We have a problem with the optical drive and I have tried the software solutions so I wish to change it.but cannot get the drive out. can you possibly send instructions please
    Genius:
  • 2,785 Answers
Just check there is any screw or latch which is holding it
Posted on Apr 28, 2008
When the computer cannot read the optical disc write it's solution
You can change the optical drive/ CD or DVD drive
Apr 20, 2017 | Televison & Video
Ze4365us will not boot from cd
If your laptop will not recognise any cd or dvd that you put into it - a music or movie dvd- it's probably the actual dvd drive at fault. It means that you will have to replace the optical drive for your computer model. This is quite easy to do.
Before buying a new optical drive, try a last-throw solution. Remove the optical drive and power up the computer. Then switch it off. Refit the optical drive and power up the computer, which may detect the refitted optical drive.
However, if you mean that your laptop will recognise the information on a dvd - such as a Windows operating system - but won't boot up from it when you restart the computer it's probably because the computer is set up to set up to boot from the hard drive first.
To change the boot-up order press either DEL of F2 at start up. Go into the bios settings and look for 'boot up sequence'. You'll be able to change the first boot to dvd or usb.
Mar 06, 2014 | HP Pavilion ze4365us Notebook
Iomega floppy usb-powered external floppy drive on windows 8
Hi, Sounds like driver related problem to me. Try use this tool to update the drivers: Driver Update Software for XP Vista 7 8. Wish you best of luck.
Nov 30, 2012 | Iomega Floppy USB-Powered External Floppy...
Burning Fail, ErrCode: 0xeb020be2
Frequently this is a driver or firmware issue. First try to update your device driver. Open the Device Manager. (Click Start > Control Panel > Hardware and Sounds (or System and Security) > Device Manger, in Windows 7. The route is similar for Vista and XP. ) Locate your CD drive in the list under DVD/CD-ROM. Right click on the drive and click Update driver. (You may need to uninstall the current driver first and restart the computer; this is in the same list.) This will find the current Windows driver. For firmware, check what drive was actually included in your G430 and find the manufacturer. You can also check for drivers or firmware at the Lenovo support site. (For 32-bit versions of Windows OS, you can use SIW to detail your hardware. It's available here: www.gtopala.com/ . )
Next check the autorun details for your optical drive. Start > Control Panel > Hardware and Sound .Select AutoPlay and select the defaults. (Note: for security reasons, you may not want to change the settings for software.) If you are really confident, you can change the Autorun settings in the registry. Back up your registry (Export > All) first. I do not recommend changing the registry.
The final solution is to get new optical drive (read/write). USB optical drives are available, if you do not want to try to replace the internal drive. Make sure that your laptop is running on AC power (not the battery only) for burning.
I hope this helps.
Feb 07, 2012 | Lenovo IdeaPad G430
Hmm, i'm trying to enter the bios by pressing f2, but i don't get the option of choosing the order of booting devices (i'm trying to format and install w7 ultimate). is there any solution to this? i've...
It most likely can only boot from the optical drive then the hard drive.If your disc isn't being recognized at boot up maybe the drive eye needs cleaning or the optical disc is bad.Also the optical drive may need replacing.
Jan 09, 2011 | Acer Aspire 5315 Notebook
How do i install internet ti sylvania mini note book
There are three basic solutions for installing software on a netbook without an optical drive:
1. Share the Disc Over a Network
Required: A network, and a PC with an optical drive
This solution essentially shares the optical drive in one PC over a network to your Netbook. For most this is the easiest method because most users these days have a network readily available, and assuming there's a network there's likely a PC with an optical drive connected to it.
First you need to load the CD/DVD into the optical drive in the PC. Now go to My Computer and right click on the drive with the loaded media, click properties, navigate to the Sharing tab (note if you haven't done this before it may give you a warning that you shouldn't do this unless you know what you're doing, click the message to continue). Check the Share this folder on the network box, give it a name of your choice and hit OK.
From this point forward any computer on your network will be able to access the shared drive. If this is a problem be sure to follow the steps above and uncheck Share this folder on the network, to take it off.
Now, make sure your Netbook is connected to the network (this works wirelessly or through ethernet wired connection). Access My Network Places, and click Add A Network Place, use the wizard to add the optical drive you selected to share.
Now that it is shared you should be able to access it from My Network Places at any time (when your Netbook is connected to the network), and it should automatically refresh if you switch the CD, if it doesn't do a right-click, and hit refresh and the files should update. If you are trying to install software and are used to auto-run, double click the Setup.exe file or similar to begin installation.
2. Use an External Optical Drive (can be a bootable disc)
Required: External optical drive
External optical drives are the easiest way to use CD/DVD media and install software to your Netbook. It is however the most expensive option.
External drives are very simple; just plug it into an available USB port. Your Netbook will automatically detect the drive and simply add it to My Computer just like a built in drive. Some drives will even run power through the USB, while this makes them more mobile it eats up your Netbook's battery faster, if that is a problem other external drives do require a power outlet for use but should not drain your battery.
3. Create an Image (not bootable)
Required: Image making software (like Alcohol 120% or VirtualDrive), image emulation software (Alcohol 120% includes one, Dameon Tools is another, or Power Iso), access to a computer with an optical drive, and a method to transfer a large file from that computer to your Tablet PC.
You will need to use your particular software User-Guide for most of this process. What you do essentially is use software to create an exact copy of the CD in the form of a file (normally a .iso) that has to be read by an optical drive emulator which then can access the CD as if it were being read by a real optical drive. The biggest disadvantage to this method is that CDs can run around 700mbs, DVDs around 4gbs... transferring files of that size, even over fast networks, can be tedious. A benefit however is you can carry important CDs (as files) with you as you go, so for example if you need to install Microsoft Word content to use some feature while your in a meeting, you can do so without having the physical CD with you... This however of course requires heavy disk space since the CD file tends to be around 700mbs.
Hope this helps.
Dec 28, 2010 | Sylvania G-Netbook
My CD-rom will not work after inserting CD's or DVD will not rev-up what wrong and what should I Do I Have Inspiron 531????
1.The laser optical eye of the CD-ROM drive may be dirty, and needs cleaning.
If the optical eye is dirty, it won't read the information on the disk you install.
A) Computer on, Windows loaded, open the tray of the DVD-ROM drive. (Or DVD burner drive. Whichever drive you are referring to. DVD-R/RW)
Shut the computer down normally. (Start>Turn Off Computer>Shut Down)
Unplug the computer from power.
Use a can of compressed air fror computers, and spray air into the DVD-ROM drive.
The optical eye, is located on the bottom of the DVD-ROM drive. (Or burner drive)
The opening in the bottom of the tray, that comes out for your disk, is where you spray the air.
You won't be able to see the optical eye, so how will you know you are spraying the air at the correct place?
If you start at the front of the bottom of the DVD-ROM drive, and work your way towards the back, you will clean the optical eye. Spray across from side to side, and in rows, as you proceed towards the rear.
(Air will make it's way through, and reach the optical eye. The optical eye is not visible, as it can be harmful to the human eye when operating.
Laser.
When the tray is closed the optical eye is exposed. It is not exposed to where it can harm the computer user.
More information that may be helpful, in understanding where the optical eye is located,
http://en.wikipedia.org/wiki/CD-ROM_drive
Scroll down to the heading - CD-ROM drives. Also view the photos down on the right, and the animated GIF.
http://electronics.howstuffworks.com/cd4.htm
How a CD Player Works. Same principle for your DVD-ROM and DVD burner drives )
2.Make Windows reinstall the drivers.
This solution requires physically removing the flat ribbon cable from the back of the DVD-ROM/DVD burner drive, then reattaching it.
Software advice of Updating the drivers, Rollback the drivers, or downloading, and installing the drivers, doesn't always work, or doesn't work.
If the physical solutions I am providing here does not work, we will proceed to the software solutions if you wish. (Comment)
1.Computer off, and unplugged from power. Open the computer case,
Dell Support - Dell Inspiron 531 Desktop PC - Manuals - Documentation - Removing and Installing Parts,
http://support.dell.com/support/edocs/systems/inspd531/en/OM/parts.htm#wp1595069
(Removing the computer cover)
CAUTION!
BEFORE you reach inside you need to relieve your body of Static electricity!
Not trying to freak you out, just needed to catch your attention.
Static electricity, can fry out the delicate computer hardware components, inside your computer.
Touch the metal frame of the computer case.
Computer unplugged from power you are safe.
Touch the metal frame of the computer case, (AFTER you unplug the computer), the computer is safe.
In the above Manual documentation - Removing and Replacing Parts, click on - Drives
Scroll down to the heading - CD or DVD Drive
(Towards the bottom of the page)
Unplug the DATA cable from the CD-ROM drive.
(No.2 in the illustration)
[The two optical drives you have are SATA drives. Dell indicates you have a DVD-ROM drive, (Plays CD's and DVD's), and a DVD burner drive.
(Plays CD's and DVD's, and records)
DVD-R/RW is a 'Burner drive'.
If the information above is correct, you have a SATA power cable, and a SATA Data cable.
(The Data cable transfers information from the optical drive, to the computer, and vice-versa)
The SATA power cable connector, is longer than the Data cable connector.
The power cable connector has 15 pins.
The Data cable connector has 7 pins.
Information,
http://en.wikipedia.org/wiki/SATA
Scroll down to the heading,
Data
Look to the right at the photo. This is a SATA Data cable, and it's connector.
Yours may not be a bent 90 degree elbow, but it will have the L shape in the connector, and 7 pins.
Scroll down to the heading Power Supply. Look down to the right at the photo of the 15 pin SATA power cable connector.
This is Not the cable/connector you want to unplug.
Unplug the SATA Data cable from the optical drive you're referencing to.
Press the Power On button in, and hold it in for a count of Five seconds.
Let go of the Power On button.
Do this two more times.
Plug the SATA Data cable back in.
Close the computer case.
Plug the computer back into power.
WAIT 1 minute.
Turn the computer on. Try the drive.
Dec 17, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
Sony Vaio Notebook's blu-Ray optical drive stops during DVD play
The laser is definitely weak on that drive, it takes alot of power to play blu-ray discs and if the laser may have been slightly defective to begin with then that can cause the drive to act funky the way it has been.
Whatever blu-ray drive you get doesn't matter as long as the shape of it is the same as the one you have now cause all you would have to do is change out the front door and the screw holder on the back of the drive, then because the shape of the drive is the same, you can move it back into its slot.
Your notebook is new enough to where any drive will work in it.
Jul 04, 2009 | Sony Computers & Internet
Getting a error 320
Hello again,
Sounds to me that the software you are using is corrupt and if that is the case the only solution is to rebuild the OS by using a CD. This isn't uncommon, if their is a bad sector on the Hard Drive this can cause the software to error and become corrupt. A full reformat and installation is the only solution if the software is corrupt.
Hope that helps,
ArmyMason
Feb 23, 2009 | Sony VAIO VGN-NR498E/S Notebook PC
I need software for ***-35PU Optical Mouse for my new computer
try this link later , The website is under maintenance.
Apr 27, 2008 | A4tech WOP-35PU Optical Mouse
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
