Question about Garmin Forerunner 305 GPS Receiver
Will not turn on, even with power from car power cord
  • 2 more comments
  • monabill Apr 30, 2008
    I know where the reset button is but where is the mode button
    on a garmin nuvi 200w series. thanks.
  • monabill May 05, 2008
    I don't know what i did but it works fine know. I took notice that the red light on the power cord on the car charger was dim but today I plugged it in 5/4/08 and it was alot brighter. strange?
  • c21trudy Jul 20, 2008
    Where is the reset button? Where is the mode button? How do I turn the Nuvi 200 off?
  • RunningL May 11, 2010
    Wow I was about to loose hope for my forerunner and found this post! It WORKED! :) Thanks!!!
  • 6 Answers
To power the unit back on, press the "Mode" and "Reset" buttons at the same time. Let go of those two buttons, press the power button, and the unit will turn back on."
Posted on Apr 29, 2008
Diggs234567 saved the day! press "mode" and "reset" at the same time. Let go and then press the power button. Fixed!!
Posted on Jun 28, 2008
THANK YOU SOO MUCH! That worked perfectly!
Posted on May 01, 2008
Older Toshiba laptop runs on battery, but not AC cord.
on some older laptops the battery has to be installed for it to turn on.
if the battery don't hold a charge it's no good.. but you need it to get power from plug.
Jan 04, 2013 | Toshiba Computers & Internet
All cords are correctly put on, when I turn the desktop on, my monitor doesnt power on, its stay off.
I apologize for thinking so simply, however, your monitor has a separate power button and power cord. Therefore, even if you computer is off, there should be power to the monitor unless the monitor is not plugged in or the power button is turned off.
Check the power button and power cord for the monitor.
Brian
Jan 08, 2011 | eMachines W1700 PC Desktop
My monitor won't even turn on....do I need a new power cord??
try new power cord, or even take out the pc power cord and try that.
or the kettle lead?
Oct 16, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
My acer laptop is turning on plz help me
First check your power cord/charger. If there is a green light on it and it is lit then that is working. Even if your battery is dead it should turn on with the power cord. If your power cord is fine then it is most likely your motherboard.
Apr 15, 2010 | Acer Computers & Internet
Wii will not work. Not even turn on. Not even red light or anything just black.
Try to unplug the AC adapter from the power cord and wait 30 min.Then plug it again.If this not help may the AC adapter is defective.
Oct 16, 2009 | Nintendo Wii Console
Won't turn on even with power cord plugged in
By dumping the power while running you have trashed your Operating System or blown up the Ram
Insert your OS disk and see if it comes to life , if it does then you may have to try a repair from the OS installation CD
If you have popped the Ram then the only solution is to get it checked out on another PC
Jun 02, 2009 | Sony Computers & Internet
Magellan 1200 RoadMate Unit no longer turns on
That means that the battery inside the Magellan must be replaced.
There is need to disassemble the unit to replace the internal battery.
May 21, 2009 | PSC Magellen SL (554030-20150-020)
My wii won't turn on
Pull cord from the wii and the wall for 5 mins to rest the brick on power cord.
Mar 25, 2009 | Nintendo Wii Console
Hp photosmart c4580 won't print
Your problem indicates that your printer is not getting the power supply .
  • Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
  • If the power cord is not damaged, plug the power cord into a different electrical outlet without using a surge protector. The product power light should turn on.
  • If the product power light does not turn on, the power cord should be replaced.
Dec 09, 2008 | Office Equipment & Supplies
Dell latitude d600 doesn't turn on
The test Dell advises to narrow down this issue is to remove the battery, hard drive, ram, and optical drive.  Next plug in the a/c power cord and you should get some LED's coming on. If not it points to the motherboard.
Aug 15, 2008 | Dell Latitude D600 Notebook
Garmin Forerunner 305 GPS Receiver Logo
444 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
