UMAX Astra 3450 - can't e-mail jpg pictures
Hi...I have an old Astra 3450 that I am using to scan some pictures. I have set jpg as the file format under preferences....I have successfully scanned all the pictures...the problem is when I try to upload the picture so I can e-mail it (using hotmail account). It does not upload the picture. Any idea what is going on? I need help. Thanks,
  1. dsffsnjgdgdjanfxcbxdfhdfbzcbz
Posted on Apr 28, 2008
1) How to Detect Automatic PageSize (eg. Remove Black Color of Scanned Image at the end of the Page.) 2) Compression Using JPEG Compression. 3) Set Name Rule and File Format How to set all...
I presume that you are using CapturePerfect ver 3 as scanning software. Please select "Auto-detection" under page size and also 'deskew' using both Roller & Image' under filters. Under file format, you need to select JPEG. Naming convention is available, however I'd suggest that you choose the name which is convenient to you. Multipage is NOT available with JPG format.
S. Mohan, Chennai, India
Jan 11, 2011 | Canon DR-9080C Path-Through Scanner
How to scan documents and save them as jpg Format as default instead of tiff?
On some copiers, there is an option to scan as JPG. Press the Scanner function key on the left, and look for a button on the screen that says something like "Scan as file type." Press this button, and if that copier can scan JPG files, you should see the option there. Otherwise you might have to scan as TIFF files and then use a program like Microsoft Office Picture Manager to convert them to JPG images.
May 21, 2010 | Ricoh Aficio 1035 Copier
How do i scan a document and then email it
If you haven't done so, install the cd that comes with the HP Officejet package. Once correctly install, you should go to "All Programs" and locate "HP Solution Center" Click on HP Solution Center, click "Settings", click "Scan settings and preferences", choose either "scan document" or "scan picture" If word document then under File type: locate "PDF(*.pdf) If document is a picture then under File type: locate "JPEG image(*.jpg), click ok. Step 2 Choose between Scan Picture or Scan Document, click accept Step 3 your file is locate under "My scan" Hope that helps
Jul 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Recognizing hardware on a Mac OS X Tiger
Try just using the epson scan utility
1. Launch Epson Scan by going into your HARD DRIVE, APPLICATIONS, and EPSON SCAN.
2. If prompted, select your scanner from the list of models and click OK.
3. In the FILE SAVE SETTINGS window, you can designate the location, name and type of file the scans will be saved as.
-LOCATION defaults to HD/USERS/(YOUR USER NAME)/PICTURES. Click CHOOSE if you wish to change this.
-PREFIX determines how the scan will be named. Type any name you like. You can also designate a start number.
-FILE TYPE dictates what format the scans will be saved in. ie. .JPG, .TIFF, .PDF, or .PICT)
-For example: if the prefix is "img", the start number is "1", and the format is "JPG", the name of the file saved in
PICTURES will be "IMG001.JPG"
4. Click OK once settings are changed as desired.
5. The EPSON SCAN window will open and begin scanning in FULL AUTO MODE. In FULL AUTO MODE the software makes all the decisions for you (as to what is being scanned, where it is on the flatbed, etc). This is the easiest way to scan.
6. If you want full control over the scanning process click PAUSE and change FULL AUTO MODE to HOME MODE or PROFESSIONAL MODE. In the latter two modes you can change your scan settings as desired. Click SCAN after you have selected your settings. Click CLOSE once the EPSON SCAN is finished scanning.
7. When scanning is complete, your images will be saved in the location specified on FILE SAVE SETTINGS, with the prefix and in the format you set.
Aug 06, 2008 | Epson Perfection V100 Flatbed Scanner
HELLO
Use the following steps to scan with the Epson Scan utility:
1. Open Epson Scan by going into START, PROGRAMS, and EPSON SCAN.
-LOCATION defaults to MY DOCUMENTS. Click BROWSE if you wish to change this.
PICTURES will be "IMG001.JPG". More settings for file format are found under OPTIONS.
Jun 22, 2008 | Epson CX8400 All-In-One InkJet Printer
Epson
I know the error is on the printer but it may still let you scan.
Jun 06, 2008 | Epson CX8400 All-In-One InkJet Printer
HP Scanjet 3500c
the scan light is very weak and my pictures turn out red, blue or yellow
Oct 30, 2007 | Umax Astra 3450 Flatbed Scanner
Setting the format of the picture i scan
Ok I am not sure why ya scanner won't save in JPEG .. however converting the files to JPEG is relitively "Simple". After saving the Scanned picture.. Open it up in say MS Paint, Painshop etc, then simply choose "Save As.." from the File Menu, and save it as a NEW image file this time with a JPEG extension. IE: origional... picture.png or picture.bmp ... save as ...picture.jpg .. ya should be good to go. :)
Jun 14, 2007 | BenQ 5000U Scan to Web Scanner
59 people viewed this question
k24674
jasbo
jasbo
