Question about Astra Mega II Espresso Machine
Astra Mega II <----Need help!
Hi!
I work at a busy coffee house in Honaunau Hawaii. We have a Astra Mega II espresso machine that we keep super clean and makes great espresso!
We recently had our Repair guy leave the Island. And we are having some problems with our machine. The right group head leaks when a shot is pulled. and the Left side is not working at all. No water is coming out. Is it possibly a gasket?? Is this something I'll be able to fix on my own?
Please help!!
Mahalo!
Francesca-
  • Anonymous Mar 14, 2014
    astra mega II have a high water pressure
The left grouphead sounds like a different problem than the right group head. For the left grouphead, I would start by replacing the group electro-valve. With hard water, this can cause the valve to remain in the closed position even though the water pump is running.
For the right group head, I would want to see this happen. Usually, if the gaskets haven't been replaced in a while (if you are busy, your 'while' may be quicker than others), I would evaluate the condition of the rubber gasket. I would also look at whether you are tamping too much espresso grounds into the portafilter. This can cause a similar symptom as a bad gasket.
Posted on Sep 13, 2008
I had the same problem with mine so I removed the front cover and cleaned the calcium build up off the nozzle. It takes a little disassembling of the the nozzle but it solved my slow dripping.
Posted on Aug 08, 2008
My astra espresso mega 2 s boiler pressure is 0.
It is possible that the safety thermostat on the boiler has tripped. Reset safety thermostat and turn machine on. If reset is not tripped then it could be the element or the pressure stat are damaged.
Aug 01, 2014 | Astra Mega II Espresso Machine
My Astra Mega II Espresso Machine doesn't seem to be pumping water in when i turn it on it makes a distict click after a second
There is either 1 of 2 things going on:
1 - The machine does not need water or
2 - The inlet solenoid is damaged.
If the boiler is full the machine will not call for water, to test this you could remove the top panel and disconnect the level probe, then turn the machine on, if it calls for water then the boiler was full and it did not need anymore. If it does not call for water then the inlet solenoid is possible damaged. To Check the inlet solenoid which is on the bottom right of your machine, you can do a resistance check on the coil, to make sure it is working, and or loosen the output of the solenoid to see if water is flowing when it is calling for water.
Apr 03, 2011 | Astra Mega II Espresso Machine
I NED DE MANUAL ARMED
You can obtain the manual by contacting Astra:
www.astramfr.com
(877) 340-1800
Mar 03, 2011 | Astra Mega II Espresso Machine
Astra problems with water...
The gauge needs to be replaced, you might be able to do it if you have the part.
Apr 06, 2010 | Astra Mega II Espresso Machine
How to use the astra coffee espresso
Hello there:
here is a couple of links that will help you get the right manual that you need ok?
best regards michael
  1. CoffeeGeek - Espresso: Espresso Machines, Astra Boiler Level Control ... i got the user manual, and a parts list from Astra, and am attempting to ... Expertise: I love coffee. Espresso: LM GS3. Grinder: Mazzer. Vac Pot: have one. Drip: no ...www.coffeegeek.com/forums/espresso/machines/407128 - Cached
  2. CoffeeGeek - Espresso: Espresso Machines, need help understanding my ... Astra recommends a particular type in their user manual, but there are better ... Expertise: I love coffee. Espresso: Astra Pro. Grinder: Macap M4 & Digital M4, BV ...coffeegeek.com/forums/espresso/machines/378621 - Cached
  3. Espresso Grinders Coffee machines, Grinders,parts, Slush machines ... HGS007 Astra home espresso grinder with timer for direct ... MDF manual. MDF Exploded diagram. Virtuoso Conical Burrs Espresso Grinder. Virtuoso user's manual ...saecoparts.com/EspressoGrinders.html - 235k - Cached
  4. Astra Espresso Machines Espresso machines, Grinders, parts, Slush ... Astra Mega III Manual rocker switch dosing 220V 5500 Watts 18 liter boiler ... All Astra machines operate with ground coffee and / or pods interchangeably - no ...www.partsguru.com/AstraEspressoMachines.html - 162k - Cached
Sep 15, 2009 | Coffee Makers & Espresso Machines
Where to get it repaired?????
Try Mr. Espresso in Oakland, CA www.mrespresso.com. While they don't typically supply Astra, I believe they are familiar with the brand and can refer you to a technician if they can't service it themselves. Astra will also service their own machines, but you would probably have to ship it to their shop in LA.
Apr 17, 2009 | Astra Mega II Espresso Machine
I NEED AN OPERATION MANUAL FOR AN ASTRA MEGA II C ESPRESSO MACHINE
Hi, I'm new to the coffee business and justed purchased this machine and no manual as well.
I just called the astra manufacturer (1-877-340-1800 ) and they were going to e-mail me a manual free of charge. Hope this helps. J Howell
Jan 23, 2009 | Astra Mega II Espresso Machine
Whistling sound
The Astras have a vacuum relief valve, usually located on the boiler top. It looks sort of like a cap, with a pin or rod sticking up out of the middle, possibly with a ring through the end. While the machine is cold, you might try working that back and forth to see if it is stuck or not. If it is stuck, get it replaced.
Dec 07, 2008 | Astra Mega II Espresso Machine
Is the Astra Mega ll capable to pull a good shut with a 21g Basque?
Do it. It has the horsepower. You will probably just need to program the shots accordingly, and maybe get a deep basket for your portafilter.
Nov 06, 2008 | Astra Mega II Espresso Machine
Astra Mega IIC startup issues
Go ahead and keep the sensor probe connected. Open up the steam wands before turning the machine on the let the air bleed off as it fills. The element should not turn on if the water level is too low and the circuit is working properly. As for the groups pumping water, try hitting the Brew Stop buttons. If that doesn't work, something may be wired wrong, or your group solenoids may be stuck.
Sep 13, 2008 | Astra Mega II Espresso Machine
Astra Mega II Espresso Machine Logo
391 people viewed this question
Top Astra Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Kolbrun...
Are you an Astra Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
