Question about Microsoft Windows XP Home Edition
Problem w/ WIN2000 Pro & XP Pro
When trying to install a newly created CD on WIN Pro and XP-Pro, keep getting message "cannot find oc25.dll". No problem using Win98, ME, or XP- Home Edition. Copied the dll to the system32 folder and tried again. It would load - unacceptably slow - then, when trying to navitage would hang up. Does anyone have a solution? thanks operating programes in italian language
    President:
  • 1,257 Answers
HERE IS THE SOLUTION :
click on the link given below and find oc25.dll....if you are unable to find press keyboard key cntrl + f .A dialog box will appear now type oc25.dll and hit find key and you will find the oc25.dll .click on that file to download it to your computer.
http://www.dlldump.com/dll-files/O_2.html
Once you have downloaded the file you are looking for you still need to make sure Windows or the program causing the error can find it. Follow these steps:
1. If you are encountering an error with Windows...
The file you downloaded needs to be placed into the Windows System directory. On most machines this is one of the following locations:
C:\Windows\System (Windows 95/98/Me),
C:\WINNT\System32 (Windows NT/2000), or
C:\Windows\System32 (Windows XP).
If you are encountering an error with a particular program...
The file most likely needs to be in this program's directory. This directory is where the program is installed (i.e. c:\Program Files\ThisProgram).
If this step solves the problem, you do not need to complete step 2.
2. You may to register this file with Windows. Click on the Start Menu and then on 'Run'. If you are replacing a Windows system file, type the following command:
regsvr32 \windows\system\file.dll (Windows 95/98/ME),
regsvr32 \WINNT\system32\file.dll (Windows NT/2000), or
regsvr32 \windows\system32\file.dll (Windows XP).
For example, 'regsvr32 \windows\system\apphelp.dll'
If you are replacing a file for another program, change the directory where appropriate. For example, 'regsvr32 \program files\Norton\xyz.dll'
If the file is registered correctly, you will receive a positive confirmation message.
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Posted on Apr 28, 2008
Aspire One netbook BSoD
Those error codes don't really mean very much to the general consumer, but blue screens of deaths are caused by bad RAM memory in your computer, not viruses. I'm going to take a guess that your computer is either several years old and/or it constantly get quite warm? Heat can shorten the life of computer components by quite a bit. You may need to get one of your RAM cards replaced to solve this issue.
There's a free program called Memtest86 that you can run to determine if this is the case. It will scan all your memory and look for bad sectors. You can download it here: http://www.memtest86.com/ and burn it to a CD. What it does is create a bootable CD that will execute the program as the computer turns on to scan all the memory. There are full instructions on their website. The process can take an hour or two depending on how much memory your computer has, and if it turns up any bad sectors then you know what your problem is.
A computer can run with bad sectors in the memory, but it makes it unstable that it will keep bluescreening, so if you have bad sectors in your memory it might be better just to replace the RAM. Luckily, this isn't too expensive. For instance, if your computer has 4GB of memory, it probably has 2 2GB RAM cards installed. You can get a 2GB replacement notebook memory for, I'd say $30 or $40. Installing RAM is very simple, and if you're willing to install it yourself, it won't cost you more than that.
Dec 06, 2012 | Acer Aspire One Netbook 8.9" Notebook
WINDOWS ERROR MESSAGE
boot from the CD copy of your windows XP. enter in console session and manually replace the file. if the file is corrupted this should fix it
Feb 26, 2012 | Gateway GT5026E PC Desktop
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Mustek "BearPaw 1200CS Scanner. Micro-star international MS-7222 2.00 Desktop PC newly aquired. Running Windows XP Professional SP 3 Problem:- Installing Scanner from disk fails with message "cannot...
Maybe you are not following the official instructions properly?
Please visit this link to download the latest driver and this link to view correct install instructions.
If this does not solve your problem, do as follows:
Create a new account with administrator rights from the XP control panel.
Log on to this new account and try to install the scanner again.
I am waiting for your reply.
Oct 15, 2009 | Computers & Internet
How to repair workstation, os are win2000 pro in workstation
do you want to reactivate the win220 pro installation on the harddisk which now you cannot access?
insert win xp pro install cd and run the repair process
or
if you have partioned the harddisk, simply do a new install on another partition, mark this active and now you should be able to boot up and access the old installation.
copy the non-microsoft programs plus personal data (everything that is not in the windows folder) to the new installation,
then run every single program from the new installation
good luck
Apr 18, 2009 | Computers & Internet
Been having this problem for 2 months.. computer is turned off... have been rebooting from CD in drive for 1 year... harddrive tired and cannot boot up by itself... lately cannot get to any Recovery mode,...
If you have a Windows XP CD, follow these steps.
1. Boot from the CD and start the installer
2. Choose to install onto the already formatted partition with the unbootable Windows, but opt to leave the existing filesystem and any other OSes alone. Choosing this will require you to create another folder for Windows to avoid writing over the existing installation. I usually call the new folder "WINXP."
3. Install Windows as you would normally, you'll need a Product Key but you can actually use your personal key on someone else's computer with no danger to you losing it or being accused of piracy, I'll explain this later.
4. Boot the NEW Windows XP install. Do not "Activate" or "register," you're going to be deleting this copy of Windows from the machine if all goes well.
5. Edit the BOOT.INI on the hard drive from the original installation of Windows with the corrupted HAL. This file should be in C:\ (may be hidden)
Sample BOOT.INI for XP Pro
Microsoft wrote:[boot loader]
timeout=10
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /NOEXECUTE=OPTIN /FASTDETECT
6. Go to C:\WINXP\system32\hal.dll (where "WINXP" is the folder you installed the second copy of Windows XP) and copy it from the new Windows to C:\WINDOWS\system32\hal.dll (or wherever you installed Windows XP originally, I use "WINDOWS" but some people use strange folder names for their XP) and overwrite any file there. The new hal.dll is uncorrupt and newly regenerated. The file is specific to each machine's hardware configuration and we needed to rebuild it. The installer did that for us with the new installation.
7. Try rebooting your computer to see if you can get into your OLD Windows installation. If you can, congratulations!
8. DELETE the "WINXP" folder (or wherever you put your new Windows install).
PS: Please rate this solution
Mar 11, 2009 | Computers & Internet
I have dual boot 98SE/XP-Pro in same disk partition which got virus attack. In order to fix problem (long story), I had to remove and re-install the XP-Pro OS. Unfortunately I deleted the XP system from...
Why would you torture yourself with that old thing?  Yeah, you can create more boot script lines...they should designate the proper root for the second volume and that ought to fix any missing file issues if indeed ICG32.dll and company are where they started....
Jul 22, 2008 | Computers & Internet
Can not install win xp on MS9158E MATSONIC motherboard
Dear Sir/Madam,
I install the winxp in MS9158E matsonic motherboard and after installation sound card not working. Mean sound not coming and i search the drivers from website but i didn't found the sound driver from web. So, I request you to please help me for download the driver for specific motherboard.
Jan 17, 2008 | Matsonic MS9158E+ Motherboard
Microsoft Windows XP Home Edition Logo
167 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
