Question about Toshiba Qosimo G35-AV660 Notebook
Skreeching sound comes from speakers when ever I switch it on, I cannot bear it so I connect a microphone plug. Looks like the mic is on, how can I switch it off. Paul
  • 54 Answers
Click on the speaker icon at the right bottom , go to the properties and then at mic option and click on the mic box it will get muted
Posted on Apr 29, 2008
I want to attatch my mic to my motherboard
desktop or laptop computer ?
3 Ports on the side- Pink,Green,Black
Pink Port is LineIn for an external device player jack
Green Port is LineIn for the Microphone jack
Black Port is LineOut for Headset or External Speakers jack
Plug the Green jack on Headphone - into the Black Port on the laptop.
b) Go to Control Panel and open - RealTek HD Audio manager
On the top of Page are 3 Icons -
One Icon is labelled Speakers One is for Digital optics, one is for Mic,
The Speakers Icon is misleading as it is also for Headphones (LineOut)
Select Speaker Icon and make it Default. Also tick Full Range - Front LR
Ignore the 4 vertical Analog Icons on the right side.
You should now have Headphone sound if your volume is not Muted.
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then
you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab
make sure that you have the right media selected also
select volume make sure the box for microphone has a tick in it
or you might have to depending on your operating system
Click start Control Pannel
click on Hardware and Sound
click on Sound
then you devices should come up ; speakers, Digital Audio, and headphones
plug your headphones in
then select headphones
at the bottom it will say set as default
select that!!
then when you disconnect your headphones it automatically switches to the speakers and when you plug them back in it automatically will switch to headphones
hope this helps
Sep 19, 2012 | Biostar P4M900M7FE Motherboard - VIA...
How to connect SONY DYNAMIC MICROPHONE F-V40 to JBL EON 515 15IN PWRD SPKR yahoo
Several ways. Easiest way is to just hook up mic to speaker via XLR and make sure on jbl speaker switch is set to Mic not Line. ( for volume ). Ideally you would hook mic to a console ( mixer ) and come out of mixers main out (l/r) to 2 separate jbl speakers ( being powered no amp is necessary ) for stereo!
Aug 26, 2011 | Audio Players & Recorders
Losing sound when plug in mic
You are probably plugging the mic in the wrong port, you should plug it in the other port looks the same.
I think the port that you are plugging in your mic is of sound (headphones).
Hope this helps
Mar 30, 2010 | Audio Players & Recorders
How to connect a microphone to Logictech z-340 ?
Hi there and happy new Year , Your Microphone has to be connect to your PC in the Red or Orange Color COded Jack Input , it cannot connect too your Speaker System ...
Hope this helped bud
Dec 26, 2009 | Logitech Z-340 Computer Speakers
Don't know how to hook them up
What a lovely daughter, how very nice of her,
here goes....straight for Mr. Koss
To Operate with AC Adapter
  1. Open battery compartment located at the back of both speakers and remove wires.
  2. Replace battery covers.
  3. Connect DUAL PLUG CONNECTOR on left speaker to right speaker at connection marked "TO LEFT SPEAKER."
  4. Connect remaining wire with 3.5mm plug to headphone jack on your audio source.
  5. Connect AC adapter (not included) to back of left speaker at connector marked "DC 6V." Plug remaining end of AC adapter into wall outlet. Be sure your AC adapter is built with the center pin as ("-") negative. Connect remaining wire with 3.5mm plug to the headphone jack on your audio source.
  6. Turn ON/OFF switch at back of right speaker to "ON."
  7. Set "INPUT SELECTOR" switch to audio source.
  8. Turn on audio source
  9. Adjust sound in the following ways: Turn volume control to desired level; push Bass Boost button located on right speaker to "ON" for added bass; push Treble Boost button on right speaker to "ON" for added treble
  10. Operating a microphone through your speakers require an additional 3.5mm plug to 3.5mm plug cable (included). Connect cable with 3.5mm straight plug to right speaker at input marked "MIC" on back of speaker. Plug the remaining 3.5mm L--plug into the mic input on audio source. Connect your microphone to the front of your speakers at "MIC" input (microphone not included)
Hope you have all of the skinny you need, good luck,
please leave a rating, thank you kindly
Apr 27, 2009 | Computers & Internet
Cannot recognize working microphone
I found the answer. Rosetta Stone has a problem detecting the mics if the speaker input is not in someway connected to the mic. I'm not exactly sure how it works, but I don't care and neither should you.
Follow these steps each time you want to use it and you should be fine.
*I'm on Vista, but this should work for every one.
1. Open Control Panel
2. Open Hardware and Sound
3.Open Sound
4.Set Line 1 as your Default Speaker
5. Refresh the Mic list
*All of your mics should now show up.
6. In Rosetta Stone, apply the mic you want and finish the setup.
7.Start whatever language you're using and switch back to the Sound menu.
8.Set whatever speaker you want to use as default.
*Rosetta Stone will continue to work fine until you close it, switch Users, or remove the mic.
In short you have to set the default speaker to LINE 1 to get the mics to appear. Then when you apply the settings switch the default speaker back.
Apr 21, 2009 | Computers & Internet
Labtech 524 microphone does not pick up sound
I have written a guide on How to convert Records and Tapes to CD. I have found that when someone asks me a question like yours here is what I tell them. Go to http://audacity.sourceforge.net/ Download the program Audacity. It is a completely free program. It works great for many audio applications. It does not have spware or adware or anything like that attached to it. In fact many studios use this program. Click on the Download Audacity 1.2.6 link to download the program. Install the program and open the main window. In the middle of the window you will see a field that is labeled Microphone. If the field is not set to Microphone then change it by clicking on the drop down menu. There are two slider controls to the left and right of the small microphone icon. Click on the sliders and set them at about 1/2. These 2 controls are your microphone input level and your Audacity main volume control. Now simply click on the round red record button. Talk into your microphone. If your mic is recording you should see recorded sound waves in the middle of the window. Click on the square stop button and then click on the rewind button. Next click on the green play button. Make sure your computer speakers are turned up. If this doesn't work your sound card may not have recording capabilities or you may have your mic plugged into the wrong connection on your tower. You can move the mic to a different connection and try recording again. Just don't plug into your speaker connection this could damage the microphone. You can check to see if your sound card has recording capabilities by competing the following On your desktop click on start - control panel - sound, speech, and audio devices then click on sound and audio devices. When the small Sound and Audio Device Window opens, click on the audio tab. Under the title sound recording, you should have a sound card listed in that field. For example my card is a SoundMaxDigital Audio. The field is right next to the small microphone icon. If there is no card listed you can buy a cheap one online or even at Wal - Mart. They are very easy to install. You just find an empty slot on *********** board and your computer should recognize the card.
Mar 13, 2009 | Labtec Verse 524 Consumer Microphone
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
Audio feedis crossing with my speaker feed with and without the microphone plugged in.
Your mic still picks up sound when it's unplugged ?
As far as the other prob goes that sounds like howl round ( feedback ), mute the mic when not talking through it or get a mic with a cardioid polar response pattern ( just ask for a cardioid mic, can get a hypercardioid or supercardioid too but a cardioid would be best for your application, point the mic right at your speaking position with the back of the mic pointing at the speakers wich ideally should be behind the mic, this will help cancel out their sound, puting a limiter on the mic and setting it where it only starts picking up sound when you talk directly into it will help too, but the sure fire way to solve the prob is to mute the mic when not speaking into it. What you definitely don't want is an omnidirectional mic, for what you are using a mic for.
Jun 10, 2008 | Logitech Labtech Verse 524 Microphone
No Sound Coming out my Microphone
i know this might sound a little obvious and maybe irrelevant to the problem, but did you press the switch on the mic? it will turn the mic on and off. make sure sound and mic are unmuted in windows volume control. if both are these didnt solve the problem, test the mic on another computer. if the mic works, maybe its not the mic that has the problem. if the mic doesnt work, then your mic may be defective or damaged in some way or other.
Mar 28, 2008 | Philips PH62080 Uni-Directional Microphone...
Toshiba Qosimo G35-AV660 Notebook Logo
42 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
