Question about Toshiba Satellite® P105-S6084 PC Notebook
Crash dump blue screen
I ll be computing along and wamo blue screen and a crash dump screen takes a *&%$$ on my computer what can I do ..?
  • fightingtige Mar 24, 2009
    I also have a toshiba satellite and its been doing the same thing.
    Scholar:
  • 186 Answers
If warranty - call it in. Otherwise it sounds like a classic case of bad ram. Find a friend with similar ram in his/her laptop and do a test swap to see if symptoms repeat. Then replace the ram. Far more common in HP's then Toshiba, but it happens for no reason. Basically it's a page in or out error with the ram causing windows to "freak out".
You can get a good selection of ram from Tigerdirect.com or newegg.com.
Posted on Apr 28, 2008
Lenovo g550 laptop with an external monitor would only display of broken original screen after crash dump
Firstly you need to get your external monitor working. Have you tried pressing FN+F3 while turned on, (may take several presses).
If you can get the external monitor working then you'll need to run windows in safe mode and try removing any new drivers you installed. or try a 'Last Known good' on start up this depends on the OS version.
Nov 19, 2014 | Acer Computers & Internet
When the computer is starting up PRESS & HOLD the "F" key which controls the external monitor. It may be F4, F5, F6. You should get image on the external screen. Go into video properties and select dual monitors or allow computer to use external display or something like that.
Crash dump when burning dvd's in premiere elements 7
Checking Event Viewer should give you more details. Right click My Computer > Manage > Event Viewer. Check Application and System by Source. You can filter by warnings and errors in View Or try another burning software. CDBurner XP is free.
Aug 26, 2012 | Adobe Photoshop Elements 7
Blue screen appears & keep restarting
It is possible that the malware is to blame, in which case a computer technician will need to sort it out.
I think it may be a bad memory module or loose memory module connection.
Take care!
damnor01
Apr 28, 2012 | Acer Extensa Computers & Internet
Memory dump blue screen
Sounds like you are having an audio driver problem try using a different driver for your sound card
Jul 01, 2017 | Computers & Internet
When I start my computer a blue screen pops up then it crashes. It has text on it but I don't get a chance to read it.
download Microsoft Debugging tool here
just select the version of your computer (OS and if it is 32bit or 64)
install it.
then check this link on how to use the windows debugging tool
click here
Every time that there is a blue screen error or a stop error, windows generates a dump file that has the details about the crash error. the dump file is located in this folder
C:\windows\minidump
you have to run the debugger, click on file, select ran deugger for crash error then after that browse to that folder and lod the minidump file.
in order for you to fully understand how to user the windows debugger, you have to read the link that i posted above.
the result of debugging will give you a detailed analysis on the problem, it could be driver issue, or the device or the OS itself
Sep 14, 2010 | HP Pavilion zd8000 Notebook
Physical memory dump
Hmm... Well a Bluescreen is when your computer crashes, and (as you have found out) preforms a physical memory dump. This can be caused by multiple things. Such as bad drivers, PFN(page frame number) or problems with your memory. When a bluescreen event occurs, the is a technical information which has an error code that can be used to help find the problem. In order to fix this problem, you may have to remove any software, or hardware that you have recently installed. To uninstall software, you may need to boot in safe mode, which is where your computer starts up using the minimal amount of drivers needed, in order to try to prevent the computer from crashing.
Here are some useful websites (sorry, my hyperlink icon isn't working):
  • www.datarecovery.com.sg/data_recovery/hard_disk_symptons_blue_screen.htm
  • www.maximumpc.com/article/features/blue_screen_survival_guide
Feb 27, 2010 | Dell Dimension 8400 PC Desktop
System crash after upgraing memory for acer aspire 4315
If u have 2 ram in 1 computer memoryh frequence
conflict betwwen each other if both r differ.
So cheange yhour ram and check both rammeoroy frequence are same .
Mar 26, 2009 | Acer Aspire 4315 Notebook
Computer will not start
When Windows crashes with blue screen, it writes a system event 1001 or 1003 and a minidump to the folder \windows\minidump. Check system event 1001 and 1003 and it has the content of the blue screen
Event ID: 1001
Source: Save Dump
Description:
The computer has rebooted from a bugcheck.The bugcheck was : 0xc000000a (0xe1270188, 0x00000002, 0x00000000, 0x804032100).
Microsoft Windows..... A dump was saved in: .......
Event Source: System Error
Event Category: (102)
Event ID: 1003
Description:
Error code 1000007f, parameter1 0000000d, parameter2 00000000, parameter3 00000000, parameter4 00000000
Control Panel -> Adminstrative Tools -> Event Viewer -> System -> Event 1001/1003. Copy the content and paste it back here
Aug 17, 2008 | HP Compaq Presario SR1230NX (PJ518AA) PC...
2 problems in one
Depending on what operating system you are using, I suggest repairing the operating system. For windows xp here is a guide that you can follow http://www.michaelstevenstech.com/XPrepairinstall.htm.
For windows vista
http://www.bleepingcomputer.com/tutorials/tutorial148.html
Apr 16, 2008 | Acer Aspire 3680 Laptop
Toshiba Satellite® P105-S6084 PC Notebook Logo
228 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
