Question about Lexmark T642 Laser Printer
T630 cannot print color
Where scan and copy everything alright, we cannot print color when we send a word doc to it. Maybe you guys can help. Thank.
  • 3 Answers
Just a wild guess. it may not be capable of printing in color.
check if you indeed have color cartridges installed.
it says B/W - Black and White.
escription: Model ID 0010G0110 / Lexmark T630 - Printer - B/W - laser - Legal, A4, A4 Long - 1200 dpi x 1200 dpi - up to 35.1 ppm - capacity: 350 sheets - parallel, USB
Posted on May 15, 2008
How do I set up on my printer to connect fax
Pl. connect the CO(telephone line) to the socket marked as LINE.
from the key board there is FAX switch select it.
To send a fax load the document face upward, if ADF is used or face downward at platen glass, press SPK or OHD or phone as marked on the key board get the audible dial tone, dial the required fax no. get the fax tone press START. If the display shows sending then alright. If display show !-SENDING,2-RECEIVING, then press the corresponding digit.
Feb 18, 2015 | Samsung Xpress SL-C460FW Laser...
How do i stop my sharp mx 4111n printer from printing with line on the paper
does this happen when printing? or copying? if printing check the fuser, image /drum unit What color is the line replace that image unit, if copying does it happen thru the doc feeder ? if so place on the big glass and make a copy if it goes away the its the doc feeder slit glass that is small glass use by the doc feeder, big glass not used by the doc feeder when copying or scanning
Feb 17, 2015 | Sharp Office Equipment & Supplies
My HP laserjet 3050 when i copy a page the paper prints black
Symptom: Black or Blank image while copying or scanning.
Part suspect rating: Scan head..70%
Scan head cable...25%
For tech guys only: Remove ADF unit from the printer, remove both side covers of adf, remove & replace scan head, check...
Replace scan head
Jul 21, 2012 | HP LaserJet 3050 All-In-One Printer
My brother MFC 8500 is receiving alright but everything I send out has a big black streak going down the right side of the page. Confirmation page also has big black streak.
Let me see if I got this right.
The received fax is clean but when you send one out it has a black streak on it.
Cool! So far so good.
Makes sense because for sending, the fax scans the original document and parts of the scanning area could be dirty and so on. Therefore a black streak may appear.
The same black streak would also appear when you make a copy, because the original document must also be scanned.
However for receiving faxes, the machine uses the internal memory and the print engine only, and the same applies to printing the transaction report, which comes from inside via the print engine.
The scanner has no rol in either situation.
Now I'm lost!
May 31, 2011 | Brother Office Equipment & Supplies
I need to know the settings on the hp photosmart c7200 printer I should be set for me to get the absolute clearest scans of docs and also my drivers license
Hi. Here are the specs of your printer or simply follow this link to know more..
Print specifications -Up to 1200 x 1200 rendered dpi black when printing from a computer -Up to 4800 x 1200 optimized dpi color when printing from a computer and 1200-input dpi -Print speeds vary according to the complexity of the document -Panorama-size printing -Method: drop-on-demand thermal inkjet -Language: PCL3 GUI -Duty cycle: Up to 3000 printed pages per month
Copy specifications -Copy resolution up to 4800 x 4800 -Digital image processing -Up to 99 copies from original (varies by model) -Zoom to 400%, fit to page (varies by model) -Copy speeds vary according to the complexity of the document.
Scan specifications -Image editor included -Integrated OCR software automatically converts scanned text to editable text (if installed) -Twain-compliant interface -Resolution: up to 4800 x 9600 dpi optical (varies by model); 19200 dpi enhanced (software) -Color: 48-bit color, 8-bit grayscale (256 levels of gray) -Maximum scan size from glass: 21.6 x 29.7 cm (8.5 x 11.7 inches)
May 06, 2011 | Office Equipment & Supplies
I am trying to scan a doc on my canon MP272 and just get the numbers : 1, then E then 3. What's that mean?
According to the manual, the error code E, 3, 1 (cycles) means that the printer is not connected to a computer with a USB cable. If you have a cable connected, remove and reseat it, or try a different USB port on the computer.
If you're trying to scan, you need to be able to send the scanned image to a computer. If you're trying to copy, press the Black button for black/white copies or the Color button for color copies.
May 27, 2010 | Canon Office Equipment & Supplies
Al-1540 only scans, wont print says-data could not be sent to pri
it seems that the computer was trying to send the data to the printer through the wrong port. i went to the control panel in windows xp, and selected printers and scanners. and added a new printer (manually) as al-1540 cs on usb port 2. it alerted me that the software was not signed, i proceeded anyways. it asked if i wanted to keep the original printer , i said yes. and the test page printed away. so i would suggest people with similar problem to keep adding multiple copies of the printer again and again on usb ports 1,2,3... etc till it prints the test page. use the copy no. indicated in the printed test page to do all your print jobs in the future.
Dec 09, 2008 | Sharp AL-1540CS All-In-One Laser Printer
When I fax docs, it is received with stripes and stains
first check the printer by copying something,here u can see the problem that u r telling me,or check it by scanning something in ur computer,if u can see that problem,all u have to do is,open the top glass cover, under the top cover thers a scanning unit(lamp unit),in that scanning unit ther are some mirrors clean that mirrors with cotton bud,clean the top glass,n fix everything again,problem will be solved
thnx N
Jan 29, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Fax machine won't copy or send a fax.
Sep 30, 2007 | Brother IntelliFAX 4100 Laser Fax
Lexmark T642 Laser Printer Logo
142 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
