My computer says there is a paper jam but there is no paper in my printer. I can make a copy and it works just fine. So I know my printer has no paper jammed in it.
SOURCE: Lexmark X3350 Printer
i think i found a solution for this.
its happen when you insert the papers to deep in the paper
jam jusy try to pull out the papers.
if its print its great , if not it should say load paper so in that
moment push the papers a little deeper.
SOURCE: Lexmark X5470 printer says, "Clear paper jam, then press check mark."
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
SOURCE: Paper Jam
Sometimes the "paper jam" with no paper is due to the printer not being able to feed paper in to the machine. You send a print job to it...printer attempts to feed paper but can't...then you get the paper jam message and ofcourse there is no paper in the machine. Powering off and on should clear the message. Make sure you clear the print job from the print que or the same thing will happen on power off/power on because the computer will still try to send the print job to the printer when turned on. I have found that all of HP's machines that have this style of paper feed mechanism fails prematurely. The pickup roller is too small for one but as soon as the roller is coated with dust it begins to fail. You can take a Q-tip and go in from the back to try and clean the roller. Water is fine.
Inkworks
866-381-0541
SOURCE: printer keeps reading paper jam
We had exactly the same problem (and this printer had never been used before) - we fed a piece of thick-quality paper, applied a little pressure from the top edge as it descended, and 'voila' the printer has finally fed one sheet right through.
What it is NOT yet doing is aligning correctly with the top margin of the document - it is more or less cropping off the top portion, but I'm trying to finish taxes and this will darn well do for now.
These printers are cheap plastic junk, manufactured to make the trip to landfill as soon as possible. Damn Canon and all the other corporations making these trashy pieces of electronics. (I still have a LaserJet 5MP, and I'm sure HP hates me for it - circa 1995 manufacture). If I can figure out how to get printer drivers for OS 10.5 (mac) it will leave to see more service still. Grrrr.
SOURCE: My 5610 wont print on cardstock, creates paper jam!
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD
lost, Scanner does not work, Connection problem etc. For find all these software solution
just click here....
http://www.hp.com/printer/prob676ijt65/solution
alkkk-2
