Printing with Lipi 6306 Line Printer
I have installed a Lipi model 6306 on a LAN environment. The printer is shared. When printing is done using True Type or Printer Specific fonts through MS Word, the print quality is good but when the same document is converted to a pdf or printing is done through an application(developed in-house using java) the printer is not using the fonts specified or the print is missing some dots. The application specifies these parameters for printing - Font Face, Font Size, Regular/Bold/Italics/Underlined, based on the document template prepared using MS Word and the parameters being stored (for use by application) using a macro written in Visual Basic.
5 Suggested Answers
allanhunt
  • 135 Answers
SOURCE: DRIVER
Try this link:
http://www.liutilities.com/device-driver/tallygenicom-6306/
Posted on Mar 28, 2010
SOURCE: my lipi 6306 line printer showing error "paper
Dear Sir,
Problem in paper calibration, u can go through given details 1) Offline, Test, Daig, Calib, Paper out, Enter, then u see Remove paper. then press enter. sum reading will come (4.something). After insert paper, (2.something). And Save == Offline enter, config enter, configuration enter, save enter, Power up. enter.
Next option 2) U can check the paper out sensor front one black sticker missing.
Parashuram Patil
Posted on Jul 01, 2010
SOURCE: Lipi 6306 Line printer
i want to knwon the which operating system supports the lipi tally genicom line printer model 6306
Posted on Jul 12, 2010
  • 114 Answers
SOURCE: lipi 6306 lmp image problem solution
change the front style it may help you.
Posted on Jul 18, 2010
In Lipi 6306 line printer "Checksum fault block 8".It is not going on offline.What should I do now.I have not faced this type of problem before.
In Lipi 6306 line printer "Checksum fault block 8".It is not going on offline.What should I do now.I have not faced this type of problem before. os window xp
Aug 29, 2013 | Office Equipment & Supplies
How to print pdf document in lipi 6306 printer
It depends on what you mean by printing a PDF.
You can not "Direct Print" PDF documents on the 6306, you will need to pass the document through an appropriate printer driver / filter depending on the operating system used.
Simply sending a PDF document to the printer will not work
If you are using Windows simply print the PDF from Adobe Acrobat using the appropriate Windows Printer driver. If you can print a Windows Test Page, you should be able to print a PDF document- The quality of the print may not be of laser printer standard- Remember this is a Line Dot Matrix printer
Apr 03, 2013 | Tally 6312 Matrix Printer
Faulty Hammer voltage-2 earr
There is most likely a fault with one of the hammer coils, this would need investigating, other possible causes;Faulty / damaged ribbon cableFaulty main boardUpdate firmware, the error should change to a more meaningful error with later firmware
Dec 16, 2011 | Tally 6306 Matrix Printer
Will lipi t6050 work with windows xp
how to solve technicle problem in lipi line printer 6306
Dec 03, 2010 | Tally Line Matrix T6050 Printer
The 6306 L showing HAMMER VOLTAGE 1 ERROR WHAT SHOULD I DO
ERROR IS BECAUSE OF DRIVER IC FAULTY IN LOGIC CARD
PLZ CHANGE THE HAMMER DRIVER IC IN LOGIC CARD
Dec 13, 2009 | Tally 6306 Matrix Printer
Oct 16, 2008 | Office Equipment & Supplies
429 people viewed this question
jasbo
jasbo
