Question about Solis Palazzo Espresso Machine
Solis Palazzo Bean Grinding
No instructions came with the machine. What does each of the two adjustments in the bean reservoir do and does + mean finer or coarser
  • 515 Answers
That one with number on is finer or coarser grinding beans, the other one is for how much gram it would grind. + means more gram.
I hope this will help you.
Posted on Jul 16, 2008
Coffee bean light won't go out when full and coffee won't work
Hi coffee friend I have just answered this question. I think
After you have done all the cleaning you have done, you can try this: do check that all knobs correctly set. That the steam spout is closed. that the water tank sitter correctly
Disconnect from power, wait 2-3minutes connect again and hope for the best.
Apr 16, 2012 | Solis Palazzo Espresso Machine
My machine will grind but no coffee is dosed. When I take the brew unit out and open the door above it ground coffee comes out but that same door does not seem to be opening to release coffee during the...
If you don't hear a click 3 times your building up fine ground coffee inside the box that the door works. Your ground is probably to fine and you are using a shiney bean which has more oils in it. Your big dial inside the bean hopper should be on 10-12 and the small knob should be turned down to the neutral position. You might for the first try turn the big dial up to 16 and see if it will work. If it doesn't your going to have to clean the grinder. This is what grinding to fine does. It cakes the grounds.
Jan 19, 2011 | Solis Palazzo Espresso Machine
I accidently poured about half a cup of water into the bean hopper. Now it still grinds beans but it will not start to cycle (the bean light does not turn off). Can i take it apart and dry it out or...
Taking the grinder apart is not easy to do and get it back the way it is suppose to be is not easy. The first thing I would do is turn the big knob to the 18 or max and the small knob to the -, and try again. If that works leave it there for a couple shots to clean everything out. If that works continue. Then while the grinder is grinding, turn the big knob back down to 8-10 and make some more drinks. 6 to 8 is a good start.
If it didn't work you will need directions but the damage may be already done. The burrs ghave no coating on them and they can rust very quickly. you may need new burrs or a new grinder.
I have a saying " If you are working on the water, keep the bean hopper covered and vice versa". Cross contamination will damage the machine very quickly.
Nov 08, 2010 | Solis Palazzo Espresso Machine
What do you do when the grinding blade will not come off for cleaning?
With the bean hopper on, turn the grinder upside down. Rotate the bean hopper to loosen any grounds that might be holding the burr holder. Now remove the bean hopper and try again to remove the holder. Only the outer burr comes off, this way.
Jul 19, 2010 | Solis Maestro G385 Electric Burr Grinder
Oily beans seem to have clogged our coffee grinder up. What can we do?
Rotate the bean hopper counter clockwise until it stops. Lift it off. Remove the outer burr with the 2 wings and clean under the burr. Clean the opening going to the chute for ground coffee(inside where the burr was).
Install the outer burr. Install the bean hopper. Rotate the bean hopper to the French press grind (coarsest) and operate the grinder. This will clean the burrs and the passages. If it starts to clog, repeat the last part to clean the burrs and passage. It must be grinding to go to a finer setting, but you can go to a coarser setting any time. Another thing. Turn the grinder upside down (empty) and rotate the bean hopper back and forth to clean the threads of the adjusting burr..
Dec 20, 2009 | Solis Maestro Electric Burr Grinder
All of sudden my grinder plugs up. coffee settles in around the base of the burr and does not seem to fall into the grind bucket, so the machine still runs but grinding basically stops as no more more...
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Nov 03, 2009 | Solis Maestro Electric Burr Grinder
Solis Maestro Plus: Grinding Adjustment does not move and can not take out Grinding Ring
Sounds like you may have broken off the adjustment tabs on the outer ring. Contact Baratza for help.
Jul 12, 2008 | Solis Maestro G385 Electric Burr Grinder
Solis Palazzo - Coffee grinder seems blocked
Hi there!
This is most likely due to a build up of ground coffee at the edges, and the whole lot has become a solid lump.
Disconnect the machine and clean with a small stiff paintbrush.
This is caused by damp beans, or using dark roast beans, or keeping beans refrigerated. Often it is the coffee oil that causes it.
If there are beans in there and the unit is not rotating, please contact here again.
Thanks......Oh, and rate as Fixya! if it helps you.
Jun 19, 2008 | Solis Palazzo Espresso Machine
Incanto de Luxe always tells me there are no beans in container
I do have the same problem.
I have removed and cleaned the grinder mechanism.
Being an electronic technician I did have a look and tried to find what method they use to detect that the new beans reservoir is empty and I did not see any kind of detector.
I suspect that they monitor the motor current to do this. If it is so would'n it be possible to desable this fonction since it is more then evident when the reservoir is empty or about to be?
Any body knows how they do monitor the status of the new beans reservoir?
Dec 18, 2007 | Saeco Incanto Classic Espresso Machine
Solis Palazzo Espresso Machine Logo
101 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
