Question about Sharp AL 1631 Copier
AL-1631 Power save indicator is flashing
At power up, The power save indicator starts flashing and nothing works. I work on HP and Xerox Laser printers but don't have access to Sharp diagnostic info. Thanks
DWallace
  • David Wallace
    David Wallace Apr 28, 2008
    At power up, It goes through its system checks.Then the power save indicator starts flashing and nothing will work. I work on HP and Xerox Laser printers but don't have access to Sharp diagnostic info. Anyone know what that error code indicates?
    Thanks
    DWallace
    Genius:
  • 3,587 Answers
Looks to me like pages 54 and 55 on 2nd link from octagon have premium information..if that doesn't get it, then your machine is truly unhappy.
Posted on Apr 28, 2008
    Genius:
  • 1,447 Answers
Hi- Are you getting an error message aside from the lights?
    President:
  • 1,944 Answers
AL-1631 is flashing "H". How do I fix this which appears to be heat related.
the h means that your fuser needs to be replaced. it might be fixable by changing the thermal fuse but most of the time the whole fuser needs to be replaced
Sep 28, 2014 | Sharp AL 100DR Laser Toner Drum Works for...
Tip
Copiers Sharp AL-1631 AL-1641CS DESCRIPTION OF SPECIAL FUNCTIONS
Toner save mode
Reduces toner consumption by approximately 10%.
Power save modes
The unit has two power save modes of operation: preheat mode and auto power
shut-off mode.
Preheat mode
When the unit enters the preheat mode, the power save indicator will light up
and other indicators will remain on or off as before. In this condition, the fuser in
the unit is maintained at a lower heat level, thereby saving power. To copy from
the preheat mode, make desired copier selections and press the start key
using the normal copying procedure.
Auto power shut-off mode
When the unit enters the auto power shut-off mode, the power save ( ) indicator
will light up and other indicators except the ONLINE indicator will go out. The auto
power shut-off mode saves more power than the preheat mode but requires a
longer time before starting copying. To copy from the auto power shut-off mode,
press the start key. Then make desired copier selections and press the star key using the normal copying procedure.
Auto clear
The unit returns to the initial settings a preset amount of time after the end of copy, or
scanner job. This preset amount of time (auto clear time) can be changed.
Stream feeding mode
For description of the stream feeding mode, see "Stream feeding mode".
Resolution of AUTO & MANUAL mode
You can set the copy resolution used for AUTO and MANUAL ( ) exposure
mode.
on Mar 14, 2010 | Office Equipment & Supplies
Sharp AL-1631: Flashing H-4. Paper tray light is
H4 indicates that you have no power for your heater lamp. Either the thermostat or the lamp is open. For the thermostat, you can reset it if you know how to remove the fuser section and its cover so you can see the thermostat and reset from there. For the heater lamp, check its continuity using a tester.
Jul 21, 2009 | Sharp Office Equipment & Supplies
Sharp al-1631 copier wont copy
It probably the toner cartrisge is empty or if there's an error code H4, the heater lamp is spoiled
Apr 02, 2009 | Sharp AL 1631 Copier
What is the code to reset the Sharp AL 1631 copier
Sharp - How to reset code
To enter service mode press thesekeys: orange C button,Interrupt, 0, Interrupt. The screen goes black when you have done itcorrectly. It may take a few tries – must be done in certain time.
To clear the maintenance indication (service man): press 20, start,1, start (the display will start to flash when entered correctly).Power off/on to make the copier dude go away. Good Luck!
Jan 31, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 Grayscale Copier Problem
Have you tried removing all cable connections on it and turning printer off and unplugging it from power supply and powercycle?
Apr 29, 2008 | Sharp AL 1631 Copier
Flashing L1 Display
clean the stripe band unther the glass
Dec 26, 2007 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
79 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
