Question about Creda W120VW Front Load Washer
Creda 1200 washing machine
There is a bad / stale water smell when i use machine, unable to find any filters, can you advise on this problem, no manual to check either,
Regards Lorraine.
  • yedder Jun 15, 2008
    got rid of, bought new £250 from curry's, best thing i ever did, thanks for help,
    Wash safe, Yedder.
  • alexandraj Aug 31, 2008
    I have the same problem. A terrible musty smell inside the machine machine.
  • 66 Answers
Make sure that your outlet pipe is at least 24 inches of the floor so you will not get dish water running back in the machine and give machine a quick wash using a good bleach hope this is usefull
Posted on Jun 14, 2008
My machine smells damp and musty in between uses. it smells like there is stale smelly water in it, it`s so bad that we can`t leave the door open. This is only a recent thing, we have pulled it out and...
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | Washing Machines
My dryer smells like an old wet wash cloth. It has a stale water smell to it and is making my clothes smell like it. I can smell it when i open the door and stand right in front of the dryer opening. the...
There is a very simple way to get rid of unwanted smells. I would suggest use a cup of white vinegar every wash to clean from stale muck and smells inside the machine.
Jul 24, 2017 | Dryers
Our clothes are coming pout smelling bad after a wash. The machine is old. We do not know if there is a filter to clean out? Not even adding SHOUT will help the smell.
You should put one half cup of bleach in the washer and let it fill. After it sets for an hour run it thru a cycle refil and do it again. All washers have water left in them even when they empty so it sounds like you had stale water in it and possibly mold bleach will take care of it and a few cycles.
Aug 08, 2010 | Washing Machines
I have a Creda 1200 washing machine, I am unable to locate the fluff filter. Does my machine have one? if not, what happens to dogs hairs etc? will they damage my machine?
The filter is at the rear of the washer.
Remove the lower rear cover of washer.
Remove the large black hose fastened to bottom of drum.
Clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well..
Please rate my solution.
Thanks.
Jan 17, 2010 | Creda W120VW Front Load Washer
Stale water smell
washer is under warrenty so called a repair man
May 18, 2009 | Roper RAS8244LQ Washer
Bad smell on dried dishes after being washed.Stale water smell.
Try Running Goo Gone Through It Although It Smells Like Oranges It Removes Stains As Strong As Sap. Also Try Running The Dry Cycle While Its Empty Two Or Three Times.
Jan 06, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Manual for Creda Excel 1200 W120VW
In your browser bar type in:
HOTPOINT USER MANUAL and follow the links.
You will find what you are looking for.Although it says Hotpoint, just type your model in the box, and it will come on screen, then you can save it, or download it to your printer
Plz rate my solution.
Thanks
Dec 15, 2008 | Creda W120VW Front Load Washer
Foul Smell from my GE Adora Washer..!
Having the same problem as everyone else , I make a habit of cleaning the filter once a month. I would like to advise people that if your load is heavy (such as scatter rugs) they will not spin out completely even when the filter is cleaned. No more GE for me!!
Aug 21, 2008 | GE WSXH208A Front Load Washer
Stale smell on crockery after wash
Most commonly, this relates to sulfides or other impurities in the water itself, but may also be caused by a buildup of food soil within the washer. Smell a clean glass of water. Does it smell stale also? If no, clean the screens and wash water sump/tank within the machine.
You can also clean the inside of the machine by using a commercial grade dish machine detergent and increasing water temp if possible.
If the water smells stale, consult a local water expert for guidance in resolving
Aug 19, 2008 | Dishwashers
Creda W120VW Front Load Washer Logo
175 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
