Question about Vacuums
Hose connection broken. - Vacuums
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=552957
Generic problem for all Vacuums
Posted by nualaheaneyi on Apr 28, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
If you have a broken hose connection, and not knowing the brand name of the vacuum, I can suggest 2 things. If you have an electric hose, meaning that it is attached to a electric power head or power nozzle, some can be repaired depending on what was wrong, but most of the time you have to replace the hose, some pigtails can be replaced but if the electric connection is broken, you need to replace the hose. If it is a non-electric hose, you can use a shrink tube, or cut out the broken part and use a hose cuff to join them together, so just shorten the hose and screw back on the original ends. In either case you need to check with a local vac dealer. Or you can make a new hose with new ends and leave the canister @ the bottom of the stairs and go up with just the long hose, unless you have an upright then you have to make it the length that is on the upright. Or replace it with the genuine hose from the factory or use the ends from the old hose on the replacement hose. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 28, 2008
I have an electrolux twinclean with a power head. The connection between the hose and the power head does not hold the hose together, it just falls apart.I think there is a clip of some kind missing. Your help will be greately appreciated. Mary Cameron
Posted on Sep 06, 2011
Top coupler on gas pump handle ONLY (Majestic 360 SS) is broken. Do we have to replace whole hose and handle assembly?
They now make a replacement tab so you don't have to replace the entire handle grip. The bad part is, most of the time it's the handle grip that has the broken place in the plastic, not the latch tab. That too can be bought seperately though, so you don't have to buy the hose. Call your local vac shop for assistance.
Oct 21, 2014 | Filter Queen Majestic Canister Vacuum
How can I repair? The power nozzle N109J is not operating, but the handle can turn the vacuum on/off and there is plenty of suction. Is it possible the electric connection in the handle is broken?
Yes,also try checking the connection from the hose to vacuum.Make sure hose is in vacuum port properly.To test this just wiggle the hose end up and down with machine running.It the problem is there the head should start intermittently.If not get back to me with more info.hope this helps,it is a fraustrating but fixable problem. Chris
Aug 16, 2014 | Electrolux Vacuums
The hose to handle connection has a broken clip. Is a new hose the solution?
Just epoxy or tape it. Joking. Can you replace the clip or substitute a different kind of clip?
Oct 14, 2013 | Dyson DC25 Vacuum
Hoover steam vac hose is broken
This applies to Hoover SteamVac model F5899-910.
My unit had a broken hose. I repaired the hose using duct tape and Teflon tape. The breakage seems to be due to a manufacturing error or design defect. The hose is clamped to the unit where it passes to the inside. The position of the clamp did not allow enough slack when the handle is released and the unit is wide open.
The hose coupling has a plastic latch that holds it onto the vacuum nipple. Pry it and remove the coupling. Then trim the ragged end of the hose and clean things up. Wrap the hose with some teflon tape and then tape the hose to the coupling with several turns of duct tape. Attach the hose coupling back onto the vacuum nipple.
Now you should move the clamp say an inch, so that it leaves more slack. Take the two screws out of the clamp and pry out the plastic bracket/cover that holds the clamp in place. Then move the clamp and screw the clamp back onto the bracket/cover. Then snap the bracket/cover back in place.
Take care not to put too much slack in the hose (by moving the clamp too far), as the hose can also bunch up due to being too crowded when the handle is upright.
Inspect the hose and the tape whenever you use it.
Aug 03, 2012 | Hoover F5899-910 SteamVac Vacuum
My vac will turn on at the unit but will not come on when I insert the hose into any wall outlet
The problem is one of two things...either the hose part is bad or the wiring to the unit is bad....all that needs to happen to make the unit come on is to short between (connect) the two wires going to the unit. Therefore if the hose part is not connecting the two wires, or if the wires are broken somewhere going to the unit it will not turn on with the hose. I would take apart one of the wall outlets and jumper the wires to make sure that the wiring to the unit is good. If that does not work, then start checking for a break in the wiring to the unit. My feeling is that the hose part is probably bad and it is not making the connection in there properly and therefore not turning on the unit.
Feb 04, 2012 | M&S Systems Vacuums
I have a CT600 power brush that would not power up. Thinking the motor was bad in it, I replaced it with a new CT700 power brush, I am still experiencing the same problem the power brush itself does not...
First try connecting the power nozzle directly to the hose. If it works, the problem is due to a broken wire or faulty connection in the wands. At least one wand will need to be replaced.
My guess is it's probably due to a broken or disconnected wire. This could be in the hose (most likely), the wands, or the tank wiring itself. You can test the hose wiring by using a multimeter or continuity tester. A tester may be easier for you to use, and will provide the info needed.
Disconnect both ends of the hose, sit down, and lay the ends on your lap. Touch one end of the probe to a terminal on one end of the hose. Place other probe on a connector at the other end. One connector will light, the other won't. Now repeat with the other terminal at the first end of the hose and repeat. The terminals will read opposite the reading in the first test. If the light fails to turn on with either test, it's a broken wire in the hose. This is most likely near/at the handle end, or at the wall end. In some cases it can be repaired, but not always.
It could also be due to a faulty switch.
For a definite diagnosis, take the unit, the hose, power nozzle etc. to a repair center.
Jan 28, 2011 | Broan-NuTone VX550 Bagged Central System...
Vaccuum cleaner with a broken hose
Is it just the corrugations of the hose broken? With most hose fittings there are two small oval shaped lugs on the side of the fitting. Grab a small screwdriver and gently (you may need a little force) push these in to ease the click ring out.
Once out, you'll find a type of screw cuff. Some hoses just unscrew, some are glued in (use boiling hot water to soften to separate).
Cut the broken piece of hose off, make sure the click ring is still on the hose in the right direction, reaffix the screw cuff, and replace the hose (with click ring) back into the hose fitting.
If it's actually the hose fitting broken, check with your local Wertheim retailer or repairer.
May 20, 2010 | Vacuums
Progressive Kenmore hose canister connection broken 116,2341130
A regular person with patience can however it is tricky. Kenmore hoses have an arrow at the cuff where the corrugated hose meets the swivel elbow at the machine, and at the cuff where the handle meets the hose. If your parts fit in the handle, the cuff needs to be squeezed slightly out of round at the arrows to allow the handle to be popped out, usually by using a vice and applying a sharp blow by hand to the underside of the hand grip.
If your problem is in the lower sleeve area where dirt gets into the contacts at the machine end, there is a 1" clip with bayonets on either side. It must be compressed at the bayonets to allow the sleeve to slide off. The internal contact rings should be cleaned and polished with W/D sand paper #600 and then lubed with vaseline. Contact fingers should be spread to apply more pressure on the internal rings before reassembling in opposite order.
When in doubt Panasonic and Kenmore warranty centers will be familiar with these.
Aug 05, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Power head turns on and off as the unit is vacuuming
Probably not hose but more then likely is a problem within your wand. Try connecting your hose handle directly to your powerhead and see if you can get consisten power. I work in customer service for electrolux and more then likely it is in fact the wand
Jul 17, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Hoover steam vac hose broken so I get no suction.
The entire hose has to be replaced. I beliive they run about 39.99
Jun 11, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Vacuums Logo
365 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
