Question about EliteGroup P4VMM2 Motherboard
Cmos settings hello, every time i shutdown my computer and open it, the clock always restart to april 27, 2002.. even though my battery is new.. please help me.. please...
  • 76 Answers
On system press del key go to bios reset old settings set new options and press f10 save new settings ok byy
Posted on May 17, 2008
Configure first the cmos setting by means of pressing f8 while booting. then press the load optimal setting and save it.
Posted on Apr 28, 2008
Always resetting the clock
first run bios update program
change new brand battery
if your system is laptop check adapter & main battery
else desktop cross check new smps
if smps problem power off system restart
Feb 20, 2014 | Computers & Internet
What.s the useful of cmos in this board
CMOS Battery powers the real-time clock and CMOS memory, which retains all the BIOS Settings including date.
CreativeTECH
May 04, 2011 | Compaq (203966-001) Motherboard
Computer will not boot past POST and it shows "CMOS checksum error - defaults loaded" on the screen...
good day,
your cmos battery is weak(low voltage) it does not save your bios settings every time you configure it or set it to default settings, it will always display cmos error every time you shutdown your PC, try replacing it with a new one, check the old battery model and buy it in your nearest computer shop, commonly used battery in Motherboards is CR2032 Lithium battery..
Hope this helps.
Sir MArkus
Feb 01, 2011 | Computers & Internet
Clock loses time. Have downloaded latest BIOS update but did not fix problem. Do I need to install a new battery and, if so, how? Computer is a HP Pavilion a6030n running Vista 32 bit.
it is advisable to change your CMOS (complementary metallic oxide semi-conductor) battery. this battery helps save and keep up to current your settings even when your shutdown your machine. if it is weak, then it might not keep the settings properly
Oct 10, 2010 | Computers & Internet
I have windows 7. When I shut down and then restart later or the next day the clock shows the time of shut down and then run ok but I have to reset it or click on internet sync and that works. Then the...
If this is an older PC (3-5 years or more) then most likely the backup battery on the motherboard has become weak.
On many motherboards this is a coin cell, which can easily be replaced (on others it is soldered in, though), just have a look.
Mar 24, 2010 | Computers & Internet
Describe your biostar p4m800-m7a cpu overheats Problem -- CPU runs ~65 degrees with case open. Machine shuts off w/o warning when case is closed, even though CPU cooler fan is exhausted and a 2nd exhaust...
Open your computer BIOS. To do this press F8 when start-up and then once your in the BIOS settings, enter power management section and then look for any settings there relating to temperature automatic shutdown. Save changes and restart computer. If it doesn't solve the problem. Reset your motherboard BIOS to do this, open your computer casing and then look for the BIOS jumper setting, it should be near the CMOS battery. Refer also to the motherboard manual to do this.
Hope this could help..Please don't forget to rate me..:-) Thanks..
Nov 08, 2009 | EliteGroup P4M800-M7 Motherboard
Clock not keeping correct time
The CMOS battery keeps the laptop configuration stored in the CMOS chip and the main battery has no effect on the CMOS.
If the date and time drift off, it indicates the CMOS battery is nearly flat and needs to be replaced.
If you had ticked the Daylight saving box in the Time Zone tab in Control Panel - Date and Time setting then the time would automatically adjust for Daylight saving.
Apr 05, 2009 | IBM ThinkPad T40 2373 Notebook
Cmos
Hi stan_z4, do you have the manual for you're board?
I'm showing the P4VMM2 is made by ESC = EliteGroup.
Which is not listed above (Intel D845EPI).
If you do have the board EliteGroup P4VMM2 than turn to page 11 in the user manual. The jumper for the cmos/bios JBAT1, Pins must be set to 1 & 2. If JBAT1 is set to pins 2 & 3 you will reset you're bios every time you boot up.
Don't have you're manual? Click on the link.
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=272&DetailName=Manual&DetailDesc=P4VMM2%20%20(V3.2A)&CategoryID=1&MenuID=82&LanID=0
Mike
Apr 28, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
EliteGroup P4VMM2 Motherboard Logo
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
