  • 40 Answers
Posted on May 07, 2008
What is the antenna wire on the griffin fm transmitter
I onistly am a hater of the sweatshop useing Apple but the antenna may just be the wifi system, or a joke gag radio antenna
Feb 21, 2013 | Griffin Technology iTrip Auto with...
FM antenna is not providing reception, despite cable connected to powered antenna amplifier. TV also connected to powered antenna amplifier (splitter) works fine. FM mode produces only static. I purchased...
If I understand your setup, you've connected the receiver antenna terminal to the output of the antenna amplifier. If this is true, I'd suggest trying the receiver using a plain old FM dipole antenna (available at Radio Shack and other stores) or even just a piece of wire hooked to the antenna terminal. You should be able to pick up some local FM stations then.
What might be happening is that the FM is being filtered out by the amplifier. Some amps made mainly as a TV signal booster have an FM trap designed to block the FM broadcast band. In the analog broadcast days, the FM band was right near the sound part of a TV signal, and the trap was there to prevent interference. It may be filtering out your FM band.It may also be possible that you're just overloading the FM antenna input with the amplified signal. Sometimes a signal can be too strong. Using a simple wire antenna will let you test the receiver by itself.
Other than connecting an antenna you shouldn't have to do any setup for FM reception. If you still get no stations at all when using a simple antenna, then the receiver may need service. But I doubt Circuit City would have sold a floor model that was defective, even at the very end, unless it was clearly marked as such and sold "as-is". I'm pretty sure you'll find that the receiver works with an antenna made for FM.
Sep 14, 2011 | Denon DRA-37
Have a Shure SLX Wireless System. The only way the microphone SLX1 or SLX2 is if they are right up to your mouth. If you put the lapel mic on a persons tie you can't hear them. The transmitter is set to...
The Shure SLX2 hand-held microphone has similar performance characteristics to the much-loved (cabled) Shure SM58 vocal microphone. It has a 'cardoid pick-up pattern' intended for close work - being spoken / sung straight into the top of the capsule at no more than about 8 inches from the mouth of the user- to minimise feedback and extraneous noise. If you double the distance between the mouth and microphone the sound level will drop four-fold so distance really matters.
The SLX1 lapel/ lavalier is a semi 'omni-directiona'l pick up pattern microphone, which should work satisfactorily up to 12 inches from the speakers mouth, but closer is better. Always try to get your users to hang it about 6 inches below their chin, at most, and preferably with the top of the microphone capsule pointed upwards towards the mouth.
Here are a few other things for you to try:
  1. There is a volume (gain) knob on the back panel of the SLX receiver unit. Try turning this up to maximum (needs a small screwdriver)
  2. Make sure that both aerials on the receiver are fully extended at different angles to each other and in a clear 'line-of'sight' with the transmitter pack, with no large bits of metal in between which could block the signal. Ideally the receiver should not be more than 25metres from the transmitter. If distance is a problem locate the receiver near to the transmitter and run a balanced (xlr) cable to your mixer/ amplifier.
  3. The angle that the receiver aerials are at should be broadly similar to the angle that the transmitter antenna is at to optimise signal reception.
  4. Make sure the receiver is not located too close to other electrical equipment which may be interfering with the signal (especially voltage transformers, CD or DVD players and hearing loop induction amplifiers which have a strong magnetic field)
  5. Always use good quality batteries - Duracell Ultra or equivalent ( do not use rechargeable batteries as they seldom achieve optimum voltage)
  6. Check that the antenna is tightly screwed into the SLX1 transmitter pack and not damaged.
  7. The SLX2 hand-held microphone has an adjustable level switch inside the body - unscrew the top of the microphone to access it - switch to maximum.
  8. Another possible cause could be an impedance mis-match between the SLX receiver and your amplifier or mixer. There are two outputs on the rear panel of the receiver. One is an XLR (large 3 pin socket) this is LOW impedance and needs connecting to a low impedance input on your mixer/amplifier. You should normally be using this output even if your amplifier has a jack-socket input (use a proper balanced XLR to 6mm trs jack cable rather than a adapter plug). The other output on the receiver unit is a 6mm HIGH impedance, unbalanced, standard jack socket (labelled 'line in'). This would normally be to connect to a guitar amplifier which has a high impedance 'line level' input socket. If you are using this output you may need to use a pre-amplifier to get a big enough signal for a microphone.
You can find the Shure SLX user manual here
Jan 27, 2011 | Shure SLX1 Body-Pack Transmitter for...
Microphone not working
hello there, Many steps to do
1. For your AirLine system to work correctly, both the receiver and transmitter must be set to the same channel. and check to make sure that the supplied receiver and transmitter are set to the same channel.
2. Physically place the receiver where it will be used (the general rule of thumb is to maintain "line of sight" between the receiver and transmitter
so that the person using or wearing the transmitter can see the receiver). The CR77 can be rack-mounted if desired (taking a half-rack
space), using an optional Samson adapter kit. The UM1 can be mounted to a video camera using the supplied velcro.
3. Extend the receiver antenna(s) and place it (them) in a vertical position. Make sure the Power on-off switch in your AH1 transmitter is set
to "Off."
4. Gently pry off the battery cover off the AH1 transmitter and slide it upwards and off to open the battery compartment. Please use care
when opening this cover as undue force will destroy the hinge.
5. Place a fresh AAA alkaline battery in the transmitter battery compartment, taking care to observe the polarity markings. Then replace the
battery cover and gently press down on it until it clicks. Leave the AH1 off for the moment.
6. Make the physical cable connection between the receiver output jack and a mic level audio input of your amplifier or mixer. The balanced
XLR jack is preferable, since it will deliver an electromagnetically cleaner signal. If required, both the balanced and unbalanced outputs
can be used simultaneously. If your system contains a CR77 or UM1 receiver, be sure to set its Audio Output Level switch correctly (see
pages 7 and 9 for details). Leave your amplifier (and/or mixer) off at this time.
7. Turn the Volume, Level or AF Level knob on the receiver completely counterclockwise. Connect the supplied AC adapter to the CR77
receiver and plug it in (the UM1 receiver can also operate off battery power or a 12 volt power supply from a connected video camera), then
plug the adapter into any standard AC outlet. Slide the Power switch in the direction of the arrow to turn on the receiver. If your system
contains a CR77 receiver, its "Power" LED will light steadily red. (Note: The UM1 receiver has no "Power" LED indicator.)
8. Turn on the power to your AH1 transmitter (using its Power on-off switch); the "Power/Battery" LED will flash if the battery is sufficiently
strong (if it lights steadily, the battery has less than 2 hours of power remaining and should be replaced). If your system contains either a
CR77 or UM1 receiver, one of the "A/B Receiver" LEDs will light, showing you whether the (left) "A" or (right) "B" receiver is currently being
used. The CR77 / UM1 meter will also indicate the strength of the incoming RF signal.
9. Now it's time to set the audio levels. Turn on your connected amplifier and/or mixer but keep its volume all the way down. Make sure
that the AH1 transmitter is unmuted (its Mute switch should be positioned away from the arrrow). Then set the Volume, Level or AF Level
knob on the receiver fully clockwise; this is unity gain.
10. Speak or sing into your headset mic (or play the instrument to which the horn mic is attached) at a normal performance level while
slowly raising the volume of your amplifier and/or mixer until the desired level is reached. The UM1 receiver allows you to monitor the
transmission signal using standard Walkman-type 30 ohm headphones connected to its headphone jack.
11. If you hear distortion at the desired volume level, first check to see whether the "Peak" LED on the receiver is lit . If it is not lit, make sure
that the gain structure of your audio system is correctly set (consult the owners manual of your mixer and/or amplifier for details). If the
"Peak" LED is lit, simply move the microphone further from your mouth.
12. Conversely, if you hear a weak, noisy signal at the desired volume level, again make sure that the gain structure of your audio system
is correctly set (consult the owners manual of your mixer and/or amplifier for details) and that the Volume, Level or AF Level control of the
receiver is fully clockwise. If it is and the signal coming from the receiver is still weak and/or noisy, simply position the microphone closer to
your mouth.
13. Temporarily turn down the level of your mixer/amplifier system and turn off the power to your transmitter, leaving the receiver on. Then
restore the previously set level of your mixer/amplifier. With the transmitter off, the receiver output should be totally silent-if it is, skip
ahead to the next step. If it isn't (that is, if you hear some noise), you may need to adjust the receiver Squelch control. When the Squelch
control is at its minimum setting, the AirLine system always provides maximum range without dropout; however, depending upon the particular
environment your system is used in, you may need to reduce that range somewhat in order to eliminate band noise when the AH1transmitter is turned off. To do so, use the provided screwdriver to rotate the Squelch control completely counterclockwise (to the "Min"
position), then slowly turn it clockwise until the noise disappears. If no noise is present at any position, leave it at its fully counterclockwise
"Min" position (so as to have the greatest overall range available).
Thank you and if you any more help let me know and don't forget to Rate
Jan 26, 2011 | Samson Airline 77 Aerobics Wireless...
My box is hooked up but it's saying no signal...I read a post from another person with the same problem and what the "Expert" said. I had already done the scan thing but it's still telling me no...
What type of antenna installation are you using? Do you have it aimed at your local transmitters? Do you have tall trees or buildings that could block the signal? Do you get signal from a low-power analog station in your area (pass-through or direct)? If you have an analog station with a transmitter near that of the digital ones, you'll have some idea of if the antenna is pointed correctly. (Digital signals do not get tuned in the way a weak analog signal does. There is no poor picture option; you either see it or you don't).
Go to or for information on station transmitter locations that you should be able to receive (if in the US). Just enter your address. Antennaweb is very conservative in the channel list even though it assumes an external antenna. Tvfool gives recommended antenna types for each transmitter in your area. The antennas are labeled with a color code by the manufacturer.
If you are sharing the OTA signal from your antenna with several TVs, you may need an amplifier.
I've had one D-T-A box fail due to a lightning strike hitting the antenna; the tuner was damaged by the power surge. I've also had amplifiers that lost the VHF (2-13) channels after a surge. If you have a lightning protection system, check it as well. The simplest diagnostic for these problems is checking if a new D-T-A box or a TV with a digital tuner can scan the channels and then check what the signal strength is for those channels.
Some tuners are more sensitive and will receive a channel that another tuner might not see as a strong enough signal. An amplifier can be useful in this case as well. (With the amplifier that got hit by lightning, one TV was still receivng channel 7 but the signal strength was 1 out of 7. The other TV got no signal due to a weaker tuner. Since that channel was from the closest transmitter, the amplifier was checked once the antenna direction was confirmed to be unchanged.)
I hope this helps.
(Antenna type, tall trees and direction are big issues. I set up a neighbor's DTA with an indoor antenna that got one set of stations. Due to placement issues, their other TV got a different pair of stations with another indoor antenna.)
Dec 10, 2010 | Insignia Digital-to-Analog Converter for...
Can an on-off switch in car antenna help FM transmitter sound ?
  • they are dependent upon the antenna. best thing to do if u want a to spent the time and money to do that would be to install a new stereo witha AUX plugin instead of your FM transmitter
Dec 02, 2009 | Car Audio & Video
Station to get signal from FM transmitter
I put the transmitter closer to  the antenna and it periodically worked. So, I don't there is a specific station.
May 18, 2009 | Audio Players & Recorders
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
Kenwood cd reciever model 241-Sa, fitted by halfords, am receprion very poor, interferance. What do I do? Thanks
Modern AM reception is usually quite bad. We are used to the high quality sound from other formats and FM, AM has a very compressed frequency range so will always sound poor in comparison. The interference could be due to poor earthing or suppression on the electrical equipment in the car. Usual suspects are ignition, wiper motors and fans. A suppressor between the +V and earth usually help, fitted as close to each device as possible. The devices causing the interference can be pin pointed by turning one electrical item on at a time and seeing if it causes a problem. Another issue is that a lot of modern vehicles use the rear screen demister as an aerial, which can cause bad reception and interference. An external aerial is always best.
May 08, 2008 | Car Audio & Video
Electrical queries
What's the question???
Jerry G.
Apr 28, 2008 | Car Audio & Video
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
