Computers & Internet Logo
Posted on Apr 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jetway S755MAX Rev: 1.0 BIOS Update
Hi
I am trying to update the BIOS on this motherboard, but it is telling me that it is write protected.
The manual states the option to disable this is in the BIOS settings in 'Miscellaneous Control' however, it does not appear in there.
I have been through the other BIOS Setup pages very carefully but cannot find any reference to it.
In fairness the manual contradicts itself as the picture of the 'Miscellaneous Control' page does not show the option! It shows what I can see.
When I try to update the BIOS it gets right to the end and says the BIOS is right protected, 'Check the jumper settings'.
So this indicates that the right protect is jumper controlled, however, I cannot find any jumper that seems to indicate in any way that it is for this.
I have also spent several hours Googling the problem with no results.
As this is Rev: 1.0 would this seem to indicate that this is an early version? The picture of the board on the Jetway website it very slightly different.
Anyway, can someone please help with this one because I really am tearing out my hair....what's left of it.
Many thanks
Michael D Shaw
Telford England.
  • 7 more comments
  • Sprocker Apr 29, 2008
    Hi
    Thank you for taking the time to respond.
    The Motherboard is a 'Jetway S755MAX' and on the board under the name it states 'Rev: 1.0.'
    If there is any further information required then please just let me know.
    Thanks again.
    Regards
    Mike
    Thanks for that.
    I do have a copy of this but dare I say the last section which details how to update the BIOS is incorrect (or appears incorrect) for my board. It states that you go to the 'Miscellaneous Control' section of the BIOS Setup and disable the 'Flash Part Write Protect'. Only problem is the option is not there!!! I have tried to do the update and it gets right to the end and states that the 'BIOS is write protect', 'Check Jumper Settings'. So this appears to conflict with the instructions.
    HELP!
    The version instaled is '755MAXA03.BIN' and I want to upgrade to '755MAXA04.BIN'
    Hi
    Thanks for your help.
    I am using the AWDFlash.exe for this, following the instructions in section 4-10 (page 43) but it just fails at the end saying BIOS write protect, check jumper settings.
    I am beginning to wonder if because this option is missing from the BIOS settings to disable the write-protect, does this effectively make it impossible to upgrade, as the option is actually part of the BIOS itself...if you see what I mean???
  • Anonymous May 11, 2010
    Yes you are correct, the info on that page is incorrect. The new bios was put out in 05 and the manual you have was put out in 03. Hence why I do believe they are wanting you to use the Awdflash exe for the install... when you go to the main download page for the bios there is a link at the top regarding updating the bios... http://www.jetway.com.tw/evisn/download/...
    Here is a question, are you using the Awdflash.exe that they reccoment to use for doing the bios flash?
    After looking through the info on jetway website and going over the files for the bios updates, if you do not see the selection to disable the Write Protect in Miscellaneous Control of the BIOS then you have the latest version already. So, no need to update the bios.
    Hope this helps... if it dose let me know. Go to the following website... and the first to last listed is your Motherboard. (S755MAXR1A) open the zip file, it conatins a PDF file. Pay attent to Chaper 4 section 10. It will tell you just how to update your Bios.
    I am guessing that you already found the new bios that you are going to update to. Make sure you verify that it is the correct bios for *********** board and that it is an updated version. It looks to me like the bios for the mother board has not changed in about 4 years. But I could be wrong on that.
    What mother board are you updating the bios on? Make and model please... and yes it is going to be jumper controlled. I just need to know what mother board so I can tell you the correct jump.
Anonymous
Level 2:
  • Expert 62 Answers
  • Posted on Apr 29, 2008
Anonymous
Expert
Level 2:
Answers
62
Questions
Helped
15158
Points
108
I understand what you are saying. The only course of action I see left is to e mail the company and ask them if there is a way to skip the "disabling" step in the update. If there is no way to skip the step then I see no way to update the Bios.
Mainboard 865gvbmsr2 bios not deceting ide hdd
Visit http://www.jetway.com.tw/jw/motherboard_view.asp?productid=181&proname=865GVBMSR2-P
Goto the BIOS download and try to update the BIOS. It may solve your problem. Try it if you know what you are doing otherwise you may get your BIOS bricked.
I want upgrade bios ga 8simlh rev 1.0,but can not
How to Reflash Motherboard BIOS About updating BIOS... The whole BIOS updating procedure should be treated with extreme caution. If you do not encounter any system instability or bugs with the current BIOS version, we suggest that you keep it. If you determine to flash BIOS, you are taking a personal risk of BIOS flash failure. Please contact your supplier or our distributors/resellers for further remedy in case system crashes unfortunately because of BIOS flash failure. Before you begin... 1. Please make sure the BIOS version you want to flash matches your motherboard model. 2. If your BIOS is flash protected, please do not enable BIOS Flash Protection under Advanced CMOS Setup (AMI BIOS) or Advanced BIOS Features (AWARD BIOS) in BIOS menu. 3. Never interrupt when you BIOS is being updated. 4. Because BIOS flashing is potentially risky, if you do not encounter problems using the current version of BIOS, it is recommended that you not flash the BIOS. To flash the BIOS, do it with caution. Inadequate BIOS flashing may result in system malfunction. Three BIOS Flash Utilities... We provide three BIOS flash utilities at our website. Below are the overviews. 1 : flashbios_qflash.gif A BIOS flash utility embedded in Flash ROM. Not all motherboards have the Q-Flash, please use @BIOS or DOS flash utility to update BIOS if your motherboard does not have Q-Flash. Features-- With this utility, you only have to stay in the BIOS menu when you want to update BIOS. No need to enter DOS or O.S. mode. Caution-- Make sure you have a functional floppy disk with the correct BIOS version for your motherboard. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 2 : flashbios_atbios.gif A Windows-based BIOS live update utility. Features-- @BIOS helps you search for, download, and then update the latest BIOS in Windows operating system. Caution-- Make sure your O.S. environment is stable. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 3 : DOS Flash utility Features-- The flash utility is a combination of AMI and AWARD BIOS flash utility. You can use it with both AMI and AWARD BIOS. Caution-- Make sure you have a functional DOS boot disk with the correct BIOS version for your motherboard.
1helpful
Ibm rev 1.5 bios update free dawnload
IBM Netvista 6648
this PC, hyjacker, is very old. and not supported by IBM now.
built by IBM in year 2000, 2 full decades ago
why even try to use this,? it will never run windows 10.
NO PCI express slots.
no SATA ports.
new BIOS would be hopeless, and not stated why.
quote your manual: check out step 2:?
1. Power-off the computer.
2. Insert the flash update diskette into drive A.
3. Power-on the computer.
4. When the Update Utility appears; select the country/keyboard, then press
Enter.
5. If the computer serial number was previously recorded, the number is
displayed with an option to update it. Press Y to update the serial number.
6. Type the 7-digit serial number of the computer you are servicing, then
press Enter.
7. Follow the instructions on the screen to complete the flash (BIOS/VPD)
update procedure.
How to flash the JetWay 939AGP-P Bios
Get this installer programs and the Bios bin file and put them onthe desktop together and open the Awdflash exe program and fallow the instructions on this site
How to update Bios
http://www.jetway.com.tw/evisn/download/update.htm
http://www.jetway.com.tw/evisn/download/bios/Awdflash.exe
I need a manual for the Jetway V266b rev.3 motherboard. Can you help in any way.
Here is the link:
http://www.machspeed.com/manuals/VIPER/V266B.pdf
Adobe reader will have to be installed on your PC.
Hope this helps
Chris
6helpful
3answers
Motherboard driver link in gigabyte 945GCM3 rev 1.0
i need intel 945GCp board driver cd...........
BIOS update (motherboard GA-6BX7+)
Please disable "BIOS Flash Protection" function in the BIOS or by Jumper. About the details, please refer to your motherboard manual.
refer to page 22 of THIS manual
If you "search" the word "flash" there are many references that may be of assistance if the jumper does not resolve issue for you
ADA3700AEP5AP 3700 Clawhammer wont boot
I believe that it should work with that chip. If you have the manual for the MoBo try resetting the cmos on the board. That should put every thing back to its defaults. It is posable that it is trying to run it at the wrong voltage.
Disabling Bios Writing Protection
Sometimes the BIOS calls this protection some sort of "virus protection" as past viruses, like the CIH virus would tend to overwrite motherboard BIOS' with jargon, bricking the motherboard. Try disabling any onboard "virus" protection and try flashing your BIOS again.
Grand Canyon Tech
Grand Canyon Tech
