Question about Alcatel Newbridge MainStreet 3612 Multiplexer
Newbridge 3612 We are moving Telecomm equipment and the Newbrige 3612 is one of them. I need to know if it will stand shut down time without any troubles like losing the programming setup. Regards, Intisar
Yes, you can shut down and relocate with no adverse affects.
Posted on Aug 04, 2008
I dont have a problem. I just wanna know how Newbridge 3600 series multiplexer help me extend telephone lines to a remote areas like Oil & Gas Pump Stations. I have STM 64 mux used as a backbone. So...
Hi Berido, you can extend telephone lines over the 3600 by using LGE and LGS cards fitted with a ringer PSU in the 3600 at the end point, works well, for more info send me a mail, lenconradie@yahoo.com
Sep 08, 2011 | Alcatel Newbridge MainStreet 3600...
We connect 8 analog lines to a 3612 on one end compressed lines to 16 k each accross a data circuit then break them back out on a 3612 on far end. Calls will be up for a minute or 2 then drop. Call...
There are many reasons why the call will be dropped. The call will be dropped when you aggregate link between the nodes fails, if this is not the case monitor the connections on the node and see if the connections stays up. If I would guess it could be the PABX that is dropping the calls and not the nodes.
May 23, 2011 | Alcatel Newbridge MainStreet 3600...
Runs without plugwires on shuts off when you put it in gear
Your cycle runs when you pull off one spark plug wire per cylinder. There are two spark plugs per cylinder and you did not remove both . Therefore you still have one spark plug on each cylinder firing to run the machine. Your motorcycle is also equipped with a side stand safety switch. Your bike will run on the side stand . But, if you put the bike in gear with the side stand down it is designed to turn off the motor. This is so you do not drive away with the stand down and loose control of the motorcycle on your first left hand turn. Get in the habit of putting your side stand up before putting the bike in gear and your problem is solved. Read your owners manual.
Oct 16, 2010 | 2003 Honda VT 750 C2 Shadow
My kawasaki gpz 600r cuts out when i try to move off in first gear. Is the some sort of safety cut out making it do this? it starts fine and runs fine but will not move.
It sounds like the kick stand switch is not working or working real good. Did you mess with the switch? Or did you buy it like that? Somebody messed with and did it wrong. When the kick stand is down, the bike goes in gear it shuts off, That is how it is supposed to work. Mine was wired up and you would not believe how many times I took off with the stand down and almost killed myself. I got a new bike and left the switch alone. I know they make special switches for the wires to be cut and relocated, I don't know if you can find one on ebay or not, but I would get under there and check to see if any wires are hanging down. Hope this helps.
May 12, 2010 | 1987 kawasaki GPZ 500 S - GPX 500 R
Need 3612 mainstreet J8 pinout configurations DB9 to RJ45
DB9 -----------------------------------> RJ45 1 ---------------------------------------> 8 2 ---------------------------------------> 4 3 ---------------------------------------> 3 4 ---------------------------------------> 7 5 ---------------------------------------> 5 6 ---------------------------------------> 6 7 ---------------------------------------> 1 8 ---------------------------------------> 2 9 ---------------------------------------> NC
If not work, invert the RJ45 connector
Mar 03, 2010 | Alcatel Newbridge MainStreet 3612...
Brother MFC-685cw stuck shutting down/standing by
Hold down that on/off button for at least 10 seconds without pushing any other buttons, wait after you release it and it should either wake up or shut down.
Aug 26, 2009 | Brother MFC-685cw InkJet Printer
No connect to rs232 serial, ports PC
df1c50d.png This is for a newbridge or alcatel 3624 mainstreet channelbank - do not use the modem side, only use the terminal side - all is needed is Rx, Tx, and ground - if looking from the "window" side of rj45 connector, or pins-side up on rj45 socket.
Aug 18, 2009 | Alcatel Newbridge MainStreet 3600...
I need the pinout for the serial cable? RJ45 to DB9
f211598.png This is for a newbridge or alcatel 3624 mainstreet channelbank - do not use the modem side, only use the terminal side - all is needed is Rx, Tx, and ground - if looking from the "window" side of rj45 connector, or pins-side up on rj45 socket.
Aug 03, 2009 | Alcatel Newbridge MainStreet 3612...
Alcatel Mainstreet 3600 Anphenol PINOUT
You must have a Dual E1 card that support a 120 ohm interface. There are cards for 75 and there are cards for 120 ohm. Sergio - Argentina
Apr 04, 2007 | Alcatel Newbridge MainStreet 3600...
Alcatel Newbridge MainStreet 3612 Multiplexer Logo
218 people viewed this question
Top Alcatel Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
