakage.
  • pmb3823 Nov 15, 2008
    First the self cleaning potion stopped working efficiently. Eventually, the oven did not light at all. The stove top works fine.
  • cameronbarro Nov 30, 2008
    I used the overn this morning, but it stopped heating in the middle of baking. The gas on the stovetop works fine. Any ideas?
You will need a new heating element at the bottom. to find the part, go to ge's website and get the model #- you should be able to find it either online or a service center.
Posted on May 04, 2008
NO!!!!!! not ge . i have the same oven and called ge for the glow bar .....$85.00. got the same ge part out of a local appliance parts dealer for $50.00.
Posted on Jul 08, 2010
2 Suggested Answers
SOURCE: GE Spectra XL 44 Gas Oven Bottom Heating
My oven won,t light
Posted on Apr 21, 2008
I had problem with the GE Profile Spectra JGBP90 Gas Kitchen Range try to turn the stoe on , clicking noice but no flame. smell lots of gas. how can I light the pilot light back, where is it?
This range doesn't have a pilot,it has an electronic igniter. If you are smelling gas while trying to light, your igniter is bad and needs to be replaced. Remove the racks from the oven. Remove bottom panel in the oven. Remove the metal plate that covers the flame spreader. The igniter will now be visible. Try turning on the oven again. Take note of how bright the igniter gets. If it stays a orangish color it needs to be replaced. It needs to get to an almost bright white,
Feb 11, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Broiler works but oven does not ge xl 44 model JJBP24BEA2WH serial LV201917P Is this worth fixing?
Hello-  Yes if it's the igniter for the oven burner. The lower burner may light, but if igniter is bad, gas flow will not increase, causing under-temp condition. The part is available for 40-75$, and is fairly easy to install. Part is accessed by removing drip pan at bottom of oven. Gas ranges last longer than electric if the self-clean 'function' is avoided. Go ahead and fix it!  Let me know if this info helps-- have more if needed.   Thanks-  Ed
Mar 17, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE XL44 gas stove the oven will not stay lite why?
That's bad. Sounds like the burner is dirty.
and the gas belive it or not is blowing the polit out it hit it so fast. The gas can't go in the burner. There should be two screws that hold it in place take it off and clean. See if that will work. Let me know.
Ken
Sep 20, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra TrueTemp Oven Pilot is Out
REmove bottom panel from stove. shut gas off for at LEAST 5 min. Longer is better. Then placel open flame above gas nozzle, slowly turn to ignite posiiton. After it is lit, wait 30 seconds and turn to on positon.
If by chance this model doens't have a knob for this, then turn gas valve off for 5 min, let fumes evaporate, light flame, place over nozzle, turn gas on.replace bottom oven panel slowly.
Jan 18, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra XL 44 gas oven
If you can smell the gas when you turn on the oven, it may be on a separate igniter that has gone bad. I would check this first. If you are not getting gas to the oven, there is possibly an issue with the supply line.
Sep 25, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
Kitchen Ranges Logo
760 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
