Question about Sony Walkman D-EJ360 Personal CD Player
In hold mode
How do I get out of hold mode?
There's a little slider button on the bottom of the cd player. I'd forgotten it was there until I was looking for something else.
Hope it's as simple as this! Good Luck!
Posted on May 12, 2008
How do I program the Venstar T1010 digital thermostat. I did not receive a manual with it.
Venstar has the documentation for the T1010 thermostat on their Small series (Residential) support page: http://venstar.com/thermostats/small-series/literature/ . The direct link to the user manual is currently http://files.venstar.com/thermostats/small-series/documents/T1010ManualRev1.pdf .
To set the time, press Mode and Fan at the same time and hold for 2 seconds. This will put the unit into set up mode. Use the up/down arrows to change the currently flashing item. Press and hold Fan while pressing either the Up or Down arrows to quickly change the item. Press Mode to move between time sections. After you advance to the section for heating/cooling mode, you can press Mode to change between the available options. Press and hold Mode and Fan to exit this setup area.
Press and hold Mode and the Up arrow for 2 seconds to program the timed heating or cooling intervals and temperatures. Press Mode to move between time period, desired temperature for heating or cooling for that time interval and the next time period. Use the Up/Down arrows to change each section. When finished, press and hold Mode and the Up arrow to exit.
I hope this helps.
Aug 12, 2017 | Heating & Cooling
How to put iPad 1 in dfu mode
Hi No 1 plug iPad to Mac or Windows. ,2 MAKE sure iTunes is running (3 turn off iPad .step1 press & hold down On/Off button for 3 seconds step 2 Swipe the slide to power off step 4 press&hold down On/Of for 3 seconds. Step 5 press & hold down the home button on the front while holding down the On/Off button step 6 keep holding down both buttons for 10 seconds ! If U c the apple logo U have held them down to long..start. Again...step 7 let go the On/Off button but keep holding the home button for 5 seconds.if U c plug into iTunes screen U have held it to long ..start again. Step 8 IF THE SCREEN STAYS BLACK"THATS IT" YOURE IPAD SHOULD B IN. DFU MODE.. i tunes should alert saying it's detected youre iPad and will allow it to b restored. If U c any logos U might b in recovery mode but not in DFU MODE IF RECOVERY MODE WORKS GREAT IF NOT TRY FOR DFU MODE ::::: good luck
Oct 26, 2016 | Cell Phones
How do I turn on the Rear Command Dial in my Nikon D80 Digital Camera?
That depends on what you want the command dial to do. If you're in either the Manual (M) or Shutter Priority (S) modes, the command dial will change the shutter speed. If you're in the Program (P) mode, the command dial will shift the program exposure. If you're in any other exposure mode, the command dial does nothing.
If you hold down the metering mode button, the command dial will change the exposure metering mode.
If you hold down the exposure compensation button, the command dial will change the amount of the exposure compensation.
If you hold down the release mode button, the command dial will change the release mode.
If you hold down the AF button, the command dial will change the autofocus mode.
If you hold down the QUAL button, the command dial will change the image storage mode.
If you hold down the ISO button, the command dial will change the ISO.
If you hold down the WB button, the command dial will change the white balance setting.
If you're looking at the menus, the command dial will navigate the menu.
If you're reviewing pictures, the command dial will move to the previous or next picture.
Hope this helps. If you still have problems or other questions about this, please don't hesitate to reply to this post.
Jun 29, 2011 | Cameras
My scale is frozen displaying f--h how do I fix this? I tried holding mode and tare and turning it onon and that doesn't work any other suggestions?
Reset it!
Turn off the scale. Press and hold the MODE button and turn the scale on. Release the MODE button you will see the scale's internal count.
Press and hold the TARE button then press (don't hold) the MODE button you will see the full capacity is changing. Keep pressing the MODE while holding the TARE button until you see 100.00 on the screen. The reset is completed. You may need to recalibrate the scale after the reset.
Nov 09, 2010 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Wolf Induction cooktop is locked in Showroom mode
If Shr (5hr) appears on the display then the cooktop is in showroom mode. To exit showroom mode the cooktop must be locked by pressing and holding the key symbol for 5 seconds. After the cooktop is locked, press and hold the melt touch pad for 5 seconds.
May 01, 2010 | LG 30" Built-In Electric Induction Cooktop...
My recovery mode says "enter USB2.0 MSD mode" what do i do
Hi there.
I can understand your issue. When you say "enter USB2.0 MSD mode"getting into recovery mode. Then i'd say firmware needs to be updated..
Please follow the steps..
There are files in the player that might be corrupted causing the device to freeze and stop responding.
SOLUTION 1 - Reset the device.
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
NOTE: Resetting will turn the player off while it is frozen.
SOLUTION 2 - Force MSC or Recovery mode then update to the latest firmware.
STEP 1 - Force MSC or go to Recovery mode
For e200v1/e200R (Recovery mode only): Connecting in Recovery mode
1. On your Sansa player, press and hold the Power/Menu button for 15 seconds to turn the device completely off.
2. Slide the Hold switch so the orange portion shows.
3. On your PC, double-click My Computer
4. On your Sansa player, press and hold the REC button while connecting it to the PC.
5. Release the REC button when a 16MB-FORMAT drive partition appears under My Computer.
For e200v2 (Force MSC mode only): Enabling MSC mode
1. Turn device OFF.
2. Slide the hold switch to the direction of the headphone jack so an orange color would show putting the device on Hold.
3. Press and hold the ( |<< ) button while connecting the device to the PC.
STEP 2 - Update to the latest firmware manually, as it is described in Method 2 http://kb.sandisk.com/app/answers/detail/a_id/306/kw/e200/r_id/101834.
In case you have any further inquiries, please do not hesitate to contact us!
Jan 04, 2010 | SanDisk Sansa e200 MP3 Player
Silent mode been activated and cant turn it off
Press Down & hold the "#" key for few seconds. it will do the trick
Mar 23, 2009 | Samsung SGH-J600 Cellular Phone
Need to activate Music on hold mode
The newer model RCA phone will do music on hold. There is a jack on the back of each phone, you plug a cd player or MOH device into it and it will play on ALL of the phones(not just that one).
Dec 23, 2008 | GE RCA 4-Line Speakerphone
To Enter/Exit Silent Mode
Silence the tones your keypad makes when you press a key.
• In standby mode, press and hold # key. Entering Silent Mode briefly appears in the display and your phone returns to standby mode.
peace!
Dec 08, 2007 | Samsung SCH-a870 Cellular Phone
How do you get in USB mode?
If you cannot change the "modes", you will have to put it into recovery mode to fix it. You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Download and run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://sandisk.com/assets/file/downloads/firmware/e200fw01.00.12.exe Best of Luck.
Sep 16, 2007 | SanDisk Sansa e250 MP3 Player
Sony Walkman D-EJ360 Personal CD Player Logo
214 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
