Question about Garmin nuvi 350 GPS Receiver
Problems with the window mount that comes with the Garmin 360
The Garmin 360 I purchased works fine, but I can't figure out how to attach it to the window mount. The window mount came with two pieces, one attaches to the GPS system, and the other attaches to the windshield. I can't figure out how to attach the ball joint on the windshield part to the mount that attaches to the GPS system. Is there some other piece I'm missing?
  • 1 more comment
  • Anonymous May 01, 2008
    the same Problem
  • Anonymous Oct 15, 2008
    We have Garmin 360, GPS purchased from Amazon.
    Cant figure out how to use window mount.
    The pieces(round ball, and whole ) does not fit right into each other.
    Please help
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    And don't try to push it on with the Nuvi attached. You take the chance of cracking the screen!!
You just have to push the ball part on the window mount into the socket part that holds the GPS. It's pretty tight, so you have to press pretty hard.
Posted on May 06, 2008
HOw do you charge it?
This unit comes with a charger (AC). There is alxo a car charger. Both have a USB connecter that plugs into the side of your unit.
Sep 20, 2011 | Garmin nuvi 350 GPS Receiver
I can't figure out how the two pieces of the window mount fit together. Do you have an illustration of how it assembles?
The arm of the Garmin G-Ball Suction Mount snaps into the back of the cradle.
You can see a picture of it here.
http://www.gpscity.ca/garmin-nuvi-12xx-13xx-and-2xx-suction-mount.html
Sep 16, 2011 | Garmin Nuvi 265W GPS Receiver
How do I attach my garmin to my dash mount?
The Garmin Nuvi 255w comes with a three piece dash mounting kit. A round disk smooth on one side tape on the other to affix to the dash (most dashes ar textured and the suction cup will not hold to textures) a suction cup arm with a ball end, and a bracket with a receiver for the ball. Snap the bracket and arm together, this can take a little effort. mount the disk to your dash in a place that doesn't obstruct your view of the road. then place the arm/bracket on the disk and push the lever down creating suction to hold the mount to the dash.
Another option it the beanbag dash mounts that hold the arm without sticking to your dash.
If this answered your question please check +. If not please elaborate on your queston
Apr 26, 2010 | Garmin nuvi 255W GPS Receiver
I purchased a locked garmin 360 and need to know how to unlock it. Thank you.
you need to call Garmin to get unlock code. u must of misplaced it or didnt come with one.
May 07, 2009 | Garmin NUVI 360 GPS Receiver
Garmin nuvi 360 suction cup knob issue
If the end of the cradle has a ball,and the cup has
a round part, just push the ball in, yes it does go in hard but should be ok. If it makes you feel more
comfortable, you can put a drop of water on ball and wipe it around, once it dries, it wont slop around.
Apr 09, 2009 | Garmin 010-10723-03 Suction Cup Mount...
Suction cup problem
Make sure your windshield and the bottom of the suction cup is clean. Clean it with some warter & detergent and wipe dry. Try wetting the bottom of the suction cup before applying it to the window.
I recommend not using the window mount. I recommend using the dash friction mount. You take the risk of cracking your LCD screen when it falls.
1. The dash friction mount will not fall.
2. It's easily removable/
3. It's legal in all 50 states (window mount is not).
- Jim
Nov 05, 2008 | Garmin nuvi 350 GPS Receiver
Garmin car charger
There are thee ways to charge the Garmin 750, 1: thru a car cord that plugs into the base that your unit mounts on. 2. Thru an AC charger. 3: thru the USB port on the Garmin unit itself. In your case the car cord plugs into the base that mounts your unit to the window. If that is not working, check that you are getting power from your car receptical. Check by plugging your Phone in or buying an adapter at Radio Shack that checks it. Also check the plug that goes into your car recepticle. Your manual tells how to check the fuse that is located in the end of the plug. If neither of these work your mount connection is bad. Hope this helps
Aug 02, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
I have two NUVI 660's and one 360 (?) navigation systems. They all work great except all three have the same problem with the suction cup. Aftera few months, they will not stay attached to the...
Hello rkfowler,
While the suction cup mounts included with most GPS units are very effective, they certainly can fail. It sounds like you are doing everything you can to make it work: cleaning both the windshield and the cup itself. You also might try putting a few drops of water onto the suction cup before affixing it.
If the suction cup mounts aren't working out for you, Garmin does have a couple of other options including a vehicle mount that uses a super strong adhesive or a friction style mount. These are available from Garmin directly on their website (www.Garmin.com) or through your local consumer electronics store, such as Best Buy.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 08, 2008 | Garmin Nuvi 660 GPS Receiver
How does teh suction cup ball fit into the garming 360
Greetings,
There is a seperate black clip that should have come with your gps if you purchased it new. Here is a link to Amazon to get a better idea of what I am talking about:
https://buy.garmin.com/shop/shop.do?pID=8125#
If you have the clip then there is a round indent in it that requires a good measure of force to attach to the suction cup mount.
Take Care,
-WN
May 06, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
318 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
