I have an ASUS P5S899-VM motherboard and wish to install 2 x 1gb Samsung ddr PC3200 184 pin ram. Is this ram compatible with the motherboard? Many thanks, Colin Sinclair.
  • stephopper2 Apr 30, 2008
    Your response was very helpful. The spellin attrocious but understandable. I suppose the spelling rates low as long as the solution is right. Thanks very much.
    Scholar:
  • 115 Answers
First you have to know the mother board supports the ram with ddr 1 and ddr2 . Now the new technology motherboard are supports only ddr2 ram and the ddr1 ram are consider as the older version. But ASuS P5S899-VM is contains the new technolgy of ram slot please see the manua or the mother board box. there you can see which it supports.please check it
Posted on Apr 28, 2008
1GB PC400 RAM does not work with motherboard A7S266-VM/U2
Hello the home page is here:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=10&m=A7S266-VM%2fU2&os=&hashedid=n%2fa
If any drivers or manual needed select first your windows.
Click on global for download.
Unzip the file and you need a pdf reader (adobe) to read the content.
Here are some specification about you mainboard:
2 x DDR DIMM Sockets
Max.2GB unbuffered PC2100/PC1600 non-ECC SDRAM Memory
2 x SDR DIMM Sockets
Max.2GB unbuffered PC133/PC100 non-ECC SDRAM Memory
(Note: DDR ram and SD ram memory can not be used on A7S266-VM/U2 simultaneously)
This means you can`t use SD RAM together with DDR ram.
The bios could have a setting for this because of the use of 2 different ram types.
Try downloading the manual.
Good luck
Nov 18, 2012 | ASUS A7S266-VM/U2 (A7S266-VM/U2/LAN)...
Compatible memory at 2gb capacity and video card for asus p5pe-vm motherboard
Hi, you can download a manual here at asus:
http://www.asus.com/Motherboards/Intel_Socket_775/P5PEVM/#download
Dual Channel Memory Architecture
2 x 184-pin DIMM Sockets support max. 2GB DDR400/333/266 non-ECC, unbuffered DDR RAM memory
1 x AGP 8X slot.
Hope this will help you.
Aug 14, 2011 | ASUS P5PE-VM Motherboard
I need to know the correct ram speed for the Asus P4B533 board, thanks.I have 3 slots. I want to install the maximum possible.
here you go mate:
Memory Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 2 GB
Dec 01, 2009 | ASUS P4B533-VM Motherboard
Ram supported by asus motherbord p5p800-vm<green>
Memory should be same as the one that is in the motherboard . Each motherboard support only one type of memory. Search on the internet for the type of motherboard for memory supported with it. If it says other than DDR2/ DDR3 then the motherboard wouldn't support the memory. Do some searching like motherboaed p5p800 and see few websites for specification for the motherboard, check the memory specifically for the details.
Sep 18, 2009 | ASUS P5P800-VM Motherboard
Which kind of RAM my motherboard is compatible?
It supports maximum of 2 GB of DDR RAM
DDR here means DDR 1 and not DDR2 or DDR3
Rate it, if it helps.
Aug 04, 2009 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
I can't recognize what specific RAM this motherboard accepts..
Dear sir,
In reply to your post- Generally now a days we use DDR400 RAM(DDR 1) for this type of motherboard.So DDR 400 RAM is More compatible then other RAM,you can use this RAM for your motherboard to obtain good performance.
good luck
chandrashekhar
Compatiblity issue..
You may install up to 4GB of DDR RAM in this motherboard. It does not use DDR2.
This is from your manual:
Dual-channel DDR400 memory support
Employing the Double Data Rate (DDR) memory technology, the motherboard supports up to 4GB of system memory using DDR400/333/266 DIMMs.
If you would care for the manual, here is a link:
Asus P5P800-VM Manual
Thanks for using Fixya.
Apr 03, 2009 | ASUS P5P800-VM Motherboard
DDR2 RAM for P5RD1-VM
The ASUS P5RD1-VM takes the PC2700/3200 DDR SDRAM DIMMs. You can upgrade your ASUS P5RD1-VM to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory. For best system performance use the maximum amount of allowed Memory per slot for your system i.e. 1 GB.
Thanks
Iqbal
Apr 14, 2008 | ASUS P5RD1-VM Motherboard
Its about the memory card
The board supports upto 4 GB RAM. PC3200 RAM is supported.
1. Reset CMOS settings by CMOS jumper.
2. Try updating BIOS of your motherboard from :
http://support.asus.com/download/download_item.aspx?product=1&model=P5GL-MX
Best of Luck,
rajesh_im
Feb 13, 2008 | ASUS P5GL-MX Motherboard
Intel ASUS P4 845 GL Motherboard
Hi, For an ASUS P4BGL-VM Intel 845GL Chipset Ultra ATA100 MATX CPU Type: Intel Pentium 4 478-Pin (OEM), the Asus site specifies max of 2 x 184-pin DIMM Sockets support max. 2GB PC2100 / PC1600 non-ECC DDR or SDRAM memory but not "and". Personally, I find it more practical to install 2 X 1Gb rather than a single 2Gb. Hope this gives you some idea. Kind regards.
Aug 07, 2007 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
