Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
No cartiridge My black ink said it was empty and I took it out but it was still half full and so I put it back in and now it says that there is no cartiridge. Please help
  • 832 Answers
Generic ink? If yes, the cart circuit board has a short circuit. This cant be repaired!
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002400/000087/faq002487_000.html?reg=us&c=us&lang=en&prod=mfc440cn_all
Posted on Apr 28, 2008
When I put a new Black ink in my Canon MX452 it shows my black as empty
Hi
if the black cartridge is genuine and new...take it back. It is faulty.
If the cartridge is refilled or compatible...hold the STOP button for 6+ seconds to disable ink monitoring. This should clear the 'empty' error and the printer should work again.
good luck!
May 17, 2014 | Canon PIXMA Office Equipment & Supplies
My printer problam is cartiridges indication are continue red.but printer cartirides ink full cartiridges ok. ple.help me.
The indication is only an aproximation. If you refil your cartridges or use reworked cartridges the printer will record them as empty.
Mar 03, 2011 | Computers & Internet
Replaced two ink cartridges now the other one says it's empty. It was just half full before.
Try to reseat/ remove the cartridges and put it back in. If it is still the same, try to put the old ink in and check if it will still show half full, if it does, it means that there might be something wrong with the detector on your printer. But usually, printers have this issue but will fix itself in 24 hours. It is just a lag in the printer's counter
Sep 05, 2009 | Office Equipment & Supplies
HP Deskjet 5740 I have not used my printer in some time and both cartridges are half full. It printed with the black but came out with gaps in the printing so i took the cartridge out and put it back...
it is better to change the black cartige becaue there is the jam of the ink in black cartidge. or pick out the black cartidge and clean with soft paper in the place from where color is pour. then reinstall the cartidge. i hope it will ok. otherwise, change the cartidge.
byee
May 09, 2009 | Office Equipment & Supplies
Black Ink wont work.
I would take the ink cartridge out, grab some rubbing alcohol and a q-tip, and wipe the bottom of the cartridge where the ink gets dispersed. You should see color on the q-tip after just a few swipes. Return cartridge back into printer and give it a go!!
Please be sure to rate this solution.
Regards,
Joe
May 08, 2009 | Brother MultiFunction Center MFC-440CN...
Can't Print with black ink because all color ink are empty.
yes you need to install all cartridge before printing any page ...I have also this model...but u need to install all 4 cartdge. before printing any page wheather color or blacknwhite..
Jan 08, 2009 | Office Equipment & Supplies
Ink Cartridge
Some of Epson's cartridges went bad that way. It may be a bad cartridge. Get a new one, pull that one out and see what happens. If it works, call Epson for a refund. They had a class action suit for that type of thing, they lost and paid off. I would think they will help you right away.
C
May 31, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Printer says ink near empty
Black electrical tape works like a charm on a Brother MFC-465CN. Thanks for the tip! :-)
Jan 16, 2008 | Brother MFC 210C All-In-One InkJet Printer
Can't print when there's only black ink
Mostly it connot print w/out color ink if when printer message empty / sometimes the printer no message while ink was empty still black can print. it depends to the chip .
Jan 11, 2008 | Xerox DocuPrint M750 InkJet Printer
Misreads ink tanks: says full ones are empty and there are 2 cyans, etc.
I had the same problem -- error message saying two cyan print tanks installed. Nothing helped (including disconnecting power cord). Then found I had an older cyan print tank still in its pack on hand, Installed that. No further problems. Assume this means print tank giving error is part of a faulty batch so am returning to retailer for refund from Canon.
Oct 24, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
32 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
