SOURCE: pioneer dvd-rw dvr-k17 problem
First lets try uninstalling the device, then on the device manager window right click on something and select scan for hardware changes, also a reboot might be required if this doesnt solve it. then lets find new drivers.
also lets try deleteing the lower and upper filters from your windows registry il post you a video tutorial in a moment.
SOURCE: Wrong region code
Go to device manager and then right click on properties, and then there should be a seciton on region code.
BTW< how the hell do i get rid of the underline?
SOURCE: pioneer DVDRW DVR-K17B ATA Drive
This is my error in report viewer for my dvdrw in laptop.
dvdrw icon is hide and it can't read any disk dvd/cd.
PLEASE HELP ME! THANKFUL
" Windows was able to successfully install device driver software, but the driver software encountered a problem when it tried to run. The problem code is 39. "
SOURCE: my pioneer dvr-k17b ata device
1) uninstall your dvr from device manager
2) write REGEDIT at RUN
3) look for UPPERFILTER using search in the edit menu. After you have found it, delete this registry
4) repeat the same for LOWERFILTER
5) Go to the device manager, scan for hardware changes. Win Vista will now successfully install your DVR
SOURCE: PIONEER DVDRW DVR-K17B ATA Device Issue in HP Pavilion DV9500 Lap
you may need to clean the lens of drive with a wet tissu paper, otherwise the drive might gone out of order, need replacement.
