Question about Nokia 6131 Cellular Phone
Main screen not desplaying when I open up my Nokia 6131
When I open phone the screen lights up but there is no display. The display on the frount screen changes.
  • 4 more comments
  • Anonymous Jun 03, 2008
    I get a blank screen whenever I open the flap, since I have inserted the 512 mb memory card. I have to close it again and then reopen to get the display.
    Also recently my screen has started flickering :-( ... Unfortunately i haven't found any workaround yet
  • bigteger Nov 20, 2008
    When I open the phone, the main screen lights up but remains black except for randomly colored dots scattered around. If I close the phone and then re-open, the display functions normally.
  • pintuu Nov 25, 2008
    i too have a same problem.inspite of switching on / off main display doesn't come up.got the ribbon cable also replaced.pls suggest a solution.
  • tmiljanic Dec 23, 2008
    my ribbon cable is broken and so the screen won't work... does anyone know how i could connect the bluetooth so that at least i can send the info to a new phone
  • Daleet Dec 28, 2008
    I have had the exact same issue. It started a couple months ago, where it would only display a black screen for 1 in every 10 opens. Now it's the opposite, but only shows the proper screen in every 50-70 opens. It's more than frustrating I can tell you. I don't think I'll go Nokia again because of it.
  • Anonymous Mar 31, 2009
    my screan goes black whenever i flip it open
Try turning the phone on with the flip screen open. Do it a couple of times if it doesn't work the first time.
Posted on May 18, 2008
Nokia 6131 blank screen
this problem occurs probably when there is problem with display
you would probably have to replace your display (LCD screen)
not much costly
this may also occurs when your phone is attacked by virus but this has less probablity in this case
May 02, 2011 | Nokia 6131 Cellular Phone
Dear i have same mobile.. but now a days there is problem on the front screen of mobile dat there is lining is showing.. i cant see main display properly tere is some light lines on the display.. plz ans...
check the flex/ribbon wire of the LCD may be loose or damage. but if try to use a good LCD, your LCD may be damage and need to replace with a good 1...
May 24, 2010 | Nokia 6131 Cellular Phone
Nokia 6131, front/internal screen light up but don't display
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Dec 17, 2008 | Nokia 6131 Cellular Phone
Main Display
Hi. Have you tried replacing the LCD screen? You can buy one herehttp://www.formymobile.co.uk/proddetail.php?prod=6131lcd and see thedisassembly section of the following file for fitting https://www.yousendit.com/download/Y2o4WGJEY1NxRTFMWEE9PQ
Nov 14, 2008 | Nokia 6131 Cellular Phone
I have nokia 6131. its main display is not working properly. only welcome screen come & meanwhile main display goes blank.
Hi. Have you tried replacing the LCD screen? You can buy one here http://www.formymobile.co.uk/proddetail.php?prod=6131lcd and see the disassembly section of the following file for fitting https://www.yousendit.com/download/Y2o4WGJEY1NxRTFMWEE9PQ
Nokia 6131 problems after changing housing
llok michelle i am a professional phone repairman
i think u shud chek the belt that connect the two parts of the phone screens and keypad. and if its connected well and the phone still just like it was u shud change that damn belt cuz its very sensitive electronic stuff always watch out with the belts
Aug 16, 2008 | Nokia 6131 Cellular Phone
Nokia 6131 housing
http://www.eserviceinfo.com/downloadsm/29953/Nokia_6133%206131%206126.html
This link will help you with re-assembly. I had the same snag. A GENTLE adjustment of the speaker contacts fixed the problem with sound. Use the above link to check your display connections.
Aug 15, 2008 | Nokia 6131 Cellular Phone
NOKIA 6131 PROBLEM
Hi go to ur mobiles setting and select full fectory default its security code is 12345. thanks keep voting.
Apr 04, 2008 | Nokia 6131 Cellular Phone
Nokia 6131
open ur phone menu. go to settings options,scroll it down further and look for display settings. in display settings there will be option to adjust its brightness.
Feb 22, 2008 | Nokia 6131 Cellular Phone
Nokia 6131 Cellular Phone Logo
350 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
