Question about Raymarine E120 GPS Receiver
I have a Raymarine L755 chart plotter that is continuously rebooting. It shows the initial screen and holds it for about 5 seconds and then beeps, reboots and the cycle starts over.
  • deltaguila Oct 09, 2008
    New Friend:
  • 132 Answers
Press and hold menu during power on and see if you can get it working. press and hold 1st softkey during power up to reset
Posted on Jan 17, 2010
    Scholar:
  • 76 Answers
Make absolutely sure that all of the buttons are clear (not stuck). After that, begin by unplugging any external interfaces (including the chart card) one by one to determine if one of those is the culprit.
Posted on Sep 06, 2009
Raymarine dsm300 Circuit breaker keeps tripping g when connected to chartplotter
either the cord to the chart plotter is faulty or the chart plotter itself is dead short
have an electrician do an insulation test and circuit test on the cord and plotter unit
Jan 08, 2017 | Raymarine Boating
I have problems with my plotter Raymarine Rc 435 chart plotter.This plotter can not location my ship to do.What is problems?
Be sure there isn't any aluminum in close proximity to your GPS antenna, or that your antenna is not to close to other powerful electronics. Aluminium reflects electromagnetic signals and other electronics emit EM fields as well causing disruption of your GPS signal reaching your antenna.
Sep 26, 2014 | Raymarine Rc435 Chartplotter
My Raymarine C80 CHart plotter won't load.
Check to see if this is a power issue by connecting to shore power and fully charging your batteries overnight with instruments off. While still connected to shore power, with batteries fully charged, turn on C80 navigation system. If the loading screen comes on and does not reset, then try holding down the button immediately to the right of the red power button for at least 3 seconds to see if the system re-boots.
Apr 13, 2010 | Raymarine C80 GPS Receiver
The chart plotter worked perfect for 5 yeas,
I think you have a C- Map card (black colour)clean the contacts with a contactcleaner if it not works try the card somewhere else
The C-Map card have problems that they work for a while and than stops inside the card a some memorychips and they losing contact
Sep 27, 2009 | Raymarine A65 Combo GPS...
The display of the C70 has stopped working. Instead of a picture it only shows either vertical bands of color or just black/white vertical/horizontal lines. Occasionally the display comes back but only for...
I recognize the problem. It mostly occurs when the plotter is exposed to moist during some days. The contactstrip which connects the computer to the screen gets moist and does not conduct in an optimal way. The result is a non readable screen with stripes
The solution is simple: press on the edges of the screen and the contact is re-established.
Jul 18, 2009 | Raymarine C70 GPS Receiver
I have a Raymarine L755 chart plotter that is continuously rebooting. It shows the initial screen and holds it for about 5 seconds and then beeps, reboots and the cycle starts over. I have a L755...
Send it to Auckland back they can install witha C-MAp card a new
Software.
BUT it is verry important that you make after the instaltation a MASTERRESET.
If not you will have the same problem in a few month again
Jan 04, 2009 | Raymarine L755 Plus GPS Receiver
RAYMARINE
With the charts page up, start by hitting the find ship softkey at the bottom of the screen.If that find the boat on the chart all is good.If not you need to check you have a GPS fix. Go to GPS screen and see you are seeing satalites.
If all is good when you hit find ship and the boat disappears again from chart while underway you will need to go into the chart setup menu and see if the screen amplifier is turned off. If off turn on.This is first place to start. Hope that helps
Jul 13, 2008 | Raymarine A65 Combo GPS...
RL70CRC crashes with new "Wide" C-map cartridge
get a new burn on the chip, I have seen this issue on a particular burn.
Mar 22, 2008 | Raymarine RL70CRC GPS Receiver
Raymarine RL70CRC GPSRadar
Hi Matt,
There is a feature in these chartplotters called "Plotter Mode" that is often misunderstood and causes the exact problem you describe.
Press menu.....chart setup.....and scroll to the bottom until you see Plotter Mode in the list of options. It should be set in the OFF position.
If you have more than one display networked onboard check the setting in each one invividually.
What Plotter Mode does is allows the chartplotter system to access range scales not supported on the chart. It is not normally used for map-based navigation but more so for chartless electronic plotting (it can display routes, waypoints and track-recorder breadcrumbs.) open-ocean cruising, or for ultra-precise GPS operations (like a precision anchor drop, finding a very specific location etc. When plotter mode is on you can zoom in to a very, very small working area. The indicator it is enable is the cross-hatch background on the screen, the lack of map information, and the NO CHART DATA watermark on the screen.
Jul 30, 2007 | Raymarine RL70CRC GPS Receiver
Raymarine E120 GPS Receiver Logo
281 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
