Question about Kodak i 280 Path-Through Scanner
Black line i have a problem with my kodak i280 model a black line appears and desapear randomly while scanning. any hints please
  • 25 Answers
Black lines can be caused by dust on the plastic imaging guides. Some models use a philips screw, older models use a Torx screw to hold down the guides. If you remove the guides, blow it out but don't use canned air. Canned air can leave a propellent film on the mirrors inside. Use a hair dryer on cool, or a air pump blower from walmart ( for blowing up air mattresses).
Then:
1. calibrate your scanner using the Kodak calibration target (12x12). Sometimes a very white 8 1/2 by 11 sheet will work.
2. change your scanner threshold from "ithresholding" to (not sure if I remember it exactly ) but I think it's called "atp." I-thresholding is really agressive at darking your images up, but will also bring out any weaknesses in your camera ccd's.
Posted on Jul 07, 2008
  • zone48
    zone48 Jul 09, 2008
    Also, the scanner camera could have some weak pixels and needs replacing. The lamps for this model last a long time and rarely need replacing. But a service rep will have to replace these items.
There may have dust on inner side of the glass after the lamps.Try clean it.
Posted on May 19, 2008
I have kodak i2600 scanner, when i was scanned document its getting black lines on the document how to solve this problem please help me
Black lines on most any scanner will be caused by dirt in the scanning system, or by a damaged/defective scanner sensor. You can clean the window.
Jul 15, 2015 | Kodak i2600 - Document scanner - 8.5 in x...
Kodak i660 black line on scanned document
The black lines are caused by either marks on the scanning strip or a fault with the scanner. If there are no marks on the scanning strip then there's nothing that can be done without sending it for repair. Details of the cleaning procedure are shown in the instruction manual.
Jul 19, 2012 | Kodak i660 Scanner
I have a kodak esp3 printer and i have never been able to get it to scan. In scan mode it just comes out with black lines I can not find a phone number for kodak on the box or in the box it`s just like...
Dear Sir/Ma'am,
If you get lines on the scans usually the scanner CCD is faulty - Please print a picture and then copy that picture, If the print looks fine but the copy has lines then then scanner on the printer is faulty and the printer would need to be replaced (if in Warranty).
Please then contact Kodak with the outcome of the steps listed above. You can contact Kodak either on 0870 243 0270 or email them on kdisc.allinone.uk@support.kodak,com (UK only)
Regards,
CViveiros
Oct 23, 2009 | Office Equipment & Supplies
The scanner makes unwanted vertical lines down the document
Clean Optical path to camera lenses back and front, then Calibrate through the Kodak SVTool.
Oct 06, 2009 | Kodak i260 Duplex Color Scanner
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
When scanning color document, blue tone is present as background shade
Have long experince with PixEdit program using Kodaks. PixEdit usually comes around it after a firmware upgrade on the scanner. Not sure about this specific model but at least OK on other models of Kodak.
Sep 25, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
I280 won't scan!
ImageCalibration means the cameras don't get enough light during their self test.
Please check the following points:
Are both lamps on or one lamp in case you have a single page scanner?
Are the imaging guides (the clear sheets above the cameras) clean?
Are the little white tags on the imaging guides present?
One tag on each imaging guide.
Without this small white tags the cameras are not able to check themself.
For emergency you can apply a small white paper or white insulating tape instead of missing tags to test the scanner.
If the lamps are light, both tags are present please calibrate the scanner with the kodak calibration sheets. You will find the calibration menue in the scanner validation tool. You can get this tool from the Kodak home page.
Jul 15, 2008 | Kodak i 280 Path-Through Scanner
Kodak Easyshare M753 Problems with lines on the photo
The same happened to my kodak camera of a different model. Maybe an internal crack appeared or something. I took mine back and got a replacement.
Jun 18, 2008 | Kodak Easyshare M753 Digital Camera
Random black lines on scanned slides
Normally dark lines are a speck of dirt sticking on to the glass and when scanned continuously, it appears as a line. Clean the glass thoroughly. Ensure the slides are dust free. If the lines are appearing in different locations, it means the dust gets removed while scanning. Line in the same place could be because of glass is scratched. The above is common with roller scanners.
For fat bed scanners, there will be no scratch on the glass. It must be from the slides/documents
Feb 20, 2008 | Braun MULTIMAG SlideScan 4000
Kodak i 280 Path-Through Scanner Logo
250 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
