Question about LG LRBN22514ST Bottom Freezer Refrigerator
Problem with GL-T 242 QM LG Fridge
When fridge will on it works only 5minutes then it will stop automatically and light is continusaly running. and fridge will not cold.my fridge Model No. is GL-T 242 QM. what is problem? i don't know, plz suggest me.
thanking you,
Custmor
  • mgrant91789 Apr 15, 2009
    The bottom freezer seems to work. The top constantly goes off. If we unplug it resets and goes back on. Then it is only on for a few minutes before it goes off again.
Pull out the freezer and ckeck for ice build up on the back. Unplug and defrost the freezer for 3-4 hours - leave the freezer door open. There may be ice covering the vents to the fridge.
Posted on Mar 14, 2009
LG Fridge not cooling refrigerator (freezer is fine, fan is running)
those sensors do fail but if the freezer is not as cold as it should be .then the refrigerator part will also not get proper cooling . TEST the freezer temp .
Sep 25, 2015 | LG Refrigerators
Fridge not working freezer does
I had a similar problem. Don't know your brand. Try this:
1. turn off power.
2. thoroughly clean/vaccum underneath and behind the fridge
3. start power and change all settings to zero until you stop hearing any humming sound.
4. activate settings and fridge and freezer will start. GL
Feb 06, 2014 | Refrigerators
LG Fridge-Freezer model no. GR-T632DVQ The upper freezer lights works. The lower fridge light stopped working. When tested the light bulb works and is NOT broken. There is a combination double...
looking for a door for lg refrigerator GR-T632DVQ
if anyone can help me plz ring 0421203100
perfect fridge, had it for 10 years, door fell off today :(
i've been searching everywhere, *sigh
please help if u can
Mar 16, 2011 | Refrigerators
Fridge not making usual humming sound
I had a same problem, However the fan in the freezer seems stop and the freezer compartment is melting. Its a double door LG with 270 ltrs.
Mar 11, 2010 | LG LRTBC1825T Top Freezer Refrigerator
Our LG GR359SQ Fridge Freezer, the fridge has stopped cooling. Everything else seems to still work, freezer, lights etc. But the fridge is warm. Any thoughts?
Make sure the the evaporator fan is running and circulation is getting to the fridge side. Remove anything that could be blocking the vent that brings in the air from the freezer to the fridge. Make sure that no frost is building up in the back of the freezer. If there is frost, then the timer can be going bad.
Jul 12, 2009 | Refrigerators
My fridge clicks off when i plug it in
It is serious take the refrigerator back, get a different on. Thanks, Sea Breeze
Mar 20, 2009 | True GDM-26 Refrigerator
Fridge not cooling
You most likely have a thermistor that needs replacing. Can you tell me the the temp. in the fridge? Most LG fridges have a 1 year warranty with extended warranty on some parts. If you could provide the model #, I can look into it further for you.
Feb 03, 2009 | Refrigerators
Bottom refrigerator not cooling
The defroster timer, or the defrost element could be out. Also the blower motor in the freezer could be locked up. If you can hear the blower its likely the timer or the element.
Mar 11, 2008 | Freezers
Fridge is not cold but the light will turn on...
if its a fridge freezer fully defrost it 48hrs
Feb 07, 2008 | Freezers
LG fridge suddenly stopped cooling.
If the fan inside the freezer is running and the compressor behind the fridge is running and is hot to touch, you have a gas problem or the compressor is inefficient. This can only be confirmed by connecting refrigeration gauges to the gas system and should only be performed by a fridge tech.
Nov 04, 2007 | Refrigerators
LG LRBN22514ST Bottom Freezer Refrigerator Logo
576 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
