Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WD440 I have a problem in that after starting a program the cycle stays on wash and goes no further although the drum keeps turning every now and then. Besides this, the washer/dryer appears to be working perfectly Hi ya. Got a WD 1400. It wont 'rince & spin' or 'fast spin'. When I put it on Fast Spin, the machine made all the right noices but the drum wasnt going round. Tried to 'Drain' but clothes still soaking. ?? If its blocked, how do I unclock it? Cheers
  • K333DAR Nov 14, 2008
    Machine will wash for EVER !!!!
    Will not move onto next part of program i.e. Drain, rinse and spin without me having to manually move the program wheel around to these items.
    Read that it could be an EPROM problem - but getting this fixed from Hotpoint seems an impossibility !
  • 868 Answers
Bad door latch or Control board is bad
Posted on May 24, 2008
Hotpoint wd440 just fills and drains does not move on from wash cycle
it ran for two hours but where did the water go? if it was not cutting off water then u most likely need to replace the water inlet value
Apr 07, 2014 | Washing Machines
The washing mashine goes through the complete cycle but only starts the drun rotation every time the wash cycle comes and than after the apropiate time continiues through the full cycle without the timer?...
I hope you can explain once again the fault that is noticed as I am not able to judge what you have experienced.
If the DRUM is not rotating or is erratic in the cycle then it is possible that the program controller unit is a prime suspect.
The power to the drum motor seems to be erratic from the controller and so is making the drum turn out of turn. I thin when the controller is activated the drum rotates without a problem.
So please check your program controller unit.
Jan 18, 2011 | Zanussi Washing Machines
Hotpoint aquarius wd440 drum sticking when rotate by hand
The drum on my hoover washing machine is sticking / grinding, can anyone advise what it may be? Thanks
Oct 14, 2009 | Washing Machines
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD440 Drawer overflowing
Hi.
I would check the inlet hose from the bottom of the soap dispenser where it goes into the drum for a soap blockage.
undesolved powder can build up here and prevent the water entering the drum
You can access this hose by removing top cover.
the hose is on the left side front.
This should solve your problem.
Please leave feed back.
Thanks.
Nov 25, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd440 aquarius
Not all programes fill with hot water.Try on 95 degree wash if it takes hot water ,you are dialing a prog,that does not take HOT.
Oct 31, 2008 | Hotpoint Aquarius WD63 Front Load...
My hotpoint aquarius wd440 washing machine - flashing lights ?
I have a fairly new Hotpoint Aquarius machine (out of guarantee).
When it is switched on, all of the red lights flash and it will not operate.
Can you help please ??
Oct 18, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd440 flashing dryer heat button and onoff button !
I had to have a tech come out for the same problem two weeks ago. They had to clean the lint collector which you cannot get to on your own. He said now that this has been done everytime I use the machine, take the clothes out and then run a rinse spin cycle.
Aug 04, 2008 | Hotpoint Aquarius WD63 Front Load...
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
347 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
