Question about Henry Numatic "" Canister Vacuum
Henry hoover Automatic rewind of cable not working. Cable will only come out a few feet then jams. Currently using an extension lead. Any advice on how to free cable much appreciated.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=26736&thid=552936
Henry Hoover
Posted by modbod on Apr 28, 2008
Automatic rewind cable not working. Cable will only come out a few feet then jams. Currently using an extension lead. Any advice on how to free cable much appreciated.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I am sorry that Henry Hoover is having a problem with his cordwinder and what happens that the cord tends to overlap the other cord inside of the vacuum and what needs to be done is this; #1 take apart the cordwinder and unwrap al the cord all the way out then re-wrap the cord and re-install #2, if that does not work then lubricate the cordwinder but not the cord to have it work more efficiently, and #3 if all else fails replace the cordwinder with a new one. Always when using the cordwinder, always pull out everything until the end to use the cord all the way out to prevent the cord from over lapping and binding up inside the Henry Hoover. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 28, 2008
No power, electrical wirring is intact from power plug to switch to pcb
normally with a henry the cable breaks from where it joins the hoover just take apart from hoover end cut about a foot of cable off and then rewire
Feb 09, 2014 | Henry Numatic "" Canister Vacuum
Henry hoover
Hi it can be the connector at the end of the Henry cable inside the cable rewind unit happened to us!
Nov 14, 2012 | Numatic Henry Bagged Canister Vacuum
My Henry Hoover cut out and will not work. Emptied bag and replaced fuse but no success.
If no burning or smelling, maybe nothing to do with motor, and if caused by the safety cut-out, it will need about an hour to cool down, and then check filter, bag, and drop coin through hose, pipes and the floor tool, to check for blockages and to stop it running hot. Damaged cable, worn carbon brushes, broken electrical rewind electrical contacts or even the printed circuit board (later models) are the most likely causes.
Jul 08, 2011 | Hoover Vacuums
My hoover smells of ammonia
I too have a problem with a bad smell coming from my henry hound hoover, but thats probely because i haven't used a hoover bag. I took the cloth filter out,banged all the dust off, then sprayed it with 'RugDoctor' pet stain remover for carpets and upholstery. It still smells a bit, but not half as bad as befor. I have now ordered a reusable,zipable,washable cloth hoover bag especially made for Henry's. It cost £8.80 from ebay with free postage. Hope this helps Nikki.
Oct 30, 2009 | Numatic HHR-200 Henry Hound Bagged...
Automatic Cord Rewinder is not rewinding anymore
I had the same problem - the power cord for my Hoover Elite Upright (U5507900) was stuck a few inches out and wouldn't go any further. But when I unscrewed the rewinding mechanism, the cord had clearly gotten twisted and partly buried under itself so after some work I was able to free it. Now it seems to be working fine, at least for the moment. Note that I had to use small screwdrivers to unscrew the cord rewinding compartment, like the kind of screwdrivers you use for computer repair.
HTH!
May 27, 2009 | Hoover Elite Rewind Bagless Upright...
My henry hoover has just stoped working its not the fuse do you have any ideas
I had exactly the same problem.there were no burning smells coming from it so nothing seemd obvious.I then took it apart and checked that all wires were connected,which they were.Then decided to check the plug.After replacing the fuse I chopped the cable of (as it is a seald plug) and connected up a new one.Hey Presto,Henry was alive again.Hope this helps.
Nov 03, 2008 | Hoover Vacuums
Henry Numatic "" Canister Vacuum Logo
1,971 people viewed this question
Top Henry Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Henry Vacuum Expert? Answer questions, earn points and help others
