Question about Car Audio & Video
Gas the needle that shows the amount of gas in my 1979 caddilac coupe deville is stuck on full and doesnt move what can i do
Buy a ford.
Posted on Oct 06, 2008
  • 47 Answers
REPLACE IT
Posted on May 28, 2008
Why does my check gas cap light continues to flash in my 99 caddilac deville
Hello Bridy, It is telling you to make sure the gas cap is tight. If that does not help, I would try a new gas cap.
Mar 26, 2015 | 1999 Cadillac DeVille
GAS HAND WAS ON 1/2 TANK THEN WENT TO FULL
Some cars,if you put fuel in the tank while the car is running,the gas needle want show the right amount of gas until you cut the car off and then restart it.If it still on full and want move,you will need a fuel pump.
Jan 20, 2015 | 2007 Ford Edge SEL
I baught a 1984 caddilac coupe deville that was sitting for 7 years and when i try to start it sometimes it turns on for like 5 seconds and turns off. If i try steping on the gas pedal it turns off...
check your timing. Cadillac use to use a plastic timing gear that would easily strip. Replace it with an aftermarket gear made of metal and you won't have problems for a long time. Why they used a plastic timing gear is the stupidest thing I have ever heard of and when I found that out I vowed to never buy a cadillac again.
Aug 29, 2014 | 1984 Cadillac DeVille
Transmission shifting problems
Yes ,you need to replace only ,after checking vacuum line that runs to it and make sure it's working correct
Apr 14, 2014 | 1998 Ford F250 SuperCab
Replace shift modulator 1979 cadillac coup deville
The governor likely failed. Not a difficult part to find or replace.
Apr 14, 2014 | 1976 Cadillac Deville
Wiring for the spark plug wires on a 1979 cadillac coupe deville 7.0 litter
http://www.google.com/imgres?q=firing+order+1979+cadillac+coupe+deville+7.0+liter&um=1&hl=en&tbo=d&biw=1536&bih=764&tbm=isch&tbnid=arLZV9-vZloLEM:&imgrefurl=http://www.fixya.com/cars/t4749618-order_wires_go_distributor_cap&docid=83fngwJsiEaf3M&imgurl=http://c.fixya.net/fixya20/uploads/images/23D7821.gif&w=300&h=300&ei=UKmxUIv-FMiNqgHJ_YD4Ag&zoom=1&iact=hc&vpx=1274&vpy=134&dur=1083&hovh=225&hovw=225&tx=142&ty=158&sig=106859446883706597375&page=1&tbnh=135&tbnw=136&start=0&ndsp=30&ved=1t:429,r:6,s:0,i:102
Nov 25, 2012 | 1976 Cadillac Deville
I rebuilt my carbs and now the number one carb spitts gas out. also when i hit the gas it stalls unless i give it full throttle checked the spark and it is great
CHECK THAT YOU HAVE PROPER FLOAT HEIGHT AND THAT THE NEEDLE VALVE IS NOT STICKING. I HAD A SIMULAR PROBLEM ON MY 1979 GS850 ALL I DID WAS TAKE OFF FLOAT BOWL AND ADJUST FLOAT HEIGHT A LITTLE AND CLEANED NEEDLE OFF SEEMS TO HAVE WORKED NO GAS ON OUTSIDE OF CARBS NOW
Oct 10, 2010 | 1979 Suzuki GS 750 E
Gas gauge is not reading correctly. Shows a full
the problem is caused by a defective gas gauge sending unit, this part is located inside the gas tank, you must remove the gas tank to replace it.
Dec 02, 2009 | 2002 Cadillac Deville
Car Audio & Video Logo
74 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
