Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
New printer set up
Printer keeps saying.printerhead missing or not installed correctly ,we have reinstalled several times as per user,s guide several times but still not working please help
  • 779241 Apr 29, 2008
    i've already reinstalled the printhead and ink cartridges several times, and the lcd screen keeps telling me there is still an error.
  • Anonymous Mar 21, 2014
    WILL NOT get beyond this point even though I have followed the directions correctly SEVERAL times. Code 3513
Rang kodak direct there is a falt with a part of the printer so they are sending a replacment as it is still under garantee .lets hope this works.
Posted on May 02, 2008
How do I change/clean the printer head
It sounds to me like it would be cheaper to just replace the printer. if you don't hardly do any printing then a cheap wal-mart printer for around 30 dollars is what you need. if you printer all the time then you need a laser printer and they run between 200 to 600 dollars and can pick one up at Sams club or a office supply store like Office Max or Office Deport. You might also check Kmart. Most people don't realize that they sell printers too.
Dec 30, 2014 | Office Equipment & Supplies
My kodak esp 6100 keeps on showing error code 3806?
Disconnect power cord, let it set 30 sec, reinstall cord. If problem still there pull out the printheads and reinstall, may have to do this a few times, if problem still there may need printheads.
May 07, 2014 | Kodak Office Equipment & Supplies
Printerhead missing
Make sure you inserted the correct cartridge and you inserted it correct. Also check is all contacts on the cartridge and in the printer are clean and shiny. Did you remove all plastic, of the package, as described?
Just one speck of dust, a almost invisible small piece of peper or plastic can spoil al the fun.
Feb 17, 2014 | HP Photosmart 7520
My esp 3 kodak printer now has a printerhead problem after a year of use. When the printer does it's power up check I get a error with the ink cartridges indicator light lit up. When I remove the ink...
Your printer needs a service, in other words the waste ink sponges need to be cleaned and dried. They then need to be replaced and the printer reassembled. Then the Epson counter resetting software needs to be installed.
With this software the printer can be set to zero, it will work perfectly after this bit of attention.
It is a good printer, it's nothing that can't be repaired.
A computer technician will be more than happy to service your printer for you.
All the best!
damnor01
Feb 01, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I insert ink cassete into it"s selphy cp780 photo
Go to section on Error Messages at page 32 of the User Guide found at:
http://gdlp01.c-wss.com/gds/0/0300002060/02/SELPHYCP780_PUG_EN_03.pdf
It will tell you to remove and reinstall the ink cassette. Try this and make sure you install correctly as per instructions on page 11 of the User Guide.
If this does not resolve the problem, do a complete power down of the printer. Turn off and unplug from the power supply. Lets rest fro a few minutes and then plug back in to the power supply and if necessary turn on power. This should allow your printer to reset and hopefully recognize that a new ink cassette has been installed.
Trust this helps. Please vote. :)
Dec 17, 2010 | Canon Office Equipment & Supplies
I keep getting a Printhead missing, not installed correctly or has come loose error. I have tried reinstalling the print head, several times and powering off several times but neither help. Any...
HTML clipboardHi
Here are a few possibilities...
1. Try cleaning the contacts on the print head and where they make contact inside the printer. (use cotton wool and Alchol) if that does not work...
2. Pull out power cable from printer wait 1 MINUTE then insert cable and switch back on again. (some printers reset to factory settings)
3. Remove printer cable from computer... Uninstall Printer driver from computer... Switch off both printer and computer. Wait 1 minute... Reconnect cables and switch on printer and computer... Allow computer to find printer... reinstall driver.
Good Luck!
Tinteiros Magic Inkjet Flush Kits (Ebay)
Sep 12, 2009 | Kodak ESP 5 Printer
Error message: Printhead missing, not installed correctly or has come loose
In regards to the error message with the printhead missing or come loose......I had that issue just shortly after I installed my printer. I was going crazy trying to fix it taking it out and reinstalling which was a pain, removing the cartridges and then the printhead to no avail. Finally I got smart and disconnected the power cord from the printer itself, not directly from the outlet. Once I did that and turned the printer back on the error was gone. It might have been a fluke, but it worked for me, so you might want to try it.
Jul 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
I just bought a new Lexmark x3550 inkjet printer. i install all required drivers for the printer from given installation CD. but when i try to print from any document it gives an error "Problme having...
Hello, are you sure it installed correctly. It sounds like it definitely cannot communjcate with pc. First try making sure in the settings drop down menu of your printer window in pc, make sure work offline selection is not checked. This often disables printer printing from pc. Check all settings as well. If this does not help i suggest completely uninstalling it and reinstalling it as well. Also, check to see this printer has driver for your windows and pc specifics. Even brand new printers can need updated drivers as the time they are manufactured and the time they are sold, can be a big time gap and new windows service packs and OS can come into play and need new drivers.
Apr 26, 2008 | Office Equipment & Supplies
Colour printing
Is by any chance a third party cartridge?
Jan 13, 2008 | Office Equipment & Supplies
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
