Question about HP Compaq Presario SR1300NX (PP195AA) PC Desktop
Turning on my computer
How do I stop programs from opening when i switch my computer on?
    Brigadier General:
  • 6,966 Answers
Try:
1. Start/Run, type "msconfig" less the quotes;
2. in the System Configuration Utility window click on the Startup tab;
3. Uncheck those that you would not want to run on startup. An example is Google updater;
4. If you are referring to built-in Windows Services, this could be done on the Services tab. An example is Windows Time;
5. Another that you can work on is Start/All Programs/Startup/
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 28, 2008
  • Louie  Role
    Louie Role Apr 28, 2008
    Hi prasannakuma, sorry for doubling up.
  • Louie  Role
    Louie Role May 01, 2008
    Glad to be of assistance and appreciate the rating too.
    Scholar:
  • 115 Answers
If you are using windows operating system go to star menu and run , in that run program type msconfig and press ener then go to startup tab select and unselect the program what you like to run on the startup and apply and save the settings and restart the computer after when you restart the window comes please select don't show this message again and close these are first step you want to stop the process when startup please check it.
How to Disable Internet Access?
Disabling Firewall Access for Windows Programs
  1. Go to the Control Panel. Click the "Windows" key or the "Start" icon, then click on "Control Panel". ...
  2. Open the Security Center.
  3. Open Windows Firewall settings. Open the "Exceptions" tab. ...
  4. Open the program and try to access the Internet.
http://schematicscom.blogspot.com/
http://electrotechnician.blogspot.com/
Oct 18, 2016 | Computers & Internet
Just today, the turntable won't stop turning when the door is closed.
have you pressed the stop button twice when the door is closed to exit the program set for cooking
Dec 17, 2015 | Microwave Ovens
Salvaged washing machine. Works, but lid switch faulty, operated continuously so Replaced. Problem now is H & C water stops & starts, agitator turns slowly and then stops and beeps after a minute?
a lid switch only stops the program when the lid is lifted
that will stop any operations involved and in progress
so there would be no water in, bowm turning, agitator action until tye lid is closed where the program is resumed
check how you installed the switch and is it adjusted properly
it is also possible the same swotch that stops the machine when unbalanced
Jul 07, 2015 | Fisher and Paykel Dishwashers
I have a Dell Latitude D630. When the laptop is switched on it emits a high pitched scream and will not boot. I disabled microphone in BIOS and machine boots fine. Re-enabled microphone and same probl
It sounds like a driver problem, normally the microphone is off on-boot-up. It should only be opened by a program wanting to use it.
Have you tried turning it off in the operating system, rather than the BIOS?
Download the correct drive here.
Product Support Dell US
Feb 11, 2015 | Dell Latitude D630 Laptop Computer PC...
BRIGHTNESS symbol on desktop-- how to get rid of it
Most likely a program that loads when your computer starts..
Click your start key and type: msconfig hit enter.
This program is very similar to a light switch. Turning startup programs off and if you need them (any) turn them back on. As you can see my own msconfig. Anti-virus will run, but other programs are turned off. Now all you have to do is figure out what program it is.
This of course is the easy direction to try first.
Apr 07, 2014 | Computers & Internet
I have a Packard Bell touch screen computer and when I try to open several programs the computer freezes with the message 'Program has stopped working' Any assistance with this problem would b
Some programs need a substantial amount of RAM and in case of computers with smaller RAM, they tend to freeze. Either close some of the running programs or increase the RAM capacity. In every likelihood it should work.
Apr 01, 2012 | Packard Bell Computers & Internet
While attempting to connect to a lan connection, the computer automatically defaults to the work offline selection. Therefore, I am never able to connect to the internet. I tried turning off the work...
Hello brian _I_kilm, there are (4) four different ways to connect to the Internet.
In the (right "start menu" pane), select the Control Panel shortcut.
Once the next window open; scroll to find,paul7of9_21.jpg Network and Internet,
click on it to open. Next, select to open the "Internet Options." paul7of9_22.jpg
To setup the Internet Connection: Click on the "Connections" block, click the ("Setup") button,paul7of9_23.jpg and follow all the instruction carefully.
2) From the "Start Menu" in the (right) pane, if you have the "Connect To: Icon, click on the icon to open; "this will start the setup and connection process."
3) Click on the "Start" button, select to open "All Programs," next scroll to find: the Product's name; example (Toshiba), click to open. "If there is a ConfigFree icon present? paul7of9_24.jpg Option is available?"
Select to open, and click on the Connectivity Doctor,paul7of9_25.jpg follow all instructions thereafter.
4) From the "Start Menu," click on the "All Programs" scroll to find: Accessories.
Select to open and check to see if you have the paul7of9_26.jpg [Windows Mobility Center]?
Open the program. There will be a Wireless Network {Turn-on / Off} Switch. paul7of9_27.jpg
  • Important "Always! Click Apply, Ok, and Restart the computer after making changes to the computer."
Did this solution help? If so; "helpful Rating Feedback is appreciated, thanks paul7of9.
Feb 15, 2011 | Toshiba Satellite P105-S6197 Laptop
I read all the feedbacks on how to uninstall but i cannot get it to work. First of all When i try to install K9 again it pops up a window saying there is a updated version would i like to install, I click...
Sounds like some kind of so called security software. I take it you'd like to get rid of it permanently so your computer functions properly? I would use system restore to go back to the date to before you installed the program. Go through proper instructions will stop and restart without k9 being on your system.
Dec 16, 2009 | Dell Inspiron 1501 Notebook
Installing AVG 8.5 on Windows XP professional getting error 0xc0070002. What is the fix?
Your computer's processor blocked an activity of a program by stopping the computer from working to prevent the activity from being executed (also known as DEP or Data Execution Prevention) and giving such error instead.
Try turning off the DEP for all programs by:
- opening Start > Control Panel > System
- Click on 'Advanced' tab
- In the performance area, click 'Settings' button
- A new window will appear
- Click on 'Data Execution Prevention' tab
- Click on the upper radio button (run DEP only for Windows services)
- Restart your computer
If it doesn't work or is turned off for all programs already then there seems to be a problem with your Windows (since you said that IE takes 100% CPU process), or the antivirus program isn't really compatible with your hardware and/or driver software.
thanks and regards
kindly rate this solution
Oct 28, 2009 | Computers & Internet
HP Compaq Presario SR1300NX (PP195AA) PC Desktop Logo
83 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
