Sharper Image Ionic Breeze GP SI720 Air Purifier Logo
Posted on Aug 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need users manual - Sharper Image Ionic Breeze GP SI720 Air Purifier
Ginko
Level 3:
  • Master 19,396 Answers
  • Posted on Sep 24, 2010
Ginko
Master
Level 3:
Answers
19396
Questions
25
Helped
8076804
Points
55462
Hi.
Here the user manual: SI720 IM.
I wanted to point out that there is an healt concern related to older sharper image products, and to ionic purifiers in general, please check online if your model is involved, pre-2007 models are generally involved.
Regards.
How do I remove the filter
Lancaster air purifiers can have different models and designs, so the exact location and method for removing the filter may vary. However, I can provide you with some general guidance that should help you locate and remove the filter in most air purifiers.
1. Check the user manual: The first step is to consult the user manual that came with the air purifier. It typically contains specific instructions on how to access and replace the filter. If you don't have the manual, you can often find it online on the manufacturer's website.
2. Look for a filter compartment: Most air purifiers have a designated compartment or access panel where the filter is located. It may be on the back, side, or front of the unit. Examine the air purifier and look for any labeled panels or compartments that indicate the filter's location.
3. Remove the filter cover: Once you've located the filter compartment, you'll need to remove the cover or panel to access the filter. The cover may be secured with screws, clips, or latches. Use a screwdriver or your hands to undo the fasteners and carefully remove the cover.
4. Take out the filter: After removing the cover, you should see the filter inside. Depending on the model, the filter may be a single unit or consist of multiple layers. Take note of how the filter is positioned before removing it to ensure you can correctly replace it later.
5. Follow any additional instructions: Some air purifiers have specific instructions for removing the filter, such as pressing a release button or sliding it out from a designated slot. Refer to the user manual or any labels on the unit for any additional guidance.
6. Clean or replace the filter: Once the filter is removed, you can determine whether it needs cleaning or replacement. If it's a reusable filter, check the manufacturer's instructions on how to clean it properly. For disposable filters, it's generally recommended to replace them according to the manufacturer's guidelines.
Remember to consult the specific user manual for your Lancaster air purifier model to get accurate instructions tailored to your device.
Red light in on my purifier an how to fix
As errors and fixes vary by brand at least and sometimes by model as well, that minimum information is posted with a query. On some models, it would mean that the filter needs replacement, that its filtration ability had fallen below an acceptable threshold. On others, it would mean that pollution has been detected. The user manual should indicate what it means. Possibly, you might find information at the brand site or at a user manual site or just by Googling "brand model air purifier red light"
Need a user manual for a Whirlpool AP35030HO Air Purifer
Go to the manufacturer's website and search the website for the manual. Or you can go to google and search, "Whirlpool AP35030HO Air Purifer manual."
Looking for the user manual on this unit. Just
After over 1 hour on some very un-user friendly websites I was finally able to find your manual here:
http://hepafiltersales.com/mm5/graphics/hfs/Manufacturers/Honeywell/Honeywell_air_cleaner_F200.pdf
For some strange reason it was filed under "Product Data Sheets"
Thanks for using FixYa.
Kelly
3helpful
Unable to locate user manual for EcoQuest Breeze AT
I have a user manual in pdf. I can send it to you if you email me at stevelam (at) ecobusiness.com.
Programing
Here is the link to the user manual; http://www.filterqueen.com/pdf/defender.pdf Hope this helps :)
Top Sharper Image Air Purifiers Experts
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
