The E 602- 003 is due to hard disk system error but you can scan it ;run check disk its can fix that problem.
try this, hold on 1 and 9 (from the machine key board) then switch on the copier;
then wait around 1 hour all screen will be white then the copier will display download mode. then switch off and put on the copier.
602 is a microprocessor and/or a programming issue with the PCM. 700 is a generic code for a transmission problem. This one could be caused by the 602 code. Basically to fix this, you have to have the PCM reprogrammed first, then if the code comes up again, the PCM has to be replaced and programmed to your truck. Then if you still have a transmission code, it will have to be addressed. Shop shops can do this work. Much cheaper than a dealer.
Your product is not identified by number given. Leviton posts manuals online by searching Leviton xxxx .pdf. There is a CPT 602 lighting console However no result shows online or at Leviton for a 602 dimmer Contact Leviton: http://www.leviton.com/OA_HTML/SectionDisplay.jsp?section=37579&minisite=10251 Add a comment and attach photo or video for possible identification
he E 602- 003 is due to hard disk system error but you can scan it ;run check disk its can fix that problem. try this,
hold on 1 and 9 (from the machine key board) then switch on the copier; then wait arround 1 hour all sceer will be white then the copier will display download mode. then switch off and put on the copier.
