Question about Konka FL2794U 27" TV
Color the normal colour has gone all people green.tried adjusting colour still the same
  • Anonymous Feb 20, 2009
    hit it and it will work
Did you ever find out to fix it??? i am having the same problem
Posted on Jul 06, 2008
My E771 monitor colors suddenly shifted with
Possibilities:
1. video-card gone bad;
2. video-cable gone bad;
3. video-cable not tightly-connected to CRT;
4. video-cable not tightly-connected to video-card;
5. "red" gun inside CRT gone bad.
Disconnect the video-cable from the computer, and try again to adjust the "red". If red-free, then it's time to responsibly recycle the CRT.
Reconnect & wiggle the video-cable, to see if that induces any "red" onto the CRT.
Connect the CRT to the VGA-output port on a notebook computer, to see if that video-card generates "red" as one of the primary colours.
Give the CRT a strong "whack" on the side, to see if "red" makes an appearance.
May 07, 2010 | ViewSonic E771 17" CRT Monitor
Green horizontal
I believe that you must reset the colors of the screen by the buttons on it or try to set colors by the software that the product came with it if any. There should be a setting to configure the 4 basic colours like red green black etc. Try to adjust green. If nothing helpes go the monitor back to test it by the store you bought it if there is warranty. Hope that helped!
Mar 23, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
The colour on my TV is a reddish colour. Have tried the colour adjustment. Skin colours in particular.
simple. easy. you have 3 screen adjustments. red green blue. turn color all the way down. you should then get just a black and white picture, but in your case, it will still be reddish. behind the speaker grill is an access panel for screen adjustment. remove speaker grill. remove access panel. you will see a block assembly roughly 6 inches square with 6 knobs on it. 3 are for screen, 3 are for focus. adjust until you have a black and white picture. then go into menu and turn your color back up. enjoy!
Nov 14, 2009 | Televison & Video
My color isn't normal. I can't see red and green properly. I've tried adjusting the settings but nothing works.
If you have had a vaccumn cleaner too close to the tv, then you may need what is known as de-gausing. This will bring your colours back as normal. Seek advise from your local service engineer.
Oct 25, 2009 | Televison & Video
Color
Check the red colour out put section at LCD base PCB..the capacitor is weak or the transistor is gone bad,replace with new one..
Jul 09, 2009 | Samsung PCL541R 54" Rear Projection...
Color is heavy on the green. Can't adjust it to look normal.
Ty reattaching the monitor cable to the monitor and PC.
If that does't work, try another cable.
One of these should solve your problem.
May 19, 2009 | Toshiba 42HL196 42 in. LCD HDTV
Screen gone yellow and green
I have a 21'' NEC TV Screen and it about 3 year old. the colour has gone to yellow and green color and the red etc
May 10, 2009 | Samsung PPM42S3 42 in. Plasma Television
Projection tv color issue
Our tv has gone very green and we can't seem to adjust it back to normal. Do you have a solution for that??
Nov 27, 2008 | Televison & Video
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
Loss of colour
With the set being 12 years old, I'm sure the picture tube is near the end of its useful life. You probably have a defective semiconductor, either an IC or transistor that has gone up giving you no color, but with the green picture, it is not likely worth repair.
Jan 02, 2007 | Toshiba 36AF61 36" TV
Konka FL2794U 27" TV Logo
99 people viewed this question
Top Konka Televison & Video Experts
Arnel
Arnel
Computer Repairing
Computer Repairing
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
