Question about Kitchen Ranges
Door hinge closed after removing door - Kitchen Ranges
We have Dacor wall mount oven. We have had problems with the hinges. The door will not close completely. We actually now can see the light through the side when the door is closed. The repair person told us that someone must have pushed the door in too far or hung on the doors and the hinges are bent and that we need to replace the hinges, which sounds expensive. Is there another suggestion?
Posted on Feb 25, 2010
How do I remove the door of Chevrolet spark
This is a TWO person job!
-Open the window all the way. This will give you something to use as a handle.
-Open the door and disconnect the wiring loom connector.
-Unbolt the door check strap bar between the hinges.
-Support the weight of the door and locate the hinge bolt on the door.
-Loosen, but do not remove, on both hinges.
-Get your helper to support the door as it might drop suddenly.
-Remove the BOTTOM hinge bolts first. Then remove the UPPER hinge bolts.
-The door should drop out of position.
REINSTALLING.
-Support the door in the open position.
-Fit the top bolt in the top hinge until finger tight.
-Repeat this for the bottom hinge. It will take some of the weight of the door.
-Refit the lower bolts for both hinges until finger tight.
-GENTLY swing the door closed to check it is not positioned badly.
-Reopen the door and tighten the hinge bolts as follows.
Top hinge, top bolt.
Bottom hinge, top bolt.
Top hinge, bottom bolt.
Bottom hinge, bottom bolt.
-Tighten until tight BUT do NOT overtighten.
-Refit the door check strap.
-Reconnect the wiring loom connector.
-Close the door to check fit.
Jan 23, 2018 | Chevrolet Cars & Trucks
Tip
How to Reverse Your Refrigerator Door (Most units)
1. Remove the toe grille.
2. Remove top hinge cover if available. Trace around the hinge with a soft lead pencil. This makes the re-installation easier. Remove top hinge and lift door off the center hinge pin, and set the door aside.
3. Unscrew the center hinge pin using an adjustable wrench and save for reassembly. Ensure that the plastic washer stays on hinge pin.
4. Lift the refrigerator door off of the bottom hinge and set aside.
5. Remove center hinge and shim by removing inside screw and loosening two outside screws enough to allow hinge and shim to slide out. Tighten screws.
6. Loosen two outside screws on opposite side of refrigerator, remove inside screw and install center hinge.
7. Remove two screws on bottom hinge with 3/8" socket wrench.
8. Install bottom hinge on opposite side with the two screws removed from Step 7.
9. Unscrew the bottom hinge pin using adjustable wrench. Move hinge pin to other hold in hinge and tighten with adjustable wrench.
10. Reverse door handles.
11. Move freezer and refrigerator door stops to opposite side. Before starting screws, use an awl to puncture the foam.
12. Position refrigerator door onto bottom hinge pin and screw center hinge pin through center hinge into the top of the door. Close refrigerator door to help align hinge hole.
13. Tighten center hinge pin with adjustable wrench.
14. Remove cabinet and hinge hold plugs and move to opposite side.
15. Lower freezer door onto center hinge pin (if you have a separate freezer door).
16. Close freezer door. Have an assistant lift up on opposite side of the door while tightening screws to install top hinge.
17. Flip top grille and reinstall.
18. Plug in electrical power cord and turn refrigerator temperature control to center position. Adjust setting as needed.
on Oct 19, 2011 | Frigidaire Refrigerators
How to change door opening to other side
Hi Eleanor,
Without a specific model number I can only give general information, but, Kenmore fridges are all about the same, so here we go. Take a close look at your unit. You should observe several small plugs inserted on the side of the doors that don't have the hinges currently mounted. These inserts cover threaded holes that are used to mount the hardware for the hinges. If your fridge has two doors one above the other. remove the top hinge hardware, lift the door up off of the bottom hinge pin. then remove the bottom hardware on the top door. Typically the mounting screws are either phillips head or 1/4" hex head machine screws. You should now see that there is now a threaded hole in the same position on that side as the plug in caps on the other side. remove the caps from the one side and insert them in their respective holes on the other side. the door hinges will attach to the now exposed holes on the side that the plugs were removed from. But not yet. First remove the top hinge hardware on the bottom door, lift the bottom door off of the bottom hinge, and then remove the bottom door hardware relocating the bottom hardware to the other side. Install the bottom door onto the hinge pin of the bottom door hinge. Close the door then install the top hinge on the bottom door. Next install the bottom hinge and hardware for the top door, set the top door on the installed hinge, close the door add install the top door top hinge and hardware next. Same with the door handles. All of this info applies to the doors and the fridge itself.
Jun 26, 2015 | Kenmore Refrigerators
How to remove bottom (freezer) door on my subzero refrigerator/freezer
With the door closed. Remove the cover over the bottom door hinge by removing the two screws holding it in place. This also allows the door closing mechanism to be removed. Rotate the door closer away from the refrigerator and slide straight down. Now open the freezer door. Take a pencil and mark around the hinge on top of the freezer door so you will know where to put the hinge back in place later. Remove the three large hinge screws and two small shipping screws. This will release the door on the top. Rotate the door away to get free from the hinge and pull the entire door straight up.
Dec 08, 2013 | Refrigerators
Oven door won't quite close tightly. I can push it about another 1/4 inch to close it completely.
You need to replace the hinges in the door. Go online to a spares website and enter make and model and order new hinges. You can replace them by unhooking the door, just takes a little effort, you might need to flick back latch on hinge and lift out. Remove inner door panel, usually 4 screws and remove. then change hinges. The 2 big pieces are the hinges.
  • images?q=tbn:and9gcsg1plmaxnucdapg-xpimmjauz_p4kgblmyf6iotcmgyh-hv4v3
Mar 09, 2011 | Ovens
How do i change the hinge on thhe refrigerator door? Thanks for your help!
Unplug the refrigerator and remove all food and utility bins from the doors. With the door open, remove the grille from the bottom of the refrigerator. Close the door.
Step 2
Remove the cover from the top hinge with the putty knife. Remove the three screws underneath, then remove the hinge. Take off the freezer door.
Step 3
Remove the three screws from the center hinge, then remove the hinge. Take off the refrigerator door.
Step 4
Remove the two screws from the bottom hinge, then remove the hinge. Replace with the new hinge and insert the two screws.
Step 5
Seat the refrigerator door on the bottom hinge and close the door. Fasten the new center hinge with the three old screws.
Step 6
Seat the freezer door on the center hinge and close the door. Fasten the top hinge and replace the top hinge cover.
Step 7
Replace the base grille, and plug the refrigerator back in.
Good luck in solving the problem with the solutions provided....
Aug 03, 2010 | Sanyo SR-4910M Compact Refrigerator
How do you adjust hinge pin hinges? I want the door to close faster.
the only hinge that can be ajusted via the pin is a loose pin hinge where the pin can be taken out to remove the door. It canot be ajusted to make the door close quicker. You can put a door closer on the door/frame but this will make the door close a lot quicker.
Perco make a closer thats is a right bas!!ed to fit but works well
Jul 13, 2010 | Hardware & Accessories
Bosch HBL 645 oven door won't close all the way
I am afraid that the door hinges are non adjustable, and the only solution is to replace them as a pair.
There should be some kind of latch mechanism at the end of the hinge
where it is fastened to the door to compress the hinge to enable you to remove them.
Hope this helps.
Jan 04, 2010 | Bosch Ovens
Dcs oven door unhinged
easy to install the door,before to remove check it how exactly the position of the door its a clip typr,or get the manual to see the procedure,open the door,pull open then if u see the hinge we have small lock in the hinge u psh it up the lock then slowly close the door,be care bcoz the hinge is powerfull,if u close the door see the hinge how to remove the door.
tnx gerbee
Jun 23, 2009 | DCS RGS-305 Professional Gas Kitchen Range
Adjustment to door hinge, as door does not close completely
In most cases door hinges needs to be replace but some time with old stile ovens and ranges help this trik:
1. Put small towels on right and left hinge between the door and range/oven body
2. Close door and gently push like you try to close completely.
3. Try several times.
4. Open door, remove towels and see if it helps
5. If not replace hinges
Nov 29, 2008 | DeLonghi Kitchen Ranges
Kitchen Ranges Logo
280 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
