Hp 5550 printer problem
You have a paper jam. If you have more paper that is left to be fed than paper already printed, pull it out from the feed tray, if not pull it out from the ejection position. You will not harm your printer.
After you do this, turn you printer off. On your PC's desktop if there is still a printer icon near your clock display in the bottom right double click that and then in the window that pops up drop the file menu down and select delete print jobs. Turn you printer off, shut your PC down. Turn your printer on, press and hold the power on button until you receive a test page or use your menu to select print test page. Also, do a nozzle check and print head alignment too all while your computer is off. Once, done, restart your PC. When you have a desktop, go to start menu, control panel or settings, printers. Select your printer to open up the printer properties page. From this, print a test page. If you have done everything right it should print okay. If you still have a printer icon in the system tray (area next to clock display) double click this again, select any print jobs left in the printer and choose resume or print now or print.
If you have any questions your get stuck, use the comment box below to comment back to me. I'll get back to you as soon as possible to help you out. I'm in and out while operating my business.
Regards,
Worldvet
Could you please suggest what could be wrong with it? Thank you.
I have hp printer deskjet 640 c so I sending print command dos'not printing
than after flash (blinking) orange light what is the most problem ?
the printer collects the paper but fails to print
gnml.
when i send a document to print paper feeding to print but orange light blinking
**** yourself.. that's the only soution. even I have this printer problem that has no solution .
When I try to print my document as soon as it starts the orange light comes on. I have to turn it off and then on again and the document doesn't print.
The orange light is blinking after the paper has been fed but doesn't start printing. I turned it off and it spits out the paper to the tray.
