Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Cleaning of mirrors - Mitsubishi WD-52525 52" Rear Projection HDTV
  • Anonymous Sep 21, 2008
    i am having the same problem that this guy is having how do you clean the projection tubes in this tv so i can get the HDtv part looking sharper cuse if i open this thing and dont know what i am doing i am going to be pissed
    Problem Solver:
  • 11 Answers
I have been fighting a dark screen almos impossible to see dark scenes
i found this from another person
the mirror has dust on it easy fix
remove front of screen by removing screws around the top and sides of the back don't forget to pop off the bottom cover in the front it just pulls off
then remove center cover screws
i could not disconnect the front electrical plug but it has enough slack to lift and then tip the front screen down to the floor
it will be obvious on the mirrors there is a big one it wasn't to dirty
lean in and look down there is a small mirror and lens they were filthy
there is a piece of foam trying to keep the dust out it was sucked backed so dust could get in
clean with windex and paper towels cloth didn't work
good luck
Posted on Dec 13, 2008
I have a hitachi 55vf820 lcd rear projection tv. How do you get the cover off to clean mirror?
Don't try that as the mirror almost never needs cleaning and MUST be cleaned with a special cleaner---leave a single fingerprint on that mirror (or a smudge) and it will stand out in the picture like a sore thumb.
Reason to clean mirror?
Apr 09, 2012 | Televison & Video
I can't find any documentation on how to remove the primary mirror for cleaning. I'm a newb and don't want to mess anything up. Thanks, Bob
First -- how do you know the mirror needs cleaning? Did you shine a flaslight down the tube and see some dust? Never use a flashlight to determine if a mirror is dirty-- they are ALL dirty when you use a flashlight to check them.
Only clean the mirror if it is interferring with the views through the scope.
There is a ring around the back-- remove those screws and the mirror should come out-- don't driop it! Then remove the mirror from the mirror cell.
Sep 03, 2011 | Celestron Advanced C10-NGT (600 x 254mm)...
My canon np6050 xerox machine doing darker copy . please tell me what can i do for it
just clean the optics mirror to clean those mirror remove the 2 screw in right portion of the machine the 2 screw is the lock of the metal plate in the right end portion of the platten glass the after you remove the screw remove the metal plate & platten glass then move the scanner assembly in the middle portion then you will see a mirrors wipe it with clean rugs then after you clean those mirror remove the 3 screw in the black cover inside the right portion of scanner after you nremove the 3 screw & the black cover you will see 2 mirror wipe it with clean rugs the after you clean the mirrors return all the cover you remove &the platten glass & metal plate then try to make a copy
Dec 08, 2010 | Canon Office Equipment & Supplies
Mirror cleaning
Never touch the mirror! If there's something on it, take it to an expert. Why do you need to clean the mirror anyway? It's out of the way during a shot on a DSLR...that is what you have...isn't it? You didn't say.
Mar 13, 2010 | Cameras
Replace side view mirror 2002 chevy tahoe
Once you've purchased a replacement mirror glass based on your specific make, model and year simply follow the steps below:
  • Remove all existing glass from the mirror head's plastic inner platform (backing plate).
  • Clean backing plate with rubbing alcohol. Clean back of replacement mirror with Burco Window Glo or other glass cleaner.
  • Apply the Burco Redi Stick adhesive patches and or silicone/urethane to the replacement mirror's back or to the backing plate itself.
  • Align and press replacement mirror to the backing plate.
  • Clean the installed Burco Redi Cuts mirror with Burco Window Glo or other urethane-safe glass cleaner.
Oct 09, 2009 | 2002 Chevrolet Tahoe
How do you replace the driver side rear view mirror on a 2007 Toyota Sienna?
  • Clean backing plate with rubbing alcohol. Clean back of replacement mirror with Burco Window Glo® or other glass cleaner.
  • Apply the Burco Redi Stick® adhesive patches and or silicone/urethane to the replacement mirror's back or to the backing plate itself.
  • Clean the installed Burco Redi Cuts® mirror with Burco Window Glo® or other urethane-safe glass cleaner.
Aug 04, 2009 | Toyota Sienna Cars & Trucks
Pentax ME super dirty mirror
Don't even think about cleaning the mirror in your SLR. For smudges and marks that can't be blown away with a handheld blower, you really need to have it cleaned by a repair shop. Most technicians clean mirrors with a special viscous fluid specially formulated to protect the fragile surface of the mirrors. Definitely do not attempt it with a standard lens cleaning solution or cloth as you could cause irreparable damage.
Keep in mind that this will not require disassembly of the camera, so the charge should be nominal
Nov 24, 2008 | Pentax ME Super 35mm SLR Camera
Cleaning mirror
Hello mrdish,
the mirror is in the attached to the top rear panel, remove the top rear panel to clean the mirror.
I hope this helps,
Thank you,
Shuttle83
May 22, 2008 | Pioneer PRO-510HD 53" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
447 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
