Back to:
Tags:
Toshiba 50H72 50 in. Rear Projection Television
Toshiba p503sgf convergence reprogramming (by 3 users)
posted by twodope on Apr 28, 2008
i have a toshiba p503sgf rear projection arcade machine with a convergence problem. i have replaced the chips but the colours still are not converging (it looks like 3D without the glasses) i have been told it needs reprogramming but have not been told how to do so. can you help??
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Sep 26, 2008
Comment by lynnbux, posted on Sep 23, 2008
i have a modrl no 50 h13 and wwhen i first plug it in it looks 3d then its fixes itself with perfect picture for about 5 minutes then switches back to 3d and stays that way
Best Solution
posted on May 27, 2008
Thanks for Trying (70)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
si yo te puedo ayudar si todavia te interesa dimelo en larryalicate@hotmail.com
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on toshiba p503sgf convergence reprogramming:
I don't want to Accept this solution
Solution #2
posted on Aug 05, 2008
Not Rated (0)
jerems
Rating: 0%, 0 votes
Sell me the boards. Ill give $50 in present condition.
Thank You!
Can you Help with these Projection Televisions problems?
Toshiba 50H72 50 in. Rear Projection...
Once the TV is turned on, after 15 to 20 minutes the...
Bill, Saw a solution from you on the message board...
Do you know where I can obtain one of these?
Im having problems with the TV becoming clear it takes 15...
hello, I have a Toshiba 50h72 and I have had this problem...
Loading problems.
Repair Service
Find Projection TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
