Question about HP Color LaserJet 2600n Printer
Lines on print page
I get three lines all the way down the page on all pages I print I have tried the cleaning function but hasn't worked
  • Anonymous Jun 03, 2008
    two to three lines in color print on the left side of the page when printing in black and white. Cleaning does not seem to help.
  • 300 Answers
This is normally either a print cartridge or the transfer belt. You can normally see the defect on the faulty unit (these units are light sensitive)
Posted on May 16, 2008
X2250 won't print form pc
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
May 01, 2013 | Lexmark X2250 All-In-One InkJet Printer
Savin 9935DPE is printing one thick vertical balck line down the copy or print pages. About 2 of every 3 pages printed. What's wrong?
are you printing from Doc feeder or glas?? if from feeder then try to make a copy from the glass, does it still do it? yes problem is with drum.
No? problem is with the small scanning glass to the left, look carefully see if any spots or lines on the 1inch glas --- clean it
Sep 05, 2012 | Savin 9945dpe 9935dpe 2035dpe 2045dpe...
The print is faded . ther are three color bar missing on the test page ( yellow, black , and black).
Hi
Go into Maintenance in the Kodak Printer Management Program and try the Nozzle Check and Head Cleaning functions until the Test page prints clearly.
Head Cleaning might be necessary after every cartridge change.
I hope this helps.
Aug 26, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Brother MFC-6800 1. Prints with 3/8" blank vertical line down the entire page; 2. Prints with a couple of 1/16" blank vertical lines down the entire page; 3. Prints with some gray shadow...
This solution is unconventional but it worked for me. The black roller on my MFC had irregularities on it and was creating horrible printouts. I pulled out the drum and cartridge and cleaned the large black roller. I used furniture polish to make the roller very smooth. Now it prints really nice.
Nov 29, 2010 | Brother MFC 6800 All-In-One Laser Printer
Lines on print. There's are three lines on picture print only. Can't see the line on document. It's about 1/4 inch wide and going throught top to bottom.
Have ou gone into your menus. Into troubleshooting, then image quality.
You will want to run both the eliminate light stripes and eliminate smears procedures. that will purge the print head, blow air through the jets and hopefully resolve the problem. I do believe the 8550 has a Jet Substitutin procedure where you can do a workaround and make other jets make up for the light areas.
here are some directions, Will forward more
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Troubleshooting Print Quality Page], and then press the [OK] button.
  4. Evaluate the 'Light Stripes Test' page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. The 'Light Stripes Test' page is the last page of the Troubleshooting Print Quality Page that printed.
    WARNING: To avoid injury, do not touch the sharp metal strip attached to the clear rubber wiper blade in the Maintenance Kit.
  5. Use a clean lint-free cloth or a new paper coffee filter to gently clean the maintenance unit's clear rubber wiper blade, use only a wiping motion across the entire length of the wiper blade, and then empty the waste tray. A dirty maintenance kit wiper blade can cause white lines and weak or missing printhead jets.
  7. Repeat step 3 to reprint the Troubleshooting Print Quality Pages. If there are no missing or partially missing color bars then the print quality problem has been resolved. If there are missing or partially missing color bars then the printhead cleaning procedure will need to be performed. Continue with the next section.
To clean the printhead using the basic eliminate light stripes procedure:
  3. Press the [Up] or [Down] arrow button to select [Eliminate Light Stripes], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Basic], and then press the [OK] button. The printer will perform a head cleaning, which will take about five minutes. The printer will then print a cleaning page and a light stripes test page.
  5. Repeat steps 1 - 4 one more time. If there are no weak or missing jets then the print quality problem has been resolved. If there are still weak or missing jets after two basic light stripe cleanings, continue with step 6.
    NOTE: Do not try the Advanced Eliminate Light Stripes Cleaning mode without performing two basic cleanings first.
    To clean the printhead using the advanced eliminate light stripes procedure:
  6. Press the [Up] or [Down] arrow button to select [Advanced], and then press the [OK] button.
  7. Select the missing jet color and number. If necessary, check the light stripes test page to determine the color and jet number of the missing jet.
    NOTE: Only perform the advanced light stripe cleaning once. If weak or missing jets still persist, continue with step 8.
  8. Print the Troubleshooting Print Quality Page. Evaluate the Light Stripes Test page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. If necessary, perform the basic eliminate light stripes procedure one more time. If the Advanced Eliminate Light Stripes procedure does not resolve the weak or missing jets, perform the Enable Jet Substitution Mode. See the Related Items below.
Feb 05, 2010 | Xerox Phaser 8550DP Printer
After changing printer cartridge, all printed pages have 3 black horizontal lines across the page about an inch apart.
It sounds to me that you need to run the clean print cartridges utility.
  1. Press the Setup button.
  2. Use the arrow keys to select Tools and then press the OK button.
  3. Select Clean Print Cartridge and then press OK . The device prints a test page.
  4. Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.
    1. Open the Printer Toolbox . There are two ways to do this:
    1. Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon.
    1. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
    2. If above does not work, then remove the black cartridge, and olace it upside down in an area it won't be disturbed for an hour, then place it back in the printer, and print a test page. (This only applies to black cartridges)
    Oct 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
    A line appears down the length of the page on all copies, printing and scanning. How do I get rid of the line?
    All you need to do is clean the top feeder which opens into two parts. make sure you clean the black rollers as well as the small strip of glass you will find when you open the second part of the top feeder . don't be afraid to pull open the top feeder it won't break
    Jun 01, 2009 | HP OfficeJet 9130 All-In-One Thermal...
    HPdeskjet 990cxi printing lines on images
    have you selected best quality in page setup>printer>properties>quality/paper hope this helps regards Jim
    Nov 24, 2008 | HP DeskJet 990cxi InkJet Printer
    HP Deskjet F380 won't print
    i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
    try to clean manually the printer by using powerful air blower,repeatedly.
    Sep 14, 2008 | HP DeskJet F380 All-In-One Printer
    HP Color LaserJet 2600n Printer Logo
    148 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
