My DTR freezes as soon as I do into the library. I have switched it off and left it but as soon as i go back to the library, it freezes again.
  • Anonymous Apr 28, 2008
    My DTR freezes as soon as I access the Library
  • 476 Answers
Could be caused by a corrupt file.
Look in the manual for a factory reset option.
This should solve the problem, but may erase the hard disk.
I would need the exact model number to assist further.
Posted on May 02, 2008
I blew #5 and #6 fuse under my hood. now my running lights stay on plus my overdrive light blinks and my transmission runs bad.
BJB ( aka Battery Junction Box , engine compartment fuse panel ) fuse #5 is for the trailer tow reversing lamp relay & the trailer tow running lamp relay. This is to the normally open contacts on those relays, which is the circuit to the 7 pin trailer tow adapter.
- Have you checked your 7 pin trailer tow adapter for metal left in there from a trailer plug ?
If you pull those 2 relays and replace fuse #5, does the fuse blow ? If so under what conditions ( i.e. when the headlamps are turned on, or when the truck is placed in reverse ) ?
BJB Fuse # 6 feeds the park lamp relay & the headlamp relay for the autolamp function. This could be where the lights staying on it coming from, but I would have guessed just the autolamp would have stopped working.
When the parking lamps are staying on, is this with the main headlamp switch in the auto position, or with the switch turned off.
The blinking OD light is the transmission reporting an error ( trans sensor issue or the actuator circuits have failed ).
The 1st place to check for this ( which is somewhat connected to the BJB Fuse #5 ) is the DTR ( Digital Transmission Range ) Sensor on the side of the transmission.
Could be the DTR connector is gummed up with road dirt, causing an issue. Part of the DTR is for starting ( Neutral or Park acts as a switch ) and part is the reverse ( again acting like a normal switch ) the other parts of the DTR feed information to the PCM for shift control and for 44 ( if the truck is a 4x4 ) for shift operation.
Start with the DTR on the side of the trans, unplug the connector and clean it with contact cleaner, and the check on the relays above.
Please report back your findings as a comment on this problem.
Thanks
Oct 27, 2010 | 2001 Ford F150 Styleside SuperCrew
Backup light problem
the sensor/switch is located on the transmission, it has 2 or more wires connected to it
Jul 04, 2010 | 1998 Ford F150 Regular Cab
My thomson dti 6300 250gb free view box wont turn on
Emailed Topuptv and got this reply
Dear Sir/Madam,
Thank you for contacting Top Up TV.
Please note that we are currently aware of an issue affecting some Thomson DTi6300 boxes.
If your DTR will not come out of standby and is not responding to your remote control, please try the following procedures.
Step 1: Power cycle
First of all, remove the power to the box and wait 20 seconds before restoring power.
Wait while the box tries to restart and allow 2 -3 minutes for this to complete.
Try this at least twice.
If it doesn't go to the solid green light then proceed to the next step.
Step 2: Front Panel Reset
Note: This procedure will unfortunately cause you to lose all of the recordings that you have stored on the box. You will need to be able access the back of the DTR and the front panel buttons
1. Remove power to the unit by removing the power cable from the back of the DTR.
2. Wait 20 seconds and restore the power cable while holding in the standby/power on button on the front panel of the DTR.
3. Release the standby button immediately you see a light 'blip' on the DTR front display and then immediately press the following front panel arrow buttons in sequence Up>Down>Left>Right
4.The DTR will now show the Orange LED with the Green LED flashing until the format has been completed in about 60 seconds. The DTR will return to ON automatically.
5. If requested, perform a channel scan to complete the operation.
We apologise for any inconvenience caused. Our Customer Services department can also be contacted on 08444 159 159. However, please note that we are currently experiencing high call volumes and so may not be able to answer your call as quickly as we would like.
Kind Regards,
Richard
May 04, 2009 | Televison & Video
Top up tv dtr box froze then staying on orange light, wont work
i had same problem today, it had locked up during deal/no deal
unplugged it three times nothing happened, wouldn't switch on
unplugged again left it for 5 minutes
then plugged in and left alone for 15mins plus
lights flasing then evetually green light went
all ok
May 03, 2009 | Televison & Video
Everything kept freezing-thomson dtr 160gb
tell them you need a new one. The one you have is faulty.
Jun 20, 2017 | Televison & Video
My thomson dtr
just found this solution and it worked for me ............. though it wiped the hard drive ............ basically restores to factory settings
turn all power off and back on again press stand by button repeatedly until flashing amber light is n constant them quickly press up down left right in that order as quick as you can .............
good luck
Nov 11, 2008 | Televison & Video
Problem with Thomson DTR DT16300-25 I have bought a DTR and I have programs stuck in the Program Library which I don't want and can't get rid of. If I try it hangs the DTR and I have to remove power to...
We've had the same problem with our Thomson DTR, but it was relatively simple to fix. Go to the menu by pressing MENU, then press 4 followed by 6. This will show the Help menu. Then, key in 1397 to enter 'engineer' mode, which contains several useful diagnostic functions. Scroll to item 7 (disable library video window) and toggle it to Yes by pressing the right directional button on the remote. After this, press Library, then delete the unwanted programmes.
It's very annoying, but hopefully the bug will be fixed when the next software update comes out.
Hope this has helped.
Oct 02, 2008 | Thomson Televison & Video
Frozen hard drive
If you have a Thomson DT16300, here's a handy fix that address freeze ups, lack of reception and problems on your Hard Disk:
goto MENU screen
goto SETUP screen
goto HELP screen
At HELP screen, Enter 1397 - this accesses the engineer panel - you can reformat the HDD in this menu - you will lose all recorded programmes and planned recordings but it clears locked or corrupted files
OR - at the HELP screen, press the GREEN button
On the lower half of the screen youwill see 3 options:
Blue - Reformat HDD - clears all the memory/HDD - useful if you have a corrupted file - you will lose all recorded programmes though
Red - reset the whole box to factory settings - good if you have a locked box or reception problems or cannto scan for new channels. It goes back to when you bought the box, so you will have to input favourites and planned recordings again
Yellow - Software revert - allows you to go back to the previous software driver - you may lose new functions, but you can always restore it back again using the same feature
Feb 15, 2008 | Thomson DPL909VD System
Philips freeview box DTR 220
Same problem with Channel 71 CBeebies. Tried rescanning which worked initially for a few weeks but it's back and rescanning does not fix the problem now.
Feb 14, 2008 | Televison & Video
Zen Micro
Sounds like it may be the index in your Music Library. Try going into Recovery Mode; remove battery, hold power switch to ON, replace battery, release power switch when the Recovery Mode screen appears on the screen. Run Option 1 CleanUP, after it completes run Option 4 Restart. You will get a Rebuilding Library screen when it reboots, that's normal, then it should go back to your startup screen. Good luck and let us know what happened
May 01, 2006 | Creative Labs Zen Micro MP3 Player
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
