Question about Samsung SyncMaster 753S 17" CRT Monitor
Focus on monitor
When there is no input to the monitor the sign "No video input" appears very clearly on the screen. When I put the video in the whole screen seems to go completely out of focus and leaves dark bands of colour horizontally across screen. Samsung SyncMaster (793s)
Regards,
Dave.
alexander.dave@gmail.com
  • 1 more comment
  • Dave Alexander Oct 02, 2008
    Thank you seslu666. This week end I will try your suggestion and
    get back to you.
    Dave.
  • Dave Alexander Oct 05, 2008
    Thanks sesylu666,
    Can youn further assist by giving me the location of these filters. I dont have a circuit drawing.
    Many thanks
    Dave (6770)
  • raja 56 Dec 04, 2008
    I have Samsung Sync Master 793s 15" monitor of 2004 September Model.
    Until a week ago time taken to display is instantanious, when the monitor is switched on, but now it takes around five minutes for the display.
    Plz. tell me what could be the problem and how to fix it .
    Problem Solver:
  • 18 Answers
Try replacing the filter capacitors on the video circuit.
Posted on Oct 02, 2008
LCD MONITOR DISPLAY PROBLEM
What your describing is a major video problem, poor color and it is blurr, It would be far cheaper to replace the monitor with a new one.
Mar 08, 2012 | Samsung SyncMaster Computers & Internet
Hdmi screen format problems
try it on av tv it may view and explain briefly i cant understand
Dec 08, 2007 | Denon AVR-3806 Receiver
DISPLAYING ON SCREEN THAT VIDEO INPUT OUT OF RANGE
Right click on the back ground of the computer desktop. If windows XP click properties, if vista click personalise. Now look for settings and move the resolution slider to 1024 X 768. This is the native resolution for this monitor.
If you still have the HZ error, click on advance look for the monitor tab, and make sure it is set to 60Hz
Mar 02, 2012 | NEC MultiSync LCD1525V (White) 15.1" LCD...
My monitor is on but there does not appear to be any graphics. The CPU is also on too. The monitor keeps showing "check signal cabel"
The ideal way is to crros check to see if the PC or the monitor is the suspected fault. So connect an external monitor to your PC and if this works OK then the PC is cleared. Now check the monitor to confirm. If not there are errors in the signal processing section- the point where the input signal from the PC has to be processed. Possible failure of the input IC.
If however the PC does not output it is failure of the graphics card and must be substituted to confirm and replace.
Jul 19, 2011 | Samsung 710V 17" LCD Monitor
Text appears fade & sometimes brightness is found high on screen.
Both are signs of a worn out tube. The only thing you can do (apart buying a new monitor) is to increase the focus and acceleration tensions on the tube - by tweaking the corresponding semiadjustable resistors.
Mar 09, 2010 | ASUS VW222U Monitor
Too much yellow does not adjust with normal drop screen adjustments. can i adjust the light beams.on my philips 50"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Turn the green screen control on the Focus Block until retrace lines appear and gradually turn it back
Until the point where you can see the retrace line disappears, just before cutoff.
2. Turn the red screen control on the Focus Block until retrace lines appear and gradually turn it back
3. Turn the blue screen control on the Focus Block until retrace lines appear and gradually turn it back
until the point where you can see the retrace line disappears, just before cutoff.
4. If the screen still appears too bright after proper G-2 adjustment, you need to adjust the sub-bright adjustment in the service menu
control down until screen cut-off. (Service data Range is usually 21 to 25 in the Service menu, for Sony sets you first go to category "MCP2", & then adjustment item 01( "SBRT")= subright.
For electrical the focus, put on the screen a clear picture of your choice thru an input of the TV set from a DVD, then pause the playback of the DVD Look into each color and rock that color focus control back and forth (turn the control one way then the other way slowing down as the picture goes into the best focus. till the picture looks sharp do each color till they all look in focus. NOTE: it is best to look into each color tube to achieve the best electrical focus. For optical focus please follow the manual lens adjustment in the sets service manual
By Larry Dillon
Aug 27, 2009 | Philips 50P8341 50" Rear Projection...
Flat Panel Monitor: 1907FPt
Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of computer.
  3. Turn on the monitor.
    The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
    1. This box also appears during normal system operation if the video cable becomes disconnected or damaged.
    2. Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jun 04, 2017 | Dell E173FPb 17" TFT LCD Monitor
Western digital world edition 2
My amigo , your monitor is most likely gettin old , Operating systems and video cards do not blur monitors unless you ordered them to do so , I'm a fully qualified monitor technition this stuff happens all the time , basicaly it's the focus block of the monitor , if it's not serious you're lookin at a few bucks to have it worked on , if more serious expect to pay more ,
and if you are me , you put on your ground protection and you open that monitor up and adjust the focus block on the flyback transformer , as CRTs age a bit the focus block needs adjustment , I can also tell you that if you plan on doing it , READ any and all documentation on how to adjust a focus block before you do it , and wear ground protection ( or if you're not scared to die like me , just use your plastic screw driver on the focus block and adjust the little dumpling. it's not rocket science in this particular situation just a focus block adjustment , and if that fails , it's time to chunk it , because more than likely it's about to totaly fail.. and easyer to buy a new one..
focus fuzzyness is a sign of bad things ahead ( 50% of the time. )
Again , if a simple focus block adjustment doesn't do the trick , I'd just chunk it and get another one
unless you're a hardware monkey like me who went to electronics school ...
And above all wear ground protection ...
I'm not responsible for accidental injury or death from following my advice on this , just trying to save your monitor.
as for a solve on this , it's a matter of your willingness to adjust the focus block which is on the flyback transformer , scary and dangerous not recommended for those who haven't made their peace with Elohim and are clumbsy lol
I hope this still gets counted as a solve
shalom >:D<
Jun 19, 2008 | Western Digital 500GB My Book World...
Samsung Monitor Syncmaster 913V Montior Screen shows patches of screen on desktop and playing videos
Sounds like your LCD panel has gone bad.
If the unit is under warranty, take it to a Samsung repair shop. If it is not under warranty, go buy a new one. LCD panels are usually more expensive then buying a whole new monitor.
Mar 21, 2008 | Westinghouse L1975NW Monitor
Irritating display
This is a sure sign in CRT screens that it is on it's last hours of life. I saw this in one of my customer's screens and I told him it was probably dying, it died the next day. You could try opening the menu and hitting degausse or whatever it's called. That helps sometimes, but if this is doing this repeatedly, it means your screen is dying.
Aug 19, 2007 | HP Compaq FS 7550 17" CRT Monitor
Samsung SyncMaster 753S 17" CRT Monitor Logo
184 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
