Question about Brother GX-6750 Typewriter
Printing wrong letters and numbers
My typewriter is printing the wrong numbers and letters
  • 9 more comments
  • Lori Rath Jun 05, 2008
    types only the symbols when I try to type a number. do not have the shift depressed or the caps lock on at the tirme.
  • unclenudie Jun 20, 2008
    typing wrong letters and symbols, when i hit a letter it shows a symbol
  • darlene240 Jul 15, 2008
    My typwriter is still printing wrong letter & numbers. I have turned the machine off and it did print correct letters & numbers for awhile, but it is back to printing incorrect letters again. I turned the tywriter off &on it did not help this time. What else can I do?
  • courtyardest Jul 16, 2008
    its typing the wrong numbers letter ans symbols.. i can have this we type up leses all day long and not iots not working, what do i do to fix this?
  • kikbch Oct 07, 2008
    I have tried turing it off and on and its still happening
  • collins5284 Oct 23, 2008
    wrong letter are printed with hitting the key
  • ATRUNOSKE Oct 29, 2008
    i am having the same problem. can you send me manual also for this brand. i am desperate to have it work to type a resume and cannot afford to replace it right now. thank you. my email is atrunoske@yahoo.com
    thanks, amy
  • Anonymous Dec 23, 2008
    me too!! help!!
  • Anonymous Jan 07, 2009
    Brand new and not typing the correct letters!!! Turning it on and off doesn't do a thing!
  • Anonymous Jan 11, 2009
    ok is there another solution besides turning it off and on cuz that dont fix the problem
  • dwhiteturkey Jan 12, 2009
    My typewriter is printing the wrong numbers and letters.
Typing wrong letters.
Please help immediately
Posted on Sep 17, 2008
    Problem Solver:
  • 4 Answers
You may have moved print wheel and it is out of timing.Turn machine off and on again and see if the problem is fixed.
Posted on May 01, 2008
5 Suggested Answers
  • 3594 Answers
SOURCE: Is there a way to set typewriter to type numbers and uppercase?
There may be a caps key. You can get a manual @ brotherinternational.com, click on support.
DickyO
Posted on Apr 21, 2010
  • 19 Answers
SOURCE: GX6750 Typing wrong letters
Linda,first of all,does the daisy wheel spin when the typewriter is first turned on? if it does,then you will feel assured that it is installed properly. Next, refer to your manual to key board settings. It will indicate that there are settings for normal standard English keyboard and somehow that setting may have been changed. It would be also be important to check the daisy wheel to see if it is compatible with standard English keyboard...Cheers, John
Posted on Oct 21, 2007
SOURCE: wong letters & numbers
I downloaded the manual from http://www.devicemanuals.com/downloadguide.php and then, following the instructions there, I removed then re-inserted the daisy wheel. This solved my problem. Perhaps it had somehow gotten out of adjustment. At least, it is something to try if you haven't tried it already.
Posted on Jul 26, 2008
  • 3594 Answers
SOURCE: I began using my typewriter this morning...and
Turn it off and on it should go thru it's dance and rehome the print wheel. f you are notin KBII , language mode or the print wheel damaged the homing pawl for the P/W is probably broken you need a tech.
DickyO
Posted on Jun 09, 2011
When I push the letter "G" , for example, a
If the printwheel isn't distorted or you aren't in KBII or a language mode the printwheel homing pawl is likely broken. You need a tech.
DickyO
Sep 01, 2011 | Brother GX-6750 Typewriter
I began using my typewriter this morning...and when I press a number or letter...it types the wrong number, letter, or symbol. For example, I press the letter "F" and it types a number...
DickyO
Jun 09, 2011 | Brother SX-4000 Typewriter
Letters on the keybords are all wrong
hi
i thing you software is not working you have to chack your manual
May 28, 2010 | Nakajima AE-830 Typewriter
When typing wrong letters and numbers type
You might have a "proportional space" printwheel but the pitch selector is on 10, 12, or 15 instead of PS. OR it is on PS but you have a normal print wheel. Try selecting different pitches. Another thing that causes that problem is sometimes the ribbon or correction tape gets caught in the printwheel.
Feb 18, 2010 | Swintec 7040 Typewriter
My keyboard does not display the letters I am keying
Just a little help from you. Does it type the wrong letters or not type some letters at all? Is the display right and print wrong or viisa versa?
DickyO
Nov 20, 2008 | IBM Wheelwriter 30 Typewriter
Brother EM530 Typing Wrong Letters
Hi there. Take out the printwheel and see if any of the spokes are bent. That would cause wrong letters. . Also if the print solenoid(piston) does not go in and out freely. Lawrence
Aug 06, 2008 | Brother ML-500 Typewriter
Types wrong letters
It sounds like you have the 10,12,15,PS selector switch on PS with a 10, or 12 print wheel installed. Return to the left margin, move the switch to 10 and type.
Jun 25, 2008 | Swintec 7040 Typewriter
Erronous letters or numbers
Under the ribbon there is a motor that drives the print wheel try to get some light oil on the front and rear bearings (wd 40 usally works well) its a little hard to get to the rear one.
hope this helps
DickyO
Jan 29, 2008 | Lexmark Wheelwriter 1000 Typewriter
Types wrong Characters
Does it always type the same wrong letter ie a always prints u or w ? if so the print wheel drive gear is out of position. if not and it get random letters some thing may be interfering with the wheel rotation.
Jul 04, 2007 | Smith Corona Wordsmith 200 Typewriter
Brother GX-6750 Typewriter Logo
1,283 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
