Question about Miele Novotronic W1918A Front Load Washer
Miele w985 washing machine
Hello mr miele,
I have a miele wash machine (w985). when I try to run the machine the water runs through the machine and out of the drain spout on the bottom. Can you assist me in fixing this problem?
John
  • 183 Answers
SOURCE: The washing machine wont start
This indicates either a faulty inlet valve, afaulty pump or a blocked filter Regards Engineer
Posted on Jul 30, 2007
  • 105 Answers
SOURCE: Miele W1903 washer skipping steps (not fully draining?)
check the motor brushes could be worn out
Posted on Mar 15, 2008
mgprice
  • 744 Answers
SOURCE: Miele Washing Machine Code: Check drain
This means that the drain attached to the pump is clogged, remove the drain plug check fro debris and replace...you should be good to go.
Posted on Jun 23, 2009
  • 4 Answers
SOURCE: miele W1712 washing machine drain fault
Just had the same problem, after Much patience and persistence I found the blockage at the y piece that joins the pump to the outlet hose air trap towards the top of the machine LHS with the top and cover off.
It was clogged solid therefore no back pressure on the top little ball valve (between the air trap and the outlet) therefore no seal therefore norain therefore a drain-fault that persists regardless of a cleaned pump filter.
Posted on Dec 04, 2009
  • 70 Answers
SOURCE: What do you do if the Miele washing machine's
The flood protection device has activated. This is caused by a leak in the machine. It can also be caused if you are not careful when checking the drain pump,water may have gone back into appliance and activated flood protection device. If this is the case Tip machine forward,water in base of appliance will run out, and appliance will work.
Posted on Mar 29, 2010
Miele G 641 Plus which isn't washing properly and not draining properly leaving a "oily film like" deposit inside he washer.
As my learned colleague Mr Gallant says, don't turn the pump impeller the wrong way as they are run by a small induction motor. I notice in the manual (page 16) there is a salt compartment in the base. Do you use that, as it is a water softener. If you live in a hard water area, the film you are seeing is calcium. Or in my 45 years experience of catering dishwashers, it is a reaction to the detergent which puts a colourful bloom on the stainless steel. Run a full wash with half a bottle of CLR. That should descale it. Then make sure you use salt or Calgon with each wash.
Regarding not washing properly, remove the wash and spray arms (Page 39) and check that the holes are free of debris. Before you remove them, make sure they spin freely. I wish I had 10 bucks for every machine where the staff say the machine isn't washing properly and it is just that the spray arms have become jammed by food debris or 2 of the 6 holes are full of lemon pips or broken glass. Remove the arms, push any obstructions back into the arms and them flush the out of the large hole in the centre. Let me know how you get on by way of a COMMENT below my name.
Miele 641 Operating Instructions Manual Page 4
Jul 02, 2016 | Miele Dishwashers
Miele 500 washing machine inlet light comes on and machine wont pump water out or spin
try leaning against door when pressing start . if it runs get the switch replaced
Jan 24, 2016 | Miele Novotronic Premier 500 Front Load...
Water leaking into the drum of my Miele washing machine when it's not in use
water inlet value is leaking. turn off water after use until u replace the value or it could start running hard and flood the room
Apr 07, 2014 | Miele Washing Machines
Miele Novotronic w963 motor does not turn after water filling
Hello, my question is, I have washing machine MIELE NOVOTRONIC W 963, is broken, Which Miele model HAVE SIMILAR MOTOR ,thank you . William
Jan 03, 2013 | Miele Novotronic W1918A Front Load Washer
Miele W1926 check inlet light flashes at he end of rinse fill
Hi Yugin.That indicates your machines water inlet valve is faulty.(Means it's taking less water then normal)Please check this steps & do it fast before water inlet is finishes:1-Turn your machine on & run empty with pre-wash cycle first.2-Please ajar the detergent drawer & check runing water on compartment one 3-Please press pre-wash button & compare the running water volume on compartment two.If the running water volume 1 is less then 2 or vs.water valve needs to be replace.That's causing problem.I hope that helps.Thanks.
Jul 26, 2010 | Miele W1926A Front Load Washer
My Miele Touchtronic W1119 shows the error message Drain/Intake Fault. The intake and filters are fine. What's going on?There is no water standing in the drum. How can I reset this?
Hello Buvamo,
You may want to check the water valve and make sure it is all the way up where the intake line is.
The other area to check for water not draining is the lint trap. While the intake/drain fault is on the door will not open for the lint trap.
There is a release lever at the bottom of the machine (Orange in color) that is below and behind the trap door. Just pull down on the lever and that will open the trap door. You may want to put a towel under there as it will leak once the door is opened. inspect and clean the trap and try running cycle again
Sep 13, 2009 | Miele Touchtronic W1119 Large Capacity...
Boiling water in Miele automatic W750
Hi,after posting I had the enlightened idea to run the machine again.Gut told me it was a blip,rather than a defect.Has run 2 cycles with no problems recurring.We keep our fingers crosswise!regards henk
Jan 08, 2009 | Miele Novotronic W1918A Front Load Washer
Miele Novatronic W360
there is still water in the waterproof tray at the bottom of the machine and the float switch has activated. pull the machine out (if pipes allow) and tip the machine backwards to drain the water from the tray.
Jun 01, 2008 | Miele Novotronic W1918A Front Load Washer
Miele novo w526
Can you hear the drain pump running??....If so the WPS system has been activated and there is water in the base.
If not, please post back if any water is going into the main wash compartment once it's started. No water, then faulty inlet valve.
Jan 21, 2008 | Miele Novotronic Premier 500 Front Load...
Mildew Smell
I have no idea if this will actually work, I have never tried it myself, but a guy I worked with on washing machines years ago used to swear by putting 3 DISHWASHER tablets in the drum and then running the hottest cycle that the machine would run (White cottons 90 degrees if you have it).
Any of you have a dishwasher and want to try throwing 3 tablets into the washing machine and reporting back on the result?
Jan 20, 2008 | LG WM2496H Front Load
Miele Novotronic W1918A Front Load Washer Logo
453 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
